Granite
LHR BA Terminal Flights Switch
Wed Mar 21, 2001 7:06 pm
Hi all
I came across this information today, maybe old news to some.
London Heathrow Airport regulars should be careful in checking just which departure terminal to use in the future. British Airways is getting together with Heathrow Airport Ltd to make infrastructure changes which will allow T1 to handle some long haul flights. On completion some 25 daily short haul flights will move from T1 to T4 and about 10 long haul services will transfer to T1.
Click for large version
Photo © Gary Watt
Now, I am flying to/from Heathrow in Ausust so I wonder where I will be Big grin
Gary Watt
Aberdeen, Scotland
Ikarus
RE: LHR BA Terminal Flights Switch
Wed Mar 21, 2001 8:04 pm
Hi!
I haven't heard anything about that - but I'm rather interested: When will these changes occur? Which flights are likely to change terminals?
Looking forward to more infos
Ikarus
mrjworth
Wed Mar 21, 2001 8:58 pm
Terminal 4 is always very overcrowded, with most long haul flights having to hold for a stand to arise. Too many flights not enough gates.
I can understand why there are considering this move, but does Terminal 1 does have the space and the
facilities which Long Haul passengers would expect?
This would be a temp move untill Terminal 5 is completed, i would have thought.
G-CIVP
Wed Mar 21, 2001 10:50 pm
I doubt that BA long-haul flights will move from T4 to T1 as I would have thought that the gates weren't large enough to cater for B747/B777. Anyone else got any more information?
aussiestu
Wed Mar 21, 2001 10:54 pm
We have already been told that longhaul flights will be moving to T1 once the aircraft stands and jetties are completed. There has been no notification as to what flights will move. There is to be 10 new jetties to enable jumbos and 777s to operate from T1.
G-CIVP
Wed Mar 21, 2001 10:58 pm
I'd be surprised if it happens.
Ikarus
Wed Mar 21, 2001 10:59 pm
What about B767s? They can easily be accomodated at T1, right? After all, some of the European flights are operated by 767s. So which BA long-haul flights are currently operated by 767s and could be moved immediately? There have to be some...
Ikarus
Crosswind
Thu Mar 22, 2001 4:51 am
South African Airways have been flying from Terminal 1 at LHR for many years now, all their flights are operated by B747s - so there are obviously several T1 gates that can accomodate the B747. Air Alliance also served T1 with their B747s in the mid-1990s.
If British Airways are planning to move some long-haul services to T1, this will probably be dependant on modification of some gates to accomodate additional large-widebody aircraft...
CROSSWIND
G-CIVP
Thu Mar 22, 2001 5:13 am
Aussiestu - I must agree that my first reply was slightly daft! I'll explain the rationale behind my initial replies.
Having looked at an aerial map of LHR, I would imagine that major amendments will be made to the Bravo cul-de-sac (?) if BA were to expand in T1. [Has anyone got specific details?]
My surprise comes from the fact, as Mrjworth hints at above, T1 as it stands, hasn't really got the floor-space/facilities to cater for B747/B777 passenger numbers and any changes would necessiate major construction works. This isn't to say it "won't happen" but I was under the impression that, in the short to medium term, BA were hell-bent on T5 so that they could merge short & long haul ops under one roof, so this "latest news" doesn't fit that well with BA objectives.
Also, wouldn't a long-haul split between T1 and T4 complicate BA ground ops even further? I know several long-haul flights operate out of T3, but a move to T1 means transferring support staff and equipment back from T4 to T1! Not exactly a cheap operation and loss of economies of scale. I hasten to add I could be very wrong!
Note to Ikraus; BA does operate B767's out of T1 already, eg on routes to Cyprus etc.
aussiestu
Thu Mar 22, 2001 6:24 am
To G-IVP I can only go as to what we were told in our BA newspaper and company reports. The work has already started and while somebody else says that SAA already serve 747s to T1 thats the only gates that will accomodate them. BA is planning to move from 10+ longhaul flights to T1 and so will need many more gates. While it may not make sense to most people T5 is a long way off and this apparently makes sense in the interim. We already operate longhaul from T4 and T3 so why not T1 as well. I would think that the T3 operations will cease and be moved to T1 or T4 once all these longhaul gates have been added.
747firstclass
Thu Mar 22, 2001 6:26 am
I think this is so that BA can increase their flights to the US. This arrangement will do, so they think, until a complete openskies takes effect and the new T5 is complete. Look for BA to transfer some USA flights to LHR from LGW and make a token offer to permit more US carriers access to LHR.
