Thom@s
SAS Grounds All B737s
Thu Apr 26, 2001 10:44 pm
Does anyone have more detailed information for why they needed to be grounded? I got the impression that it was about the 737-600, but in the news they said Braathens have the same type of aircraft. (Braathens don't have the 600 version.)
Can anyone help?
Thom@s
"If guns don't kill people, people kill people - does that mean toasters don't toast toast, toast toast toast?"
Samurai 777
RE: SAS Grounds All B737s
Thu Apr 26, 2001 11:05 pm
SAS's grounding of its 737-600 fleet might have something to with the FAA ordering emergency inspections of all newer Boeing 737s because of a defect in the tail assembly. This move appears to affect only 737NGs.
This link below shows the related article.
http://www.nandotimes.com/nation/story/0,1038,500476372-500731724-504176921-0,00.html
shankly
Fri Apr 27, 2001 1:04 am
Given the much publicised rudder problems on the older 737's, the FAA directive is quite amazing. What is it with Boeing and the back end of 737's?
L1011 - P F M
Thom@s
Fri Apr 27, 2001 1:30 am
Ahh, I've heared about those problems. It caused two 737s to roll uncontrolably, didn't it?
Thom@s
LN-MOW
Fri Apr 27, 2001 1:34 am
SAS has not grounded any aircrafts. I don't know where you got that from. They're doing the same as everyone else; checking the aircrafts in between flights or overnight. As far as I can tell, it's not a very time consuming job..
- I am LN-MOW, and I approve this message.
Thom@s
Fri Apr 27, 2001 1:46 am
They said so on the News
Thom@s
LN-MOW
Fri Apr 27, 2001 1:51 am
.... and since when were 'the news' credible? LOL
Some journalist probably added 2+1 and got 4 ...
There probably is a deadline for the check, but as long as all planes are checked within that time, no planes will be grounded.
Thom@s
Fri Apr 27, 2001 1:59 am
Maybe you're right. What do they know about aviation anyway?  Smile
Thom@s
GOT
Fri Apr 27, 2001 2:10 am
SAS wouldn't ground there 737 unless the where forced to it. It's a mian part of there fleet and grounding them would be really bad for SAS. Hope that they wont find any problems.
GOT
Just like birdwatching - without having to be so damned quiet!
SK A330-300
Fri Apr 27, 2001 2:11 am
No aircraft will be grounded according to SAS information department.
heisan67
Fri Apr 27, 2001 4:08 am
Just flew a SAS B737-600 today....and we were definitely flying....so the information must be wrong I guess.
Braathens aircrafts B737-400/500/700 are all flying today as well. All different models seen at Oslo airport -OSL today with pax embaring and disembarking.
OE-LDA
Fri Apr 27, 2001 4:21 am
I was in CPH two days ago and saw SK 737 flying.
Regards, OE-LDA
I am totally missing basics and clueless about airline flying!
prebennorholm
RE: SAS Grounds NO B737s
Fri Apr 27, 2001 4:57 am
There are absolutely no news in Scandinavia today. Even the weather is quite normal - mostly rain of course. The radio news tonight had to repeate all subjects about three times to fill up the allocated 20 minutes.
Such situations make journalists desparate, and then such faults happen.
Best regards, Preben Norholm
