Desmidus
777 And A340 Fuel Economy
Mon Jun 25, 2001 6:45 am
I implore you, I beseech you, do not turn this into anything but a number-backed discussion.
I am curious about the fuel economy numbers concerning the 777 and A340. Much is said about which plane is better, which plane is worse, but I've heard little in the way of which one is more economical of the two. As I understand it, the A340 is more effecient on long routes, while the 777 is more efficient on shorter routes? What, if any, are the range numbers where the A340 becomes more effecient?
RE: 777 And A340 Fuel Economy
Mon Jun 25, 2001 7:36 am
This is a shot in the dark, but If my understanding is correct, Boeing aircraft have always been more fuel thirsty than their Airbus counterparts(except the 767 series). So im guessing the 777 will be more expensive to operate than the 346, fuel wise anyway.
Mon Jun 25, 2001 7:50 am
Desmidus,
That will do no good, it will anyway turn into A vs. B.
CYKA,
LOL
And where would you find this info?
Mon Jun 25, 2001 8:06 am
I didn't, like I said it's pure speculation.
fanoftristars
Mon Jun 25, 2001 9:05 am
Dismidus:
Type this link into your web browser and read the section on range and fuel economy:
http://www.boeing.com/news/feature/777x-launch/254504_777x.pdf
Then report back your findings.
"FLY DELTA JETS"
YoungDon
Mon Jun 25, 2001 9:33 am
Fanoftristars,
Do you truly think that something from Boeing could be accurate to a degree that it could be considered credible. Please. They listed the cruising speed of the A340-600 as Mach .82, when it is really Mach .84 erasing that so called 20 minute advantage. Airbus would do the same thing to Boeing if it had the chance.
Spaceman
Mon Jun 25, 2001 10:21 am
On the Boeing report it also mentions that the 772ER can fly further than A340-600. I suspect it probably not true since the A340-600 carries more fuel than 772ER. It carries about 20,000 liters more fuel.
RE: Spaceman
Mon Jun 25, 2001 10:30 am
The 772ER does have more range than the A346, and it carries 20,000 liters less fuel, so I guess it is more efficient than the A346.
772ER: 7,700 nm
A346: 7,500 nm
Sources:
Boeing and Airbus
Spaceman
RE: Spaceman
Mon Jun 25, 2001 10:36 am
A340-600 has alot more Maximum takeoff weights than 772ER too. It means if A346 flys with less weight than the max it will fly further than 7500nm! 772ER flys further beacuse it is lighter and cand not carry as much as A346.
RE: Spaceman
Mon Jun 25, 2001 10:40 am
You're correct. But the A346 doesn't even compete with the 772. It is fighting the 773ER.
dynkrisolo
Mon Jun 25, 2001 10:47 am
There are so many models, which ones do you want to compare?
One question I can answer without guessing:
The B772ER burns more fuel per trip than the A343, but...
the B772ER has more seating capacity. On a per seat basis, it all depends on how airlines configure their planes. My guess is, with a comparable configuration, they are pretty close but the A343 might have a slight edge.
For the A346 and the B773ER, the situation is likely to be reversed.
The B773ER will likely burn less fuel per trip than the A346, but the A346, according to Airbus, will have more seating capacity. I would say on a comparable configuration, the B773ER should have the advantage.
Fuel consumption is only one constituent of the DOC. Burning for fuel, even on a per-seat basis, does not automactically make the aircraft less efficient. You really want to look at the DOC.
Hamlet69
Mon Jun 25, 2001 12:06 pm
Desmidus,
Unfortunately, the numbers you seek are very hard for the general public to obtain, because they deal direct with the financial and technical operations of the airlines. What we can come up with is a very rough & crude nm/g ratio. However, as these are coming direct from the manufacturers (who are known to embellish) and do not take into consideration payloads, they are obviously not the whole story. (BTW - I've only bothered to list the airplanes that directly compete)
777-200ER
45,220 g
7,700 nm
= 0.170 nm/g
A340-300
39,280 g
7,300 nm
= 0.186 nm/g
777-200LR
51,590 g
8,820 nm
= 0.171 nm/g
A340-500
56,750g
8,500 nm
= 0.150 nm/g
777-300ER
47,890 g
7,250 nm
= 0.151 nm/g
A340-600
51,480 g
7,500 nm
= 0.146 nm/g
Like I said before, these numbers are very basic. However, what they appear to show is that the Airbus, as suspected, is more fuel efficient in the current generation. But as the newer generation comes out, we see that they become far less efficient, allowing the Boeing's, who do not lose as much (the -200LR actual goes up a point), to better the A340's efficiency numbers. But again, this does not take into account payloads, which I have yet to see some firm numbers on.
Hamlet69
Honor the warriors, not the war.
B747-437B
Mon Jun 25, 2001 12:15 pm
Hamlet - those numbers are all well and good, but you need to factor in the operational payloads at those fuel burn rates for that to mean anything. I did a full breakdown of the 744, 772 and 773 last month and it took me a couple hours on each. Don't bust your head because the kids here don't understand it anyway!  Smile
"The A340-300 may boast a long range, but the A340 is underpowered" -- Robert Milton, CEO - Air Canada
YoungDon
Mon Jun 25, 2001 12:27 pm
I really don't appreciate your arrogance B747-437B. Some here may not understand it, but you don't have to act pompous about it. Have a good day.
B747-437B
Mon Jun 25, 2001 12:31 pm
YoungDon - you may call it arrogance, but I find it a complete drag to spend 6 hrs calculating efficiency of widebodies and then be told by some pimply faced kid from Hong Kong that my numbers mean nothing because the 777 livery looks better. Call me once bitten, twice shy.
Hamlet69
Mon Jun 25, 2001 1:57 pm
B747-437B,
I agree. Like I stated earlier, without the max. payloads, or the operational payloads tied into those stats, they don't really say much. However, that is the best solution I could find with the information and time I had. Its a basis, one which I hope we can expand on. . .
Hamlet69
Desmidus
I don't like where this is going. B747-437B, I asked for numbers. Hamlet gave me numbers. They were good numbers. I'm grateful that he took the time to do so, just as I am ungrateful for your 'addition' to the topic.
Perhaps less moderation would be needed, as your profile displays, if people did not venture off-topic and into the sticky realm of vague insultes as you are doing right now.
