kevin
Tu To Make A Gaz Aircraft
Thu May 24, 2001 12:04 pm
Just read in the Airliner World that Tupolev Bureau is planning to build an aircraft that will use gaz instead of fuel. Well not 100% gaz, but mixed with fuel.
As for me I like their creativity, but I'd stick with fuel  Big thumbs up
StarAlliance
RE: Tu To Make A Gaz Aircraft
Thu May 24, 2001 3:48 pm
Gas is much cleaner indeed! But why don't they use 100% gas? I just cannot figure it out!
Besides, we already have cars run on gas, then why can't we have planes run on gas?
philb
Thu May 24, 2001 3:57 pm
Tupolev have been playing around with alternative cryogenic and other fuels for a good few years and have flown a cryogenic powered TU154.
There are many fuel stability/storage and pumping issues to be resolved whatever alternate, or mix of, fuels is used but the team is way ahead of anyone else in the search for alternatives to the standard carbon based fossil fuels.
Thu May 24, 2001 4:53 pm
PhilB
You are right in that Tupolev has already tried and tested am LNG powered Tu-154. It's designation was the Tu-155, and made some 100 test flights from 1988.
During testing, it was found that only minor adjustments to the rates air intake and fuel supply had to be made, and that the aircraft was actually cost-effective.
After the testing, it was decided that production of the aircraft would go ahead, using the designation Tu-156. This was to have happened in 1996, but lack of funding pretty much ensured the project never went ahead.
Another problem which affected any production of the aircraft, was the installation by Gazprom at airports, the necessary equipment to be able to refuel and service the aircraft. This would be an immense cost.
There have since been other plans to produce LNG fueled aircraft; the Tu-206 and the Tu-136.
The Tu-206 is basically an LNG fueled Tu-24, and the Tu-136 was to be a development of the Tu-130 (a project that never got off the ground).
Once the Russian economy gets back on it feet, it is very possible that Tupolev, Gazprom and other parties may very well resume studies into the production of an LNG fueled aircraft.
Some information on the Tu-155, in Russian is at http://www.aviation.ru/Tu/Tu-155.html
Scotty
Aviatsiya/Авиация
