727 Hush Kits Wow!
Thu Feb 22, 2001 3:28 am
I just recently flew on an American 727-200 from MIA-DCA and I was astonished at how quiet the new hush kits were. I usually dred flying in 727's, but this time it was a really pleasant flight. (Not to mention the increased legroom.) Good job hush kit designers!
Starship
RE: 727 Hush Kits Wow!
Thu Feb 22, 2001 4:36 am
A 727-200 noisy on the inside?! You have to be kidding!
I have flown 727-200s without hushkits a number of times and I would never have considered them noisy. Try a Junkers Ju-52 sometime (especially with the windows open)!
Or a Bell Jetranger. If you need to wear a headset with boom mic to be heard - that's noisy. I have never seen anyone in the cabin of any 727 wearing a headset.
Behind every "no" is a "yes"
critter
Thu Feb 22, 2001 6:32 am
News Flash..!!!!!!!!!!!!!!!!!!!!!!!!!!
American has converted there B727-200 with the Riesbeck Hush kit. This particular version does nothing to the engines, that I am aware of. It is done all by flap settings and thrust ratings. Along with some minor modifications to the wings. This method is a whole lot cheaper than the Engine Modifications done by RORH or BF Goodrich. I will do some research as to the specifics of the changes.
critter
critter
Thu Feb 22, 2001 6:49 am
Topic: American 727's Hushkitted?
Username: Beechbarron
Posted 2000-05-27 04:39:36 and read 313 times.
Are American's 727's hushkitted with another model hushkit than the fedex one? I recently noticed at Hartsfield that there are no tailpipe mufflers on them. They are much louder too!!!
Ben
<< Next newer topic | Next older topic >>
Topic: RE: American 727's Hushkitted?
Username: AAR90
Posted 2000-05-27 05:06:27 and read 127 times.
Raiseback modification -- whatever that is. I read about it once or twice, but didn't pay any attention since it'll never be flown out on the left coast. Sorry.
Username: DFW-JETS
Posted 2000-05-27 05:16:30 and read 128 times.
A pilot I talked with at AA stated that there are 2 727 hushkits that AA uses. A expensive one and a cheap one, the expensive one for the 727s that are going to be retired last, which are the ones that now have the longer tailpipes, and the cheap kit is on the planes retiring soon, and have the regular tailpipe. Thats how he explained it. Sounds accurate to me....
Username: DL_Mech
Posted 2000-05-30 02:11:15 and read 76 times.
FEDEX offers several different versions of their hushkit. The longer tailpipe version is a high-gross weight version that involves extensive work on the forward engine mount assembly, as well as adding the long tailpipes with a "daisy-petal" inside and a two-inch extension aft of the compressor inlet guide vanes. The tailskid is changed as well. Some of our Delta shuttle planes have the low-gross weight FEDEX hushkit which have the short tailpipes with only the "daisy-petal" installed. Flaps are locked out of the 40 Degree position on both. The Raisbeck kit has different versions as well. Their high-gross weight version has an external "daisy-petal" similar to the old turbojet 707's. Their "cheaper" low-gross weight kit (which AA has bought) changes the leading-edge flap and slat actuators to increase lift from the wing (which requires less T/O power). This is all I know about the Raisbeck kit, so the mod could be more involved than what I have described here.
kmia
Thu Feb 22, 2001 6:54 am
the 727 was and will be always quiet inside, hush kits or not................
exusair
Thu Feb 22, 2001 6:55 am
I thought hush-kits only affected the noise outside of the aircraft. Due to the positioning of the engines at the back of the a/c you wouldn't be able to hear the noise of the thrust generated, only the buzzing of the compressor. You can definitely hear them on a 727 if you are in the last 2 rows or on the aft f/a jumpseat. The noise is definately nominal in the front of the plane.
critter
Thu Feb 22, 2001 6:57 am
Here is some more information from the Tech-ops forum.
"Hush Kit" is really a generic term. I think the correct term for a hushkit is a physical modification to the engine itself. But it is apparent that there are some other modifications that are being considered hushkits that don't modify the engine in any way.
Raiebeck's level 1 "hush kit" modifies the flap settings to a max flap 25 landing and derates the engines. It's marketed as a hush kit as wit hthis modification the plane meets currents stage 3 noise standards.
I hope this helps.
critter
MX727
Fri Feb 23, 2001 3:22 am
A 727 with hush kitsmakes the same noise, but the range of this noise is in a very short area. Flap setting for landing is limited to 30 degrees, so you need less engine power on final approach.
Noise inside of the aircraft is not changed due to de hush kit. It depends on the speed the pilots want to fly it. A climb at 340 knots is very noisy inside.
Click for large version
Photo © Mark Abbott
KLM747
Fri Feb 23, 2001 6:36 am
I personally think the 727 is quiet the way it is. Great classic airplane!  Smile/happy/getting dizzy
KLM747 Big grin
