rabenschlag
Has AUA 777 On Order?
Fri Aug 03, 2001 1:24 am
hi there,
it happened that i tried to figure out the best connection from fra to syd next spring and i dropped into austrian airlines website.
there, the flight OS3001 from vienna to sydney is announced to be operated by AUA using B777!!! however, if you look at their fleet as it is presented on their site, theres no B777 at all. have they ordered some of them? if yes, what will happen to their A340's? same thing as with SIA?
regards, r.
N80NA
RE: Has AUA 777 On Order?
Fri Aug 03, 2001 1:30 am
this flight operates as a code-share with LAUDA AIR stopping in Kuala Lumpur
OS 561 F VIEKUL 777 11:25
NON-SMOKING
KULSYD 777 7:45
NON-SMOKING
OPERATED BY LAUDA AIR LUFTFAHRT AG
ARRIVES SYD TERMINAL I
rabenschlag
Fri Aug 03, 2001 1:39 am
BUT
on their site its announced as OPERATED BY AUSTRIAN!!!
are they wrong? try it: http://www.aua.com
N80NA
Fri Aug 03, 2001 1:48 am
this is from an APOLLO RESERVATION display :
FR 10AUG VIE / SYD Š 8:00 HR
NG 1 T 12JUN-25SEP VIESYD 1045A 315PŠ 777 1
NG 1 S 12JUN-25SEP VIESYD 1045A 315PŠ 777 1
OS 561 S T T 25MAR-04OCT VIESYD 1045A 315PŠ 777 *1
NG 1 T 14JUN-30SEP VIESYD 1045A 315PŠ 777 1
NO MORE LATER FLIGHTS 10AUG
the asterik after the 777 on line 3 signals it's a code share flt !!
also,
just went into the Austrian web-site,
entered VIE SYD 9AUG and if you hit the "i" at the end of the segment,
it will display flt information and towards the bottom you will see
AIRCRAFT TYPE
CARRIER
and
OPERATED BY
and it does state LAUDA AIR as the operator !!! :+)
Fri Aug 03, 2001 2:19 am
I think all of the AUA group now operates under the brand AUSTRIAN.
That might be it.
odie
It's On Lauda Air..
Fri Aug 03, 2001 2:58 am
No, Austrian Airlines did not order B777. The B777 was operated By Lauda Air. But from the Winter 2001/2002 schedules onwards, there will be no more Lauda Air code on its flight. All flight will be under the Austrian Airline Group, i.e., all flight codes will begin with OS, but the aircraft might not be that of Austrian Airlines'. Therefore, you have OS 3001 / OS 3002 for the VIE-KUL-SYD v.v. flight.
Lauda Air operates 3 times weekly from Vienna to Sydney via Kuala Lumpur (4 times weekly from mid-January onwards) and twice weekly from Vienna to Melbourne via Kuala Lumpur.
If you are flying from FRA, I think the airlines to fly with if you want better connections are Asian airlines such as MAS, SIA, Thai and Cathay. They offer frequent flights to Australia as well as from FRA. Lauda Air is not too bad if you don't mind transiting in KUL at weird hours.
Regards.
