Critter_592
Number Of Flight Attendants Required?
Sat Feb 24, 2001 10:47 am
How many flight attendants are reqired for Domestic flights on a 767-300 and 757-200?
desertjets
RE: Number Of Flight Attendants Required?
Sat Feb 24, 2001 10:54 am
Good question, but I think the rule of thumb is one for every 50 or so.
On a recent AA 757 flight there were 4 or 5 FA's on board. One in FC, and the remainder in steerage, I mean coach. On the smaller 737s (300/500/700) I have seen 3-4. I am sure there is someone out there who knows what the FAA/ JAA/CAA require.
ILUV767
Sat Feb 24, 2001 11:12 am
757s must have 4, 767-300 Domestics must have 5
Critter_592
Sat Feb 24, 2001 11:20 am
Thanks ILUV, but can I ask where u got your info from?
delta fly boy
Sat Feb 24, 2001 11:31 am
how ya doin... ILUV is correct.. however, in my Airline Employee handbook, the F.A.A minimum staffing requirements for the B-757-200 is 4, and the max jumpseats are 6/5. On the B-767-300 says 6 with the maxjumpseats of 8, and the 767-300ER domestic is 5, with the max # of jumpseats being 11. Hope that helps. And just as somepersonal input, don't ask me why the minimum staffing is less on the ER. Take it easy!
airnewzealand
Sat Feb 24, 2001 11:47 am
Here in NZ and Australia, There has to be 5-7 Cabin Crew members on Board a 733 aircraft,
744: 18-21 FA's
732: 6 FA's
734: 4-7
735: 3 and upwards
738: 6 Cabin Crew members
742: 17 Cabin Crew
752: 5-6 Bain Crew members
762: 10 Cabin Crew members
763: 11 FA's
772: 15-17 FA's
BAe146: 3-4 FA's
Concorde: 6 Cabin Crew
A320: 5-6 Cabin Crew members
A319: 4 FA's
A332: 9 FA's
A333: 14 FA's
A343: 14 Cabin Crew
MD-11: 11 Cabin Crew
Saab340: 1-2 Cabin Crew
This is reference to how many Jumpseats are on board. The flight can only depart with the least number of FA's on the right.
i.e If oi wrote 9-12, There has to be 9 flight attendants on board in order for the plane to take off.
Hope this helps.
Ny the way i got my info from My sister who works for AirNewZealand.
'mikey
(Future flight attendant)
delta fly boy
Sat Feb 24, 2001 12:08 pm
the above info is not correct for US carriers. A 732 MAY have 6 jumpseats, but no way is that the minimum f/a required. I don't think I've ever seen a US domstic 733 with more than 4 f/a. And a 762 does not have a minimum of 10 f/a. sorry.
airnewzealand
Sat Feb 24, 2001 12:58 pm
I said Australia and NZ. Sorry i was meant to put the least next to it. Here it goes,
732: 3-6 Cabin Crew
734: 3-7 Cabin Crew
735: 3-7 Cabin Crew
738: 5-8 Cabin crew
733: 4-7 Cabin Crew
742: 17 Cabin Crew
744: 17-21 Cabin Crew
752: 4-6 Cabin Crew
762: 8-10 Cabin crew
763: 8-11 cabin crew
772: 15 cabin crew
BAe146: 3-4 Cabin crew
Concorde: 6 Cabin crew
A322: 6 Cabin crew
A319: 4 cabin crew
A332: 9 Cabin crew
A343: 14 Cabin crew
MD-11: 11 Cabin crew
Saab340: 1-2 Cabin crew.
Sorry about the mistake i made in the first post. I was talking about International Service on these aircrafts. Some are Domestic!
mikey
(Future flight attendant for AirNZ)
ILUV767
Sat Feb 24, 2001 1:45 pm
Man...6 flight attendants on a 737. Sweet. Service must be good
Also, my info is based on the 50 passenger rule
a380
Sat Feb 24, 2001 1:55 pm
My friend was on an A320 with only ONE F/A on board! That's what he told me.
woxof
FAR 121.391
Sat Feb 24, 2001 2:31 pm
Sec. 121.391 Flight attendants.
(a) Each certificate holder shall provide at least the following flight attendants on each passenger- carrying airplane used:
(1) For airplanes having a maximum payload capacity of more than 7,500 pounds and having a seating capacity of more than 9 but less than 51 passengers--one flight attendant.
(2) For airplanes having a maximum payload capacity of 7,500 pounds or less and having a seating capacity of more than 19 but less than 51 passengers-- one flight attendant.
(3) For airplanes having a seating capacity of more than 50 but less than 101 passengers--two flight attendants.
(4) For airplanes having a seating capacity of more than 100 passengers-- two flight attendants plus one additional flight attendant for each unit (or part of a unit) of 50 passenger seats above a seating capacity of 100 passengers.
(b) If, in conducting the emergency evacuation demonstration required under Sec. 121.291 (a) or (b), the certificate holder used more flight attendants than is required under paragraph (a) of this section for the maximum seating capacity of the airplane used in the demonstration, he may not, thereafter, take off that airplane--
(1) In its maximum seating capacity configuration with fewer flight attendants than the number used during the emergency evacuation demonstration; or
(2) In any reduced seating capacity configuration with fewer flight attendants than the number required by paragraph (a) of this section for that seating capacity plus the number of flight attendants used during the emergency evacuation demonstration that were in excess of those required under paragraph (a) of this section.
(c) The number of flight attendants approved under paragraphs (a) and (b) of this section are set forth in the certificate holder's operations specifications.
(d) During takeoff and landing, flight attendants required by this section shall be located as near as practicable to required floor level exists and shall be uniformly distributed throughout the airplane in order to provide the most effective egress of passengers in event of an emergency evacuation. During taxi, flight attendants required by this section must remain at their duty stations with safety belts and shoulder harnesses fastened except to perform duties related to the safety of the airplane and its occupants.
(e) [Reserved]
BostonBeau
Sat Feb 24, 2001 10:37 pm
What amazes me sometimes is the mismatch between the number of flight attendants and the number of passengers. I mean I have been on flights with 150 passengers and the minimum number of flight attendants, and the flights were awful because the poor FAs couldn't keep up with that number of people (Eastern's Air Shuttle on the A300, right after the Pan Am Shuttle had started, and they had to deliver snacks and drinks AND collect fares both during flight.). And also on flights with 10 passengers and 14 flight attendants (a TWA B747 between LAX and BOS, that somehow had made it to the printed timetables, but not into the rez computers, so there were almost no passengers; that was a funny situation, cause I went to the ticket office to buy the ticket..and the sales agent said "no such flight" and I showed it to her in the printed timetable. She said "OK...I will write a ticket...but don't expect there to be a plane at the airport when you get there" LOL).
Critter_592
Sun Feb 25, 2001 6:16 am
Thanks everyone for you input. Woxof I appreciate it.
airnewzealand
ILUV767 & Critter
Sun Feb 25, 2001 7:20 am
Why did you want to know??
Iluv767: That is why NZ service is so great on Domestic and International Flights!!
mikey
Critter_592
Sun Feb 25, 2001 10:54 am
Just curious. Had never heard what the FAA's limits were.
