StarAlliance
Any A340 Crash Before?
Wed Jun 06, 2001 6:40 pm
Are there any A340 crash before?
Thx
ZK-NBT
RE: Any A340 Crash Before?
Wed Jun 06, 2001 7:02 pm
No A340 has crashed before although 1 was detroyed by fire at Paris in about 1994, aircraft belonged to Air France.
Scott.
hkgspotter1
Wed Jun 06, 2001 7:06 pm
The only A330/A340 to crash was one of Thais A330's during a test flight in France. The aircraft was still owned by Airbus.
A320-addict
Wed Jun 06, 2001 9:20 pm
Sabena has had a crash with one of it's A340's.
I think it was oo-scw, returning from JFK to Bru, about 3 years to go.
It landed on rwy 25L at Brussels. Touchdown was reported as being normal. 2 Sec after the touchdown, the right main gear broke of, making the aircraft sliding down the runway. On it's way the gear also tore off the main part of the rudder and elevator.
No injuries were reported.
The aircraft was out of service for almost 1 year and is now again in service at the company.
zauberfloete
Wed Jun 06, 2001 9:23 pm
That´s not a crash, it´s an incident.
A320-addict
Wed Jun 06, 2001 9:34 pm
Maybe we should define the word "crash" then.
I think an airplane that slide down 2000ft on the runway, and ends up in the grass, after which it is out of service for more than one year because it had almost beyond repair damage..., is rather a crash then
and "incident" although indeed there were no fatalities.
Once again, just my humble opinion
A320-addict
Wed Jun 06, 2001 9:39 pm
By the way,
An A340 that burns down on the tarmac, is certainly not a crash then.... but still more than just an "incident"
Zauber....
BelugaBoy
Wed Jun 06, 2001 10:46 pm
And I think the one that burned down belonged to Sabena to, it was the time that Sabena and Air France were 'partners'.
I think some of the first A340's that Sabena ordered where operated by Air France for a while since Sabena couldn't use them right then. They were still using B747's and DC10's back then.
The plane was carying the Air France livery at that time it was detroyed.
But I can be wrong, maybe somebody else can confirm this.
Wed Jun 06, 2001 11:48 pm
A320-Addict,
The A340-200 which had the landing incident in BRU was out of service for a mere 4-5 months, not over a year as you said. BTW, when fixed, OO-SCW was the first to wear the new livery.
As for the definition of 'crash', I think we mean a total loss with loss of life?
apuneger
Thu Jun 07, 2001 1:33 am
Juul:
I saw it happening, when I worked for Sabena as a student. I was looking out of the employees-cafetaria, when OO-SCW landed.
This definitely was one of the most memorable moments in my 22-year old life.
Ivan
Ivan Coninx - Brussels Aviation Photography
lmml 14/32
Thu Jun 07, 2001 1:37 am
And there was the much publicised Virgin A340 that landed with only the right gear down. What was interesting about that incident was that the check list says that the centre gear has to be manually retracted in such cases as it is not designed to support weight like the outers.
Thu Jun 07, 2001 2:12 am
Apuneger,
Wow! Scary sight, I can imagine! Come to think of it, I saw the aircraft pass over my house that day, minutes before the incident (I live under the approach path for BRU). It was the 12.40 flight from New York, which was the only SN widebody arriving around that time. Only half an hour later I saw the news on the TV, reporting about the incident... scary.
Greetings Big grin
jgardiner
Thu Jun 07, 2001 2:22 am
If the center gear of an A340 is not designed to support weight then what is its purpose?
VC-10
Thu Jun 07, 2001 3:31 am
Jgardiner,
Think about it, the Ctr gear is not designed to take the weight that the main wing gear takes.
jgardiner
Thu Jun 07, 2001 6:05 am
True, the center gear cannot support as much weight as either of the outer gears, but it does help hold the plane up. For that reason, I don't understand why you would want to manually retract it if either of the outer gears failed.
philb
Thu Jun 07, 2001 6:13 am
Jgardiner,
As the VS crew (which included the British Aerobatics champion) demonstrated, it is possible to land the A340 with relatively minimal damage without one main gear.
The reason for retracting the centre gear is that it cannot take the weight and stresses from the side of the aircraft that has lost its main gear and, if left in place, it would shear off at an unpredictable time, causing extra damage and unforseeable consequences to the handling of the aircraft.
VC-10
Thu Jun 07, 2001 6:20 am
I would venture to suggest it would probably go up into the cabin.
The Ctr Gr is only there to take the weight at the upper end of the weight limit. At low weights it's not even on the ground !
jgardiner
Thu Jun 07, 2001 7:15 am
Philb, VC-10
Thanks for the info.
jgardiner
Thu Jun 07, 2001 8:12 am
Philb, VC-10
Thanks for the info. Very helpful.
