gsoflyer
717 Vs Dc9
Fri Jun 29, 2001 11:48 am
How can you tell the difference on site between a 717 and DC9?
RE: 717 Vs Dc9
Fri Jun 29, 2001 11:50 am
The engines
N863DA
RE: 717 Vs Dc9
Fri Jun 29, 2001 11:52 am
DC-9 = pointy tailcone
717 = square tailcone (like the MD-90)
The engines are also distinct; the 717 has clean-cut engines with no visible reverser buckets on the ends. (One piece cowling). The DC-9 has much longer, thinner, engines with the hinges for the reverser buckets clearly visible.
FLY DELTA JETS and sail UNITED STATES LINES
N 8 6 3 D A
RE: 717 Vs Dc9
The tail-fin on the 717 extends further up from the horizontal stabilizer.
Early Air
RE: 717 Vs Dc9
Fri Jun 29, 2001 12:07 pm
The 717 had much bulkier and more modern looking engines. Notice in the photos below.
Here is a DC-9
Click for large version
Photo © Felix Sieder
Here is a 717
Photo © Frank Schaefer
Rgds,
Early Air
Udo
RE: 717 Vs Dc9
Fri Jun 29, 2001 5:31 pm
I you see a DC-9 that is taking off without any noise then you can be sure it's a B717...
Udo
Me & You & a Plane Named Blue...
rapo
RE: 717 Vs Dc9
Fri Jun 29, 2001 8:19 pm
I heard from a pilot friend of mine that the 717 is quite the rocket.
RE: 717 Vs Dc9
Fri Jun 29, 2001 8:31 pm
It is quite a rocket. But it is a QUIET Rocket. When I flew on that baby (717), she was so quiet, I could talk to the guy 5 rows ahead of me without yelling. On a DC9, You have to SCREAM just to talk to your neighbor. When he said it is quite a rocket, he meant for speed. She sure does go fast. Those Engines have the quietest thrust reversers I have ever heard. BTW -- in a few years, the thrust reversers will be visible due to all of the oil that collects on the nacelle. It will outline the Bucket Shells. But right now, the BR715 (which is very overpowering the OVERPOWERED 717) are the cleanest engines available
DC9 engine -- 14,000 lbs of thrust each -- 57 ton A/C
717 engine -- 18,500 lbs of thrust each -- 57 ton A/C
The 717 is 4,500 pounds more overpowered. When you takeoff, you sure can feel that extra oomph, It pushes you back in your seat as if the F/A SLAMMED you down.
I sure do love the 717
Now, If you have anymore questions about the 717, Just ask your buddies JOSH & STEVE... They'd be glad to answer any of your questions.
gsoflyer
RE: 717 Vs Dc9
Fri Jun 29, 2001 9:04 pm
OK, now I will have to pay more attention. I have flown the NW DC9s are those things are just LOUD. Does Airtran have DC9s also or just 717s?
travatl
RE: 717 Vs Dc9
Sat Jun 30, 2001 2:36 am
AirTran currently operates 34 DC9s and 22 717s, and soon to be gone, 4 737-200s.
AirTran DC9:
Photo © Richard Silagi
AirTran 717:
Photo © Joe Pries
AirTran 737:
Photo © Chris Liao
Travis
RE: 717 Vs Dc9
Sat Jun 30, 2001 2:55 am
717's are awesome. I agree with Critter592, you can feel that extra power. I flew in two of AirTran's 717's. They are a very good airline by the way.
B747-437B
RE: 717 Vs Dc9
Sat Jun 30, 2001 3:19 am
If you think the 717 is overpowered, try riding the MD90 someday. 28000 lb of thrust for a MTOW of around 170,000lb! Wow!
"The A340-300 may boast a long range, but the A340 is underpowered" -- Robert Milton, CEO - Air Canada
AM744
RE: 717 Vs Dc9
Sat Jun 30, 2001 5:49 am
I agree that the 717 is powerful. I've only seen one, an AirTran taking off from MSP and was amazed by its climb rate. I like those planes.
