a380
SW B732/735 And Seating
Wed Jan 31, 2001 12:59 am
Questions from SW novice:
1) I believe there are no "assigned" seating in SW, but how to prevent people from scrambling for seats once boarding started? Not everyone is courteous.
2) On which routes are B732/735 used?
N202PA
RE: SW B732/735 And Seating
Wed Jan 31, 2001 1:15 am
A380:
1.) Southwest uses colored, numbered boarding passes that you pick up when you check in at the gate or counter. The color corresponds to the flight you're taking. The numbers go from 1 to however many seats there are on the airplane and are given out on a first come, first serve basis. If you get to the counter early, you can get a lower number. WN boards in groups of 30, first boarding group 1-30, then 31-60, then 61-90, then 91+. Many Southwest gates have signs for seperate queue areas where passengers in each boarding group are to line up, in order to organize the boarding process.
If you'll search the archive for "Southwest Boarding Policy" within the last year, you will find several discussions on this topic.
2.) Some of them, but not a whole lot. Since Southwest does not publish aircraft information for individual flights, it's impossible to tell you exactly which flights they're used on. However, from my personal experience, there seemed to be several of the 200s operating flights out of CLE and BWI.
a380
Westjet RE: SW B732/735 And Seating
Wed Jan 31, 2001 1:20 am
Thank you N202PA.
Do most discount airlines use the same policy? Like Westjet (I live in Canada)
N202PA
Wed Jan 31, 2001 1:32 am
As far as I know, no other airline uses this boarding procedure. Westjet, as I read, uses assigned seating obtained at the check-in counter. Vanguard also uses assigned seating. AirTran gives seat assignments at the gate.
Wed Jan 31, 2001 4:48 am
Because they are increasingly rare in the fleet, WN has taken to flying the remaining 732's through DAL and HOU in order to keep up the pilot hours. Also, DAL and (?) HOU do not have any noise restrictions that would apply to the -200.
If you do not want someone to sit next to you, look mildly insane as people pass you along the aisles. I find that muttering to myself about the voices and clutching my carry-on works well. Whatever you do, do not talk to the person in the aisle seat if you are in the window, or vice versa. If you make this critical mistake, people coming down the aisle will assume that you might be together and will ask to take the middle seat in hopes that your companion on the aisle will move to the middle rather than be separated from you, thereby surrendering the much coveted aisle seat to the newcomer.
I admit, it is a strange seating procedure at first. But once you get used to it, you start to resent the authoritiarian seating regime implemented by other airlines (What do you mean I am ASSIGNED to the worst seat on the aircraft!?)
Wed Jan 31, 2001 6:57 am
just because you are assigned somewhere doesn't mean you can't swap seats with someone who agrees. i do that all the time.
Wed Jan 31, 2001 8:46 am
The 737-5H4s are used mainly in the west and the -2H4s are used mainly in the east and southwest. The -5H4s are most predominant in California.
YXDFan
RE: Westjet RE: SW B732/735 And Seating
Wed Jan 31, 2001 2:14 pm
WestJet does not pre-assign seating when you make your reservation. However, they do assign you a seat at check-in. And they board by row number starting from the back (Row 20).
WestJet rules!
ABQ757
Thu Feb 01, 2001 3:13 am
Here at ABQ, I see Soutwest 732's about 2-3 times a day. Mainly ABQ-DAL flights. And I think 1 735 to PHX.
Fly America West 757's
Gabe
