TOMASKEMPNER
What´s The Concorde Max. Range?
Mon Jun 11, 2001 8:46 am
I want to know the Concorde´s range.
I think is not that large due to the fact that when BA operated LHR-SIN services they have to stop at BAHREIN.
Could anyone answer me.
flyf15
RE: What´s The Concorde Max. Range?
Mon Jun 11, 2001 8:56 am
With a typical payload, 3550nm.
GDB
Mon Jun 11, 2001 9:06 am
Depending on the usual weight and other factors, with max passengers and baggage - 3,500 NM, (4,030 SM). On the LHR-SIA routes a considerable part of the leg to Bahrain was overland at M0.95, so fuel burn was a lot higher, Bahrain was the best place for the refuelling stop. On the flight from Bahrain to Singapore, the cooler tropical air inproved engine fuel efficiency allowing a range of 3750 NM.
The max. recorded range on a normal passenger service was on 11 September 1984, when G-BOAB flying between Washington and Nice with 54 pax. covered 3,965 NM, (4,565 NM). The flight took 4 hrs and
7 min.
GJR
Mon Jun 11, 2001 10:29 am
Was that the flight where Capt. Warpole nearly ran out of fuel, or was that into LHR. I understand when they landed they were pretty unsure if the a/c would be a "tailsitter" due to the CoG being completely wrong with nothing they could do about it as they did not have enough fuel to pump forward.
Does anyone on the forums know if the range will be effected by the tank mods? will she still be able to fy to Barbados next year?
GDB
Mon Jun 11, 2001 3:30 pm
No, Capt. Walpole made his 'error' three years later on a JFK-LHR charter.
Ground tests on the effects of the liners on the unuseable fuel, plus of course the results of test flights, should tell us if we are OK for BGI.
Most people seem optimistic on this subject.
