lax2000
UAL EWR-LAX Question
Thu Feb 22, 2001 10:40 am
Can some one tell me the flights and times that UA uses a 757 over the A320...
Thanks!!
Adam
RE: UAL EWR-LAX Question
Thu Feb 22, 2001 10:42 am
UA85 leaves EWR at 1220pm and is a 757. UA66 leaves LAX at 815am and is a 757 (it originates in Lihue, Kauai, Hawaii). Check UAL.com and do a flight search. There may be more 75's.
Early Air
Thu Feb 22, 2001 11:08 am
Sure, I do the EWR-LAX on UA route about once a month. Here are the flights that use the 757 and the the A320.
Flt# Dep time
85 12:20 pm
87 5:40 pm
Thats it, just those two flights, the rest are on the A320. I know that the 757 is larger but the A320 is actually nicer inside, it is a newer aircraft. You can not really tell a size difference in the cabin unless you are in the very back and staring up to the front. I suggest you go for a 320 flight. Their tv system is neat in that plane to. Plus, it's quiter!
