AC
Stall
Fri Apr 30, 1999 12:00 pm
What's a stall? Something about the plane going too slow for the engines or something?? Thanks.
I Believe I Can Fly...
L-188
RE: Stall
Fri Apr 30, 1999 12:33 pm
Simply stated it is when the angle of attack of the wing exceeds the critical angle of attack.
RE: Stall
Mon May 03, 1999 2:07 am
When the wing goes through the air at too great an angle, the airflow around the wing becomes disrupted and the wing no longer produces sufficient lift. As the others hinted, this maximum angle is called the critical angle of attack. A stall has more to do with the angle between the flight path and the aircraft's attitude than with the speed of the air, as an airfoil can stall at any speed if the Critical Angle of Attack is exceeded.
