debn
United's Scheduling Error?
Fri Mar 02, 2001 9:11 am
Does this make sense?
Date: 04/01/01
Flight UA5875 Departs FWA 2:30pm
Arrives ORD 2:20pm
Doesn't daylight saving time kick in on April 1st? As far as I know, Indiana doesn't change it's time. Looks like a serious error by some UAL employee.
Big777jet
RE: United's Scheduling Error?
Fri Mar 02, 2001 9:43 am
Yep, I think you were right! It should be read 3:20pm not 2:20pm arrival ORD. I don't know what happen. Whoa!
Big777jet
Early Air
Fri Mar 02, 2001 10:04 am
contact ua, that is a problem.
chiawei
Fri Mar 02, 2001 10:12 am
Part of indiana does have day light savings. Fortwayne is part of eastern time zone.
The other airport such as IND and LAF do not change.
debn
Fri Mar 02, 2001 10:38 am
FWA does not observe daylight saving time.
I rechecked UAL schedule. Their daylight saving schedule starts on April 2nd(not on April 1st). Someone picked the wrong date.
desertjets
Fri Mar 02, 2001 10:43 am
Isn't Fort Wayne in the Eastern Time Zone though, IIRC only NW Indiana is in Central time and they don't switch to daylight savings.
SegmentKing
Fri Mar 02, 2001 12:25 pm
If that leg is goofed up, all they need to do is make sure the ORD-FWA positioning leg is goofed up to. If it is, then all is well and they can fix it. Everyone will just be a tad early for the flight.
nate
~ ~ ~ ~ pRoFeSsIoNaL hUrRiCaNe DoDgEr ~ ~ ~ ~
JetService
Fri Mar 09, 2001 4:35 am
It appears the schedule is indeed incorrect. On 4/1/01 at 2:00am, the folks in ORD will move their clocks up one hour. The folks in FWA will not, therefore both will be on the same time (Central). So either this is a mistake or United is unveiling some new technology on this route. heh heh
"Shaddap you!"
jmc1975
Southwest IN - Daylight Savings Time
Fri Mar 09, 2001 4:52 am
Actually, it's Sothwestern Indiana (i.e. Evansville) that observes Daylight Savings Time and is on the Central Time Zone. All the rest of Indiana doesn't observe Daylight Savings Time.
PHLflyer
Fri Mar 09, 2001 5:04 am
Well, I have no idea if they observe DST in that part of Indiana, but I do know that either AA or UA is incorrect. If you look at AA4064 FWA-ORD its times are 1306-1407, someone has made a mistake.
debn
Fri Mar 09, 2001 5:10 am
I called and sent emails to United. No one responds. Looks like they don't give this issue much importance.
I have already booked a ticked on this wrongly scheduled flight. And I need to cancel it, cause I have some other things to do. Wondering, if I can use this "wrong schedule" excuse to make them waive the cancellation fee.
SegmentKing
Fri Mar 09, 2001 5:27 am
01APR-SU-6A FWAORD(FWACHI) ET CT
ORD ALTERNATE CGX MDW
1#AA4338 Y5 B5 H0 K0 M0 V0 S0 N0 FWAORD 600A 655A * ERJ 0
L0 Q0
2#UA5879 Y9 B9 M9 H0 Q0 V0 W9 S9 FWAORD 650A 645A * D38 0
T9 K9 L9 G9
3#AA4326 Y1 B1 H0 K0 M0 V0 S0 N0 FWAORD 837A 931A * ERJ 0
L0 Q0
4#UA5877 Y9 B9 M9 H9 Q9 V9 W9 S9 FWAORD 1100A1055A * D38 0
T9 K9 L9 G9
5#AA4064 Y6 B6 H0 K0 M0 V0 S0 N0 FWAORD 106P 207P * ERJ 0
L0 Q0
6#UA5875 Y9 B9 M9 H9 Q9 V9 W9 S9 FWAORD 230P 220P * CRJ 0
T9 K9 L9 G.
2#UA5871 Y9 B9 M9 H9 Q9 V9 W8 S9 FWAORD 405P 355P * CRJ 0
T9 K9 L9 G0
4#AA4342 Y7 B7 H7 K7 M7 V7 S7 N1 FWAORD 606P 705P * ERJ 0
L5 Q5
6#UA5873 Y9 B9 M9 H9 Q9 V9 W9 S9 FWAORD 700P 755P * D38 0
T9 K9 L9 G0
hehehe.. air wisconsin has just discovered how to offer time travel!
RJNUT
Fri Mar 09, 2001 6:11 am
I used to do scheduling for Midway Connection in 1992 and that was one of my worst nightmares...fwa-mdw . i always made doubly sure, twice a year ,that i had that sched. correct, b4 loading with OAG.. Oops, looks like a mistake to me!!!
RE:RJNUT
Fri Mar 09, 2001 7:08 am
A scheduling error kinda like the UAL 737-300's in TVC this summer? Watcha think?
JetService
Fri Mar 09, 2001 7:32 am
Debn, good luck with the 4 minute layover at ORD.  Big grin
"Shaddap you!"
RJNUT
Fri Mar 09, 2001 7:46 am
One error i did make at Midway connection was loading a flight in OAG from MDW-TVC. but i entered MDW-TVL which is Lake Tahoe...the flight made it out to the travel agents systems and actually had someone booked on it...they were disappointed to not got to Tahoe
Fri Mar 09, 2001 8:11 am
Is it me, or is UAL the most screwed up airline in the business now.
ILUV767
RE: Boeing757fan
Fri Mar 09, 2001 9:05 am
Its just you.
I Like To Fly
Fri Mar 09, 2001 9:13 am
Just you, I can think of some much worse airlines and mistakes.  Smile/happy/getting dizzy
Why do you think a simple scheduling error makes them so screwy?
debn
Fri Mar 09, 2001 9:40 am
JetService, you are right.
I have only 4 minutes to connect at ORD.
But how do you know my schedule ? I didn't tell anyone.
Either you are God or an UAL employee.
JetService
Fri Mar 09, 2001 11:41 pm
Debn, actually it was just a lucky guess. I was guessing your layover was anywhere from 45 minutes to 1:15 (that's what mine usually are). The scheduling-mistake slashed an hour off the layover, so I just pulled the number 4 out of the air. Besides, if I were God, FWA would have UAL mainline service. Big grin
"Shaddap you!"
