Eduardo Lepe
What's The Airport With Most Runways In The World?
Sat May 08, 2004 7:33 am
Hy:
I was checking Jeppesen and A.net and I found a nice question to make you guys:
What is the airport with the most number of runways all over the world?
Give you a try to guess that airport...
 Smokin cool
Best Regards!!! Eduardo Lepe.
Horus
RE: What's The Airport With Most Runways In The Wo
Sat May 08, 2004 7:34 am
I think its AMS with 7 or 8
EGYPT: A 7,000 Year Old Civilisation
Sabena332
Sat May 08, 2004 7:36 am
DFW also has a few.
Patrick
PHLapproach
Sat May 08, 2004 8:16 am
I always thought it was ORD with 6.
Bobs89irocz
Sat May 08, 2004 8:36 am
ORD-6
DFW- 7
I would say DFW has the most if not tied with the most.
13L 17L 17C 17R 18L 18R 13R are the runways if your looking at the airport to the south.
[Edited 2004-05-08 02:01:59]
N79969
Sat May 08, 2004 8:42 am
My guess would be Denver.
InnocuousFox
Sat May 08, 2004 10:02 am
Denver only has 6.
We just covered this. (Gee it was a simple search)
[Edited 2004-05-08 03:04:00]
Dave Mark - Intrinsic Algorithm - Reducing the world to mathematical equations!
Eduardo Lepe
Sat May 08, 2004 10:47 am
Actually AMS has 5 Runways ORD has 6 and DFW has 7
DFW is the airport with the most number of Runways  Smile/happy/getting dizzy
Olympus69
Sat May 08, 2004 11:00 am
Probably the same as it was a week ago - the last time this question was asked.
dtwclipper
Sat May 08, 2004 11:19 am
DTW also has 6 since 2001
Compare New York Air, the Airline that works for your Business
TexAussie
Sat May 08, 2004 11:56 am
Yes, it's DFW with 7... and all can be operated simultaneously. When the wind is blowing from the south, from Highway 114 you can actually see 4 aircraft on direct approaches -- one to 13R and three parallel landings on 18R, 17C and 17L. If you can see far enough, over to 13L you may be able to see one on a tight turn coming in (so as not to cross paths with the three big runways' inbound traffic). I have come into 13L in a 767-300 many times from ATL and you make a soaring tight, low base turn over Las Colinas. Great views. 18L and 17R are used for departures.
Of course, when the wind in northerly, the reciprocal headings are used. The inside runways are always, with few exceptions, for departures and the outside runways are for arrivals (diagonals are mixed use). An aircraft who calls a requirement for 17R/35L to land can get it... but they'll be waiting a long time unless it is an emergency or planned well in advance. A pilot came on the PA one time, giving the passengers info on DFW, one time and said the planes are sequenced and handled in from 100 miles out (not sure if that is standard, but it sounds like a long way out to be sequencing).
It is neat to see the lights lined up for miles in the sky at night. On a clear evening, from Keller or Southlake Texas, it looks a multi-lane highway extending out into space. I would love a night photo of that!
The diagonals (13s) are mixed dep/arr. I have used 31L on a BA 777ER (maiden 777 flight from DFW years ago) and we used 31L... this "short" runway at DFW is 9,300 ft.
17R/35L is the long runway, which the Concorde used with Braniff and then BA.
From the DFW web site:
How large is DFW Airport?
The Airport covers more than 29.8 square miles; real property consists of 18,076 acres (7,318 hectares). The Airport is situated in the cities of Euless, Grapevine, Irving, and Coppell. DFW Airport is the second largest in the United States in terms of land mass and third largest in the world.
How many runways does DFW Airport have?
DFW has seven runways, including five north-south parallel runways and two diagonal runways:
Runway 17L/35R 8,500 x 150 feet
Runway 17C/35C 11,400 x 150 feet
Runway 17R/35L 13,400 x 200 feet
Runway 18L/36R 11,400 x 200 feet
Runway 18R/36L 11,400 x 150 feet
Runway 13L/31R 9,000 x 200 feet
Runway 13R/31L 9,300 x 150 feet
InnocuousFox
Sat May 08, 2004 11:59 am
(or... just click on the link provided and get almost all of that information from the LAST time we went over this)
AirAmericaC46
Sat May 08, 2004 1:28 pm
Denver will have 12 runways when the actual blueprint materializes. I'm not sure if they will pursue the expansion as international flights just come in trickles.
jwenting
Sat May 08, 2004 1:48 pm
Schiphol has 6 runways. Not 5, not 7 or 8, 6  Smile
04-22
06-24
09-27
01L-36R
01C-36C
01R-36L
There ARE early plans to put in another 06-24, but if that happens the 09-27, 04-22 and 01R-36L will almost certainly be closed to make room for a 2nd terminal.
I wish I were flying
Eduardo Lepe
Sat May 08, 2004 2:04 pm
Jwenting:
When did the Netherland government constructed the runway 01C-18C and where is the runway, I am searching for a diagram with that runway but until now I have not found any. Could you please let me know if you have one?
And well about the plan of a new runway you could make it without problems just it would not be so closer to the terminal and you could connect Runway 01R with the beginning of runway 24X.
I do not see so many problem there, but I certainly do not know AMS, and also the government have to search for any inconvenience and also with the people that lives nearly that zone.
AirAmericaC46:
Denver has a lot of free space to construct new runways, but 12???? Wow!
I do not think Denver needs all that runways, Denver is not as concurrent as some other airports like LAX that has 4 runways or AB) (FRA / FRF / EDDF), Germany">FRA that has 3 and you can not make simultaneous operations, and if they do so, they would have to construct also new terminals, and also a internal Metro like ORD's.
But anyway, if MEX can subside with 2 runways anything else is possible  Nuts
N276AASTT
Sat May 08, 2004 4:02 pm
Speaking of DFW and it's 7 runways. I remember reading that the DFW Airport Board was in negotiations/talks with the neighboring city of Grapevine for permission to build another, 8th runway. Does anyone here know of the outcome of it all, or is it still going on?
Dejale Caer tu el Peso! YOMO
deltaffindfw
Sat May 08, 2004 4:12 pm
"Denver will have 12 runways when the actual blueprint materializes"
Can I laugh any louder!!! Hello, let's wake up and see reality!!!! What blueprints say mean nothing about what's going to happen anytime. DFWs "blueprint" was to have 13 terminals - do you think that will happen?? Esp. given that the airport has been around for 30 years, still continues to grow, and has the most runways of any airport.
It's so ironic now to be in DEN and see the signs that say "Gates 1 - 49" and "Gates 50 - 99" in the Concourses when there aren't even close to that many gates there. Wishful thinking....
Bobs89irocz
Wed May 12, 2004 1:00 pm
TexAssie- I grew up in Keller, all the nights i spent out there camping or doing whatever me and my buddys would always look up into the sky and admire the HW in the sky around DFW. Most of my friends are now either in pilot training or getting there A & P. Most of our parents are employed with the airlines at DFW/AFW.
BTW: I was there to see the first BA 777 come into DFW. Where you on that flight? Since you seem to know your stuff about this area i have a weird question. About 10 years ago did you know anything about BA sending a TU-154 to DFW. When i was going 1709 one day as a kid i could have swore i saw one taking off to the north.
IL76
Thu May 13, 2004 8:22 pm
Regarding AMS, the correct naming of the runways is:
04-22
06-24
09-27
18L-36R
18C-36C
18R-36L
Users browsing this forum: masgniw, MaxTrimm and 1 guest
