TOMASKEMPNER
Which Is The Longest Flight Operated By 757 & 767
Tue May 29, 2001 3:00 am
I want to know which is the longest flights operated by both 757-200 and 767-200/300/400.
I think that the longest 757-200 flight is MX 1691 :CUN-EZE (about 8.5 hours)
As for 767 I think that Spainair uses it for the MAD-EZE route (13 hours) and I think that UA use them for a while for their HKG operations, I don´t know if UA flew 767 from LAX to HKG because I think the aircraft lacks of range to operate that route.
As for 777 I think is CO : EWR-HKG route
RE: Which Is The Longest Flight Operated By 757 & 767
Tue May 29, 2001 3:08 am
as for 757-200 (though i don't know the exact time) i think icelandair's miami-kevlavik route is one of the longest ones
by738
Tue May 29, 2001 3:19 am
Glasgow - Orlando and Gatwick -Goa are long flights which were at one time operated by 757's. Although with a stop I think. Some of the GLA - Toronto flights operated by 757's must be long flights too.
B747-437B
Tue May 29, 2001 3:21 am
Ethiopian used to operate BOM-BJS with 757s back in the early 90s. With the airspace restrictions, that could run well over 9 hrs on a bad day.
"The A340-300 may boast a long range, but the A340 is underpowered" -- Robert Milton, CEO - Air Canada
MAH4546
Tue May 29, 2001 3:24 am
Icelandair does not fly Miami-Kevlavik. They do fly Orlando-Kevlavik, I think. Finnair flies Miami (actually, Fort Lauderdale)-Helsinki with a 757-200, but with a stop in Bangor, Maine. One of the longest 752 routes is AA's Miami-La Paz (Bolivia) which is about 7 hours. CUN-EZE is 8.55h, one long flight! I just find it wierd that MIA-EZE is 8.30h, though I'm sure equipment has something to do with it.
a.
B-HOP
Tue May 29, 2001 4:18 am
They did not really fly LAX to HKG non-stop, they are used for HKG-DEL as their round the world flight. I think CP have used it for Vancouver to Hong Kong in around 91/92. By the way, I think someone have a discussion about which is the longest route for 767, have a search.
Live life to max!!!
englandair
Tue May 29, 2001 4:19 am
Occasionally Uzbekistan Airways uses a B757 between Tashkent and London. I realise that's not as long as some of the suggestions, but how long does it take?
Jamie.
voodoo
Tue May 29, 2001 4:27 am
Prior to getting A330-200s
I think Canada 3000 did either
Vancouver and/or Calgary to London via Keflavik
with 757s.
` Yeaah! Baade 152! Trabi of the Sky! '
mjb69
Tue May 29, 2001 4:44 am
I flew AMS to EWR in a CO 752 (8hrs. 15 min). I believe it is listed as 3,657 mi.
mjb69
Tue May 29, 2001 5:10 am
Well just for the distance I've made YVR-YYC-KEF-STR on CMM 757-200.
The longest nonstop sector was KEF-YYC at 06.20h.
Rgds,
B737-700
GeneralA
Tue May 29, 2001 5:44 am
Continental Airlines operates the Duesseldorf (DUS) - Newark (EWR) route with 757-200. Total Flight time is 08:45h. In November they will switch to 767-200.
777-500er
Tue May 29, 2001 5:46 am
MXP-SFO on AZ is the longest 767 flight. It's 12.30h in the air.
Michael SFO
 Smile/happy/getting dizzy
skyservice_330
Tue May 29, 2001 5:47 am
2 summers ago I flew on a Air Transat 757 from Toronto to Glasgow. I think it was about a 7.5 hour flight.
AirCanadaMan
Tue May 29, 2001 6:16 am
What about the AC flight to Sydney on a 767-300ER.
I believe it starts in YYZ, then off to YVR to HNL to SYD.
Thats pretty darn long.
Heinz
Tue May 29, 2001 8:14 am
If you're not talking about non-stop flights, but flight number,
ROYAL BRUNEI used to operate FRA-DXB-BKK-BWN and
I think LHR-DXB-BKK-BWN with 757s, in the early 90s.
The flights still exist, but now with 763s.
Not strictly 757/767-related, I remember to have seen
Wardair Canada 727 C-FFUN in DUS several times on flights from Canada (not bad, eh ?!) , and if I'm not mistaken, Sterling
used to fly fly Caravelles all over the world. Maybe our
Danish / Swedish readers can contribute more details...
Best regards...Heinz
slawko
Tue May 29, 2001 8:38 am
Air Canada 3127 YYZ-HNL-SYD has to be one of the longest...or Air Canada's YYZ-TLV which is also a 767, Elal also operates the 767 on this route but it is YYZ-JFK-TLV.
"Clive Beddoe says he favours competition, but his actions do not support that idea." Robert Milton - CEO Air Canada
STT757
Tue May 29, 2001 10:05 am
El AL was flying ORD-Tel Aviv for a while with a 767-200 nonstop.
ei a330-200
Tue May 29, 2001 10:35 am
I believe that either Air Canada or Canadian flew from Vancouver to Sydeny. I don't think that they stopped, but I could be wrong. If it was non-stop, that was one hel of a long flight. By the way, that was on a 767.
Tue May 29, 2001 11:33 am
Let's bring some order to this chaos!!!
First of all, i think that Ladeco's route SCL-MIA is quite long for a 757-200 (8 hours and a half) although Ladeco is now a domestic chilean carrier.
And for the 767, could be the SCL-JFK route(11 hours???) or the GRU-MAD route (12 hours) both operated by LanChile, but the GRU-MAD route does not exist anymore because now LanChile flies directly to MAD from SCL in A-340
Alpha 1
Tue May 29, 2001 12:19 pm
CO 67 LGW-CLE, a752, is scheduled 8:45, and has taken as long as 9:30 when encountering stiff headwinds.
