United Airline
What Is 'ETOP'?
Thu Feb 01, 2001 9:50 pm
Can anyone explain what's 'ETOP'?
mls515
RE: What Is 'ETOP'?
Thu Feb 01, 2001 9:57 pm
Do a search. But briefly, it has to do with flying a twin engined airplane long distances away from suitable airports to land at in the event of an emergency. This usually means out over the ocean, but doesn't have to.
OO-AOG
RE: What Is 'ETOP'?
Thu Feb 01, 2001 10:04 pm
ETOPS is an acronym for Extended-Range Twin-Engine Operations. Without an ETOPS rating, an aircraft with only two engines must be able to get to an airport where it can safely land within 60 minutes if an engine fails in-flight. ETOPS extends this "rule time" to 90 minutes or more, up to a maximum of 180 minutes. Obtaining an ETOPS rating requires certification of the reliability of an airframe/engine combination as well as an airline's flight operations and maintenance. Usually extra equipment is required as well, such as additional backup systems for electrical power.
Falcon....like a limo but with wings
RE: What Is 'ETOP'?
Thu Feb 01, 2001 10:29 pm
WHy can't they be more than 180?....
ANy technical problems behind?
OO-AOG
RE: What Is 'ETOP'?
Thu Feb 01, 2001 11:19 pm
There has been some discussion about extending ETOPS rules to allow a 207/240 Minutes Etops. The main problem would be in case of inflight cabin fire (SR111 is a good example) or medical emergency. A 3 hours flight for diversion airport is an awfully long time!
Kubla
RE: What Is 'ETOP'?
Thu Feb 01, 2001 11:28 pm
OO-AAG,
I don't understand how a medical emergency is going to be affected by the number of engines on the airplane. Three hours is three hours when somebody is having a heart attack, whether they are on board a 747 or a 777.
Same goes with an inflight cabin fire - the number of engines doesn't seem to affect the effects of a cabin fire. An engine fire, yes, but not someting like what happened to Swissair.
RE: What Is 'ETOP'?
Fri Feb 02, 2001 5:56 am
The whole reason for ETOPS is specifically for engine related problems. The fire on SR111 or any medical emergency has no effect on the ETOPS rating of the aircraft. The whole idea behind ETOPS is to ensure that a twin engined jet will have enough power to get to an airport a certain distance away if one of the engines dies.
notdownnlocked
RE: What Is 'ETOP'?
Fri Feb 02, 2001 7:40 am
Engines
Turn
Or
Passengers
Swim
RE: What Is 'ETOP'?
Fri Feb 02, 2001 10:56 am
Extended Twin Operations. AKA, Engines turn or people swim. Operators want 180 ETOPS approval but have to prove to the FAA a high level of engine reliability. Don't assume it's just 180 minute no way-point trips over water. It simply means you have no airport that can accomodate you within 180 minutes. If you lose 180 ETOPS, the next level down is 120. Then you have to fly further up north and waste more fuel (to get to Europe for example).
classic707
RE: What Is 'ETOP'?
Fri Feb 02, 2001 11:17 am
Engines
Truning
Or
Passengers
Swimming
 Big thumbs up
