DFW
What Does "Heavy" Mean?
Sun Apr 25, 1999 3:36 pm
I have been flying for years, I am a business traveller and usually fly twice a week, but the one question I have never bothered to ask is, what do they mean when they say. "flight 001 heavy cleared to land?". I have noticed the term used on DAL, AA, and BA 767,777 flights here at DFW so one would assume it has something to do with the size of the aircraft. (?) Any help would be appreciated as always. Cheers.
Ken
RE: What Does "Heavy" Mean?
Sun Apr 25, 1999 4:46 pm
I believe there's a certain weight limit, and if a plane weighs more then that, then it will be called "heavy". I'm just not sure what that weight is.
As far as I know, the smallest plane that could be called a heavy is the 757, but I have never personally heard a 757 being called a heavy.
Sun Apr 25, 1999 8:42 pm
Hi everyone..
I'm totally new on here, but I just thought I should answer your question. "Heavy" is normally used to describe wide-body jets, or so I was meant to believe, I have never heard of aircraft being regarded to as "Heavy" due to their weight... Hope that helps. Till next time!
Sun Apr 25, 1999 9:59 pm
What I think it means that the plane has enough fuel on board to make an international flight, even though if it just flying a domestic flight.
Rooz
L-188
Mon Apr 26, 1999 2:13 am
It refers to the weight of the aircraft. They include it in their callsigns to designate the larger seperations required between themselves and other traffic.
I can't remember what the exact number is but 300,000 LBS sticks in my head for some reason. Can somebody out there correct or confirm??
"Heavy" aircraft have larger clearance seperations required because of the stronger votexes and wake turbulence generated by the aircraft. There was a big stink about the 757 a while back because it's wing design generates a strong votex but still its weight isn't enough to classify it as a heavy. I do belive that they did adopt a wider seperation for that aircraft.
Fred
Mon Apr 26, 1999 2:37 am
The weight is 220,000 pounds. I think that it is a waste of time saying it all the time as it is on your card. It is not required to tell them at all.
Mon Apr 26, 1999 6:13 am
One more note - As I understand it, the heavy designation is based on Max Gross weight, meaning that a heavy aircraft is considered heavy regardless of it's weight on a particular flight, as long as it is capable of taking off over a certain weight (220,000 lbs??) If 220,000 is the deciding weight, 757 is heavy, due to the fact that it's max. t/o weight (as listed on AA's website) is 240,000 lbs.
n4khgirl
Mon Apr 26, 1999 6:48 am
I thought heavy was used to describe a widebody cargo plane
mirage
Mon Apr 26, 1999 7:24 am
The 757 is not "heavy" for ATC purposes. In addition, there are many wide body aircrafts that don't use the designation "heavy" on ATC communications.
It seems it's not very clear the criterion to use this designation or if it's clear, then, there are many pilots who forgot to use it.
Luis, Faro, Portugal
Mon Apr 26, 1999 8:26 am
I just spoke to a briefer at the Terre Haute Flight Service Station, and after looking it up in a book she gave me the following definition of a "heavy" aircraft: "An aircraft that is capable of operating at a weight of 255,000 pounds, whether or not it is doing so on a particular flight." Therefore, the 757 is not a heavy, because even it's max. taxi weight is <255,000 lbs, but those aircraft that are heavy are always heavy, regardless of load. i.e. AA's 777 would have been identified as heavy when it was doing touch and goes in Fort Worth for pilot training before entering service, despite the fact that it probably had relatively little fuel and only a few people on board.
RE: What Does
Mon Apr 26, 1999 10:51 am
The maximum gross takeoff weight on a 757-200pf is 255,000 lbs. FYI
There was a post earlier about a heavy designation only going to wide body aircraft. Why is our DC-8 71 and 73's designated as a heavy jet then? It is based upon weight. Would you classify a DC-8 as a wide body?
dash8
RE: What Does
Tue Apr 27, 1999 1:37 pm
Well just to throw in my two cents. In our BOM it states that a heavy is any plane with a MTOW of 130,000 kg (300.000lbs). No matter how small the plane is. Also it is said the although the 75 is not a heavy it should be considerd as such by both ATC and flight crew.
Also the term "heavy" isn't required for every transmission, only the initial call to the appropriate ATS unit.
dash8
joe
RE: What Does
Wed Apr 28, 1999 8:43 am
Two more cents... I beleive the separation requirements for heavy jets are greater that those of "normal" aircraft. One more reason to indicate it in the call. One more thing, KC-135 tankers (B707) are considered heavy, although narrow body.
RE: What Does
Thu Apr 29, 1999 8:37 am
I read once that a heavy aircraft was any aircraft with a rock band on board or an aircraft that was cool to look at.
In this context a russian aircraft is seldom heavy since they are not cool to look at. Also, they almost never have a rock band on board.
Bugger..
hmmmm...
Heavy Means 300,000lbs Mgtow
Fri Apr 30, 1999 11:05 am
According to Aviation Week online, the 255,000 lbs figure is relevant only to the term "large" for the purpose of aircraft traffic separation. Larger aircraft need more separation from smaller ones due to the problem of wake turbulence. The term "heavy" refers to any aircraft which has a MGTOW of 300,000 lbs or more.
An optimist robs himself of the joy of being pleasantly surprised
