Sonic99
Widebody Aircraft - The Largest?
Wed Jun 27, 2001 3:43 am
Now this trully is a widebody!!! Is this the largest aircraft now flying? (size and capacity)?
Sonic99
Click for large version
Photo © Lolo
JAL
RE: Widebody Aircraft - The Largest?
Wed Jun 27, 2001 6:38 am
It's huge!!!!!
Is it bigger than the A380?
Work Hard But Play Harder
NWA
Wed Jun 27, 2001 6:41 am
Yes, its the biggest. its an antonv.
23 victor, turn right heading 210, maintain 3000 till established, cleared ILS runwy 24.
IMissPiedmont
Wed Jun 27, 2001 12:08 pm
This is THE An-225. One and only, finally returned to the air after 5 years. Antonov Design Bureau says it has enough parts to build another. This is the largest aircraft in the world. Don't know for sure, but I'd say this is about the size the A380 will be.
Steve  Wow!
The day you stop learning is the day you should die.
Wed Jun 27, 2001 12:59 pm
The A380 is only about the size of a C5-A Galaxy, An-225 is much bigger than both.
Jkat
Wed Jun 27, 2001 1:01 pm
Is this the only type of this aircraft out there? Wouldn't be suprised.....its huge!
SSTjumbo
Wed Jun 27, 2001 1:02 pm
The An-225 has a larger wing-span and longer fuselage than the A380 and is in a larger size class. The tail's span is greater than a 737's wing span!
I don't know, so this is my signature.
megatop
Wed Jun 27, 2001 3:34 pm
The AN225 is, and still will be the largest aircraft, even when we see the A380. The A380 will fit en a 80 x 80 m box. The wingspann of the AN225 is about 88 m.
Regarding MTOW the largest projekted A380 is about 583.000 kg, but the AN225 has a MTOW of 600.000 kg. As for the C5, AN124 and the B747 the MTOW is "only" arround 400.000 kg.
The payload of the AN225 is 250.000 kg. Thats more than a emty Boeing 747.
So the AN225 is, and still will be HUGE.
Megatop
747-600X
Wed Jun 27, 2001 3:37 pm
Agreed on all counts. It's the biggest. Here's my thing though: I was told on this here forum that all AN-225s were scrapped, did they build this one new or just not scrap it in the first place? I was really shocked to see it still up and about. What an awesome machine!!!
b767-400er
Wed Jun 27, 2001 4:03 pm
747-600X:
All? There is only one!!! Someone must be drunk......
Tony,
B767-400er
An-225
Wed Jun 27, 2001 4:28 pm
Yeah, it's the biggest, and it's the only one - they'll put them to serial production soon.
Money does not bring you happiness. But it's better to cry in your own private limo than on a cold bus stop.
SPRINGBOK
Wed Jun 27, 2001 9:02 pm
I think so, its an Antonov 225, its awesome!!!
SSTjumbo
Fri Jun 29, 2001 6:37 am
Not for long! check out http://www.lmasc.com/ama/freighter.htm
-Anyone have more info on this?
757man
Fri Jun 29, 2001 6:53 am
The An-225 spent most of the 1990's in storage, with a second example partially constructed. I know nothing of what happened to the incomplete second airframe, I assume it will be finished off now that type will go into production.
Correct me if I'm wrong here, but I thought the largest aircraft in the world would read something like:
1. An-225
2. An-124 Ruslan
3. Lockheed C-5 Galaxy
4. Boeing 747-400
5. Boeing 747 100/200/300
I assume after this five, the next largest types would be something like the 777, A340, A330 and the trijets (MD-11, DC-10, L-1011). Does anyone know which would be the largest out of the aircraft I've just mentioned?
Obviously the list will change when the A380 makes it's maiden flight.
RIX
Sat Jun 30, 2001 3:08 am
AFAIK, Lockheed C-5 Galaxy is still slightly bigger (at least, longer) than An124, but with less payload.
fritzi
Sat Jun 30, 2001 3:21 am
Its the largest aircraft ever without a doubt!
