cba
CO EWR-HKG Restrictions
Tue Jun 12, 2001 4:29 am
Does the Continental flight from Newark nonstop to Hong Kong have any weight restrictions placed on it? I know that UA's JFK-HKG flight does, but the 744 has less range than the 777-200ER.
pilot21
RE: CO EWR-HKG Restrictions
Tue Jun 12, 2001 5:09 am
Cba
There is a very interesting article about the route in May's (I think it was May's issue) Airways magazine. CO, Boeing and the FAA worked on the planning of the route, including visiting the various alternative landing strips on the route which would used if something went wrong on the flight. However as regards the flying of the route I can't remember it mentioning any restrictions. The only extra provisions made for the flight is that 2 whole flight deck crews are carried, upon entering Russian airspace it has to climb as they use Metres while Canada/USA use Feet and the crew have to be very careful in monitoring the fuel temperature as it is so cold going over the polar cap, that the fuel in the wing tips is actually in danger of freezing!
Check out the article though as it tells you everything about the first flight.
Pilot21
Aircraft I've flown: A300/A310/A320/A321/A330/A340/B727/B732/B733/B734/B735/B738/B741/B742/B744/DC10/MD80/IL62/Bae146/AR
krisair747
Tue Jun 12, 2001 5:12 am
Yes... When the flight doesn't get its perferred flight plan..more fuel is added and more passengers come off. As of late though, there hasn't been to many weight and balence restrictions.
Open your heart and push the limits
SAS_A330-300
Tue Jun 12, 2001 6:00 am
Correction
Cba and Pilot21
The article is in June's issue.
Simon Larsson
You know the gear is up when it takes full power to taxi
