ZK-NBT
Singapore Airlines 744's
Sun Apr 22, 2001 3:01 pm
This question may have been asked before? Do SQ 744's have different seating configurations. IE. The SM aircraft and SP aircraft. Just wondering because in AKL 9 out of 10 we get the SM series mainly SMA-SMQ. I was at the airport TUES WED THURS FRI 2 weeks in a row SME SMG SMJ SMA SME SMC SMN SMQ. Those were the aircraft for the 2 weeks hope you can understand. Scott.
RE: Singapore Airlines 744's
Sun Apr 22, 2001 3:24 pm
SMA-SMH have a 16-58-316 config. The rest have 12-52-316 config.
GUNDU
ZK-NBT
Sun Apr 22, 2001 5:57 pm
Thanks for that. Sorry if the original was a bit hard to understand. Scott.
Singapore 777
Sun Apr 22, 2001 7:33 pm
Basically, the series SMI-SMZ, SPA-SPJ and SPL-SPO are all refitted aircraft with the new First Class and Business Class seats. The series SMA, SMC, SME - SMH are all with the 16F, 58J and 316Y configuration but the First Class seats are new ones also.
Sun Apr 22, 2001 7:42 pm
Ways in which you can tell if SQ 744's are configured with Sleeper Seats in First Class and new Ultimo Business Class seats.
1. By identification of the aircraft registration as mentioned by this post SMA,SMC,SME-SMH.
2. If you look at the number of windows between Door 1 and Door 2, if there are two windows starting from Door 1, this indicates that the aircraft has an old configuration whereas the newly reconfigured aircrafts do not feature the two windows from Door 1 as First Class toliets are located in this area now.
