flying-b773
Flights Into Cheju
Thu May 17, 2001 12:30 am
I need help..... thanxs for any given
Hmm, to my knowledge, the 2 korean airlines, KE and OZ do fly from seoul to cheju.
however, are they any other foreign airlines that fly to cheju as well?
Thanks a lot
airmale
RE: Flights Into Cheju
Thu May 17, 2001 12:45 am
Cheju officially re-spelt Jeju and now known as latter Smile
.....up there with the best!
flying-b773
Thu May 17, 2001 12:48 am
i see.. thanxs a lot...
Kubla
Thu May 17, 2001 1:12 am
As far as I know, only KE and OZ can provide domestic service inside Korea, so they are the only options from Seoul. Also, if you are going through Seoul, you'll have to make the transfer from Incheon airport to Gimpo to catch Jeju flights.
It doesn't make much difference in this case, as Jeju International (CJU) is only served by those two airlines anyway. I believe the international routes are to Tokyo (via Pusan), Nagoya, and Osaka on KE and to Fukuoka on OZ.
Here's a web site with transportation info to Jejudo. I'm not sure how up to date it is, so be sure to check with other sources too.
http://www.chejuinfo.net/trans/trans_e.html
flying-b773
Thu May 17, 2001 1:52 am
thanxs a lot, kubla.
i was a bit troubled, because i heard tt ANA do fly into jeju...
anyway, my problems are solved.. thanxs a lot
jourdan747
Thu May 17, 2001 4:28 pm
KE also flys from PEK to JEJU and from HKG to JEJU...hope this helps!