AC330
Tue May 29, 2001 12:48 pm
I know before Canada 3000 got its A330's they used to operate a YYZ - YVR - HNL - Raratonga - SYD flight on a 757. I could have the stops mixed up but i know I was a really long trip, especially for a 757.
Tue May 29, 2001 1:16 pm
I wasn't aware of the CUN-EZE 757....The only one that I knew about that I think would be kind of long in a 757 is the CO flt from CLE-LGW. There could be longer ones though.
Rafabozzolla
Tue May 29, 2001 1:32 pm
GRU-MAD is operated with 767s by Varig, wich also lands at MXP and FCO with these aircraft. I suppose the longest 767 flight is also with Varig GRU-LAX.
paulc
Tue May 29, 2001 3:41 pm
How about Taipei - Auckland - Air NZ 767-3 - i did this route in 1994 and it was around 12 hours
English First, British Second, european Never!
United_fan
Tue May 29, 2001 8:43 pm
I took UA71 LAX-LIH in March. It was 6.5 hours with the headwinds 2,615 miles. This has to be one of the longest,at least as far as UA is concerned.
Click for large version
Photo © Konstantin von Wedelstaedt
Scott
Champagne For My Real Friends,and Real Pain For My Sham Friends
airafriquedkr
Tue May 29, 2001 10:59 pm
I checked the mileage on flights that were suggested here, and these would be the longest (nonstop):
CUN-EZE on Mexicana is a total of 4286 miles (757)
MAD-EZE on Spanair is 6259 miles (767)
Rafabozolla:
The last day of RG's nonstop 767 GRU-LAX service will be on May 31. Then flight will then operate GRU-LIM-LAX.
AY-MD11
Tue May 29, 2001 11:21 pm
Finnair starts flying summer time to Toronto from Helsinki,Finland with a 757-200 nonstop that is pretty long flight!
 Big thumbs up
AY-MD11
gkirk
Tue May 29, 2001 11:26 pm
CO DUS-EWR would be pretty long. Thats operated by a 757 just now.
Tue May 29, 2001 11:30 pm
Air 2000 operate services from LGW-ANU (Antigua) with a 757 which is around 9hrs, JMC also do this.
HL  Smile/happy/getting dizzy
RayChuang
Wed May 30, 2001 12:27 am
I believe another very long 767-300ER flight was Aeroflot's SEA-SVO non-stop. I believe that is now flown by a 777-200ER, though.
NWA ARJ
Wed May 30, 2001 12:39 am
Last summer when I flew from Las Angelas to Detroit. I flew on a NW 757 and it took about 8 hours for the trip. I also flew from Minneapolis to Orlando on a NW 757 that took about 3 hours. Both were pretty long trips.
Nightmare 68, Fargo Tower, Runway 36, Fly Runway Heading, Mantain 10,000, Cleared For Takeoff, Change To Departure
Critter_592
Wed May 30, 2001 12:54 am
NWA ARJ Where is Las Angelas?
TOMASKEMPNER
Wed May 30, 2001 4:53 am
Mexicana # 1691
Cancun- Buenos Aires is the longest nonstop flight operated with 757-200 much longer than CLE-LGW, EWR-AMS, MCO-KEF, EWR-DUS.
Spanair
Madrid-Buenos Aires is one of the longest nonstop flights operated with 767-300ER, longer than AZ : SFO-MXP, RG : GRU-MAD, etc.
As for 747-400 the longest route is JFK-HKG and ATL-JNB.
For 777 : EWR-HKG
For A340 : HKG-YYZ,
EZE-AKL
and soon : CX´s : HKG-JFK
SouthRebels
Wed May 30, 2001 5:06 am
The 757 longest route is roughly 8 to 9 hours. Continental runs one CLE to LGW. United goes ORD to EZE with a 767-300, 13.5 hours.
United_fan
Wed May 30, 2001 11:06 am
I don't mean to be rude,but 8 hours LAX-DTW?? Did the pilot get lost???
Just wonderin'
747buff
Wed May 30, 2001 11:25 am
Aeroflot runs LAX-SVO with a 763.
At Eastern, we earn our wings every day!
rpwgw
Wed May 30, 2001 12:20 pm
I've flown Narita - Perth on a Qantas 767-300ER (QF 70). Restricted load meant a row of three seats!!! That flight takes 10hrs 15 minutes.
AEROMEX
Wed May 30, 2001 2:32 pm
On a 767-200ER might be Aeromexico's daily MEX-CDG. More than 11hrs.
Wed May 30, 2001 3:49 pm
i guess the longest flight on a 767 is Alitalia's Milan-Caracas route 15 hrs!!!  Wow!
correct me if im wrong  Smile
chepos
Wed May 30, 2001 5:04 pm
The Alitalia Milan-Caracas flight I highly doubt is 15 hours.
Chepos
Puerto
Fly the Flag!!!!
El Al 001
Wed May 30, 2001 8:28 pm
El Al used to fly TLV-ORD and TLV-HKG with 762.
It also operated in the past a 757 to JNB via NAI and to JFK via LHR/STN.
dutchjet
Wed May 30, 2001 9:18 pm
Present schedules may be different, but the MIA-SCL Ladeco flight was the longest nonstop 757 segment and the LAX-GRU was the longest 767 segment, I believe. Also, Air New Zealand operated the 767 nonstop Fiji-LAX for a while.
As more 777s/A340s come into service, aircraft are being reassigned and many of the very long 757/767 flights are being operated by the newer types so that airlines can avoid load restrictions and carry more cargo.
