aad665
Pilatus PC-12:Right Aircraft?
Wed May 23, 2001 9:11 am
Hi,
I'm writting a business plan to start a new airline. I plan to flight in Eastern Canada only.
I'm looking for a very fuel efficient aircraft not bigger than 19 px. The leg should not be longer than 400-500nm. as exemple YQB-YYZ or YYZ-YOW-YQB.
Pilatus PC-12 looks very efficient. and it's not too risky ($$$) for a start-up.
What do you think?
Thank for your input, I really appreciate.
Luc
ILOVEA340
RE: Pilatus PC-12:Right Aircraft?
Wed May 23, 2001 9:21 am
I would have to agree with you however from a passenger stand point itis not the most pleasent aircraft to fly in. Have you thought about metro II/III's?
aad665
Wed May 23, 2001 10:44 am
I did. Metro II/III not enough fuel efficient...plus they have two engines. That means more operating expense.
Air Montreal tried, without success, to operate Metro II/III and they failed.
Luc
Max Q
Wed May 23, 2001 11:22 am
You might want to check on the legalities of operating a
single engine aircraft for hire.
Jean Leloup
Wed May 23, 2001 11:24 am
Luc, I think the PC-12 looks great. It seems like a great aircraft. The 1 prop does not seem to give a really good image, but I'm sure you can't beat it for efficiency. I hope it happens for you and tell us if you get started! I'd love to fly on your airline, if i could afford it!
good luck
Next flight.... who knows.
777gk
Wed May 23, 2001 11:30 am
What about the Cessna Caravan? Those I believe are available with EFIS cockpits, and FedEx operates hundreds of them, so they must not be to hard to get your hands on.
desertjets
Wed May 23, 2001 12:04 pm
The PC-12 is a really great aircraft, I think it fits about 10 or 12 in a high density seating arrangement. But there may be legalities flying it for a scheduled airline... if you were running an air taxi service I'd say no problem... I just wonder if it is certified for the CAAs equivilant of FAR 121.
ILOVEA340
Wed May 23, 2001 1:32 pm
what about a compair 10?
catpac
Wed May 23, 2001 4:54 pm
ILOVEA340,
you seem like a funny guy, in your first post in this forum you say the almost new PC-12 is not as comfortable as a 30 year old flying cigar called metro III,....I would say that there is no way a Metro could compare to the PC-12 in terms of passenger comfort and I am sure many other aspects as well.
AAd65, as for your airline, my best suggestion would the King-air 350, its a twin turbo, so no problem in flying scheduled passenger operation (from FAA viewpoint) and it is a good performance aircraft all round,....things like MLW is the same as the MTOW, certified up to 17 pax...etc
Have fun planning your own airline
Mike
jwenting
Wed May 23, 2001 5:14 pm
PC12 has a major advantage: excellent shortfield performance (plus lower operating cost, as it is single engined).
If regulations are not an issue (as seems to be the case, others in the area obviously also operate it in similar settings) and you like her (I sure do like the looks and specs, don't have a license so don't ask about handling  Smile ) it becomes a matter of price and availability of both aircraft and staff (pilots, mechanics mostly).
Given the small size, what do you envision your planned feeders using? An operation with PC12s is likely to be a feeder itself, as the aircraft can go almost anywhere.
I wish I were flying
superdawg
Wed May 23, 2001 10:31 pm
The PC-12 is very popular here in Western Canada. SmartAir, PeaceAir, Northern Sky and Montair are all using the PC-12 for scheduled operations in Alberta and BC. I think it is very popular on the Calgary to Edmonton Municipal route as the Muni has the 10 passenger restriction.
S'Dawg
L-188
Wed May 23, 2001 10:37 pm
There are a lot worse aircraft to pick up then the PC-12.
AC183
Thu May 24, 2001 12:35 am
The PC-12 seems to be quite popular in Canada for small airlines. In addition to those mentioned by S'dawg, they're also operated in as charter, scheduled, and private aircraft by Bearskin, Wasaya, RJM, Chartright, Kelner, Pascan, Thunder Air, North American Charters, Ontario Government, Nova Steel, the RCMP, Keewatin Air, Expressair, and Nakina. I also believe there's other carriers planning on using them.
The PC-12 has several advantages. I heard (can someone confirm???) that at 9 seats it only needs one pilot, not 2. And being under 20 seats it doesn't need flight attendants. As a single-engined aircraft, it's cheap to operate. It has a high degree of flexibility because it can get into lots of airports. And although I've never flown one, I understand it has reasonable comfort levels.
The principle disadvantages of the PC-12 are that it doesn't match the appeal of jets, and it's also a fair amount of money to purchase (new aircraft have that tendency).
Personally I like the idea of using PC-12's. Compared to larger aircraft, they're lower risk. But be careful of competitors flying larger aircraft in the event they start up YQB. Flying niche market routes, however, that may not be a problem. I don't think you'd be working with connecting traffic to other carriers, so you could also use convenient alternative airports, such as Toronto Island or possibly even other alternatives to Pearson. There's also Ottawa-Rockcliffe, and Montreal-St.Hubert. I don't think it's wise to fly entirely to secondary airports, but by using some of them it might help reduce landing fees.
