hkgspotter1
UA821 (JFK-HKG) Cancelled Today... Why?
Thu Apr 12, 2001 2:14 pm
I was just checking the CLK airport page and UA821 is shown as cancelled !!, Does anyone know why ??
StarAlliance
RE: UA821 (JFK-HKG) Cancelled Today... Why?
Thu Apr 12, 2001 2:41 pm
It seems strange for Hong Kong indeed. Besides, anyone knows what happens to the JAL flight departing on 13/4 at 03:50 - JL 2706 - to Fukuoka and the flight departing at 04:35 - JL 1704 -to Osaka/Kansai ? Is that some tours charter those flights, but JAL cannot provide?
hkgspotter1
Thu Apr 12, 2001 3:00 pm
Both of those flights have been cancelled.
lxlgu
Thu Apr 12, 2001 3:13 pm
Hi HKG Spotter
According to UA CRS flight cancelled due mechanical
in advance of flight check in times
Hope this helps!
Cheers!
Tony
hkgspotter1
Thu Apr 12, 2001 5:41 pm
They did not get another aircraft ??
ILUV767
Thu Apr 12, 2001 6:20 pm
Hey Everyone,
Im back from my 3 day trip with a lot of flying!  Big thumbs up Yesterday Denver was closed due to snow and a power outage. This caused massivie delays in the united system. Chicago was also affected, but mainly from severe thunder storms. While the aircraft may have been on a mechanical, I think that DEN and ORD were key players in the flights cancleations. Even though that aircraft may not have even passed through there.
n949wp
Thu Apr 12, 2001 7:20 pm
Hkgspotter,
If I'm not mistaken, UA only have a couple of 744 flights out of JFK. So if one plane goes mechanical, they'll be hard-pressed to find a replacement in short order.
If it had been ORD or SFO, then it might be a different story.
'949
senliture
Thu Apr 12, 2001 9:01 pm
I've just back from CLK. Will that be a possible reason for the UA821 cancelled due to strong headwind at the polar?
But the CO99 arrived on-time today
HS-LTA
Thu Apr 12, 2001 9:08 pm
Due to thunderstrom at JFK made the planes UA821 hasn't arrived.
hkgspotter1
Fri Apr 13, 2001 1:53 am
You dont cancel a flight because of a thunderstorm !!, this can not be the reason.
949,
That sounds a more possible reason.
See'ya
SegmentKing
Fri Apr 13, 2001 1:57 am
Wanna bet? tons of flights are cancelled due to Thunderstorms. Try Camp O'Hare back in mid september. Hundreds were cancelled... the weather was aweful..... I remember driving into work that day from Lake Geneva WI... the tri state was moving at about 20 mph due to the hard rain.. you could barely see 100' in front of you... took me about 3 hours to drive 70 miles vs 90 minutes.
Nate
~ ~ ~ ~ pRoFeSsIoNaL hUrRiCaNe DoDgEr ~ ~ ~ ~
ILUV767
Fri Apr 13, 2001 3:29 am
Also, try O'Hare yesterday. The T.V.s at IAD said that ORD was experencing severe thunderstomrs causing a lot of flight canclations and delays.
OH-LGA
Fri Apr 13, 2001 6:14 am
Of course you can cancel a flight because of a thunderstorm... planes fly around thunderstorms, so it doesn't make much sense to take off into one... taking from my knowledge of meteorology (which was recently expanded by leaps and bounds thanks to a class) the wind shear associated with thunderstorms makes it extremely dangerous to fly in one, do you remember the DL incident at DFW (they made that movie about it, Fire & Rain i think the title was).
It could have been a mechanical, or even a mixture of several factors, but flights can be cancelled in the event of a thunderstorm that causes conditions that are unsafe.
Moi,
Kai
Head in the clouds... yet feet planted firmly on the ground.
