trickijedi
Airport You Transit Through The Most
Sun Sep 12, 2004 9:29 am
Being a UA flyer, I often find myself most commonly waiting for boarding times at SFO and NRT while in transit.
Where do you find yourself transiting through the most?
Its better to be on the ground wishing you were in the air than be in the air wishing you were on the ground. Fly safe!
Aeroflot777
RE: Airport You Transit Through The Most
Sun Sep 12, 2004 9:31 am
Mostly I find myself boarding at either SFO (thats because I live in SF), JFK, and a lot at SVO.
Aeroflot777
PlymSpotter
Sun Sep 12, 2004 9:59 am
I usually transfer through BCN, I prefer it to MAD, the terminal is so much more spacious and well laid out. Not to mention the fact that most of the walls are made from glass, so you can see everything going on airside!
Photo © Marlo Plate - IBERIAN SPOTTERS
Sometimes use BRS too, its smaller but just as modern and great for quick transfers. In five mins you can get off one aircraft and be in line for your next flight. The only downside is that in the departures lounge a special type of glass has been installed to deflect sunlight, which it also makes a good job of inhibiting your view out  Angry
Dan  Smile/happy/getting dizzy
theCoz
Sun Sep 12, 2004 1:13 pm
DFW, PHX, and SDL (Scottsdale, Arizona US)
Cory6188
Sun Sep 12, 2004 1:33 pm
Having EWR as my home airport, I never have to transfer through anywhere. CO has non-stops to almost any city you could want to go to, so it's rarely necessary.
JBLUA320
Sun Sep 12, 2004 2:51 pm
I second what Cory said...
but I guess if I had to choose, it'd be IAH :-P
JBLU
speedbudgie
Sun Sep 12, 2004 4:11 pm
Unfortunately, I have the displeasure of transiting through IAH most often. If I am lucky enough to get flights that arrive into and out of the new terminal, it is not so bad. Otherwise it is usually a mad dash through the airport from one end to the other.
worldoftui
Sun Sep 12, 2004 5:35 pm
I always seem to have the misfortune of getting IAD.
Delta767300ER
Sun Sep 12, 2004 6:24 pm
I always connect through ATL. I actually prefer going thru ATL and sometimes go out of my way to go thru ATL.
-Delta767300ER
levent
Sun Sep 12, 2004 7:59 pm
For me that would be Madrid Barajas (though I also prefer BCN, like PlymSpotter) and Amsterdam Schiphol. I really like AMS, if you have enough time in between you can go through customs and up to the huge terrace. The situation in MAD might change with the new terminals, they used lots of glass there too.
Vimanav
Sun Sep 12, 2004 8:21 pm
Frankfurt - about 5 times a year.
rgds//Vimanav
Sarfaroshi kii tamannaa ab hamaare dil mein hai, Dekhnaa hai zor kitnaa baazu-e-qaatil mein hai
AMS
Sun Sep 12, 2004 8:54 pm
In the Last year it was FRA......and this year it wil be EWR and KIX
AMS
leviticus
Sun Sep 12, 2004 10:18 pm
It's FRA without doubt, I've been to the airport more that 25 times the last 12 months without ever leaving the airport it self.
DAL7e7
Sun Sep 12, 2004 11:34 pm
Being a DL in TLH I mostly use ATL, but on occasion, I'll use DFW or CVG. This year its been mostly CVG, though.
DAL7e7 is wondering... Do pilots take crash courses?
RCS763AV
Mon Sep 13, 2004 12:32 am
I would have to say MIA with AA. Though i havent been there in 2 1/2 years. I now use FLL with AV and DL. I have also transited through FRA, ATL, MEX and CCS.
USairways16BWI
Mon Sep 13, 2004 12:36 am
BWI ( because i live 15min away) and FLL, i go there a few times a year. Others are PHL, CLT and i did ATL once.
WidgetBoi
Mon Sep 13, 2004 1:27 am
ATL
CVG
ORD
DTW
jeremy
flymia
Mon Sep 13, 2004 7:30 am
I almost always dont have to connect fly AA from MIA. But the times I have it was with Delta in ATL or once with AA in DFW.
panam330
Mon Sep 13, 2004 8:52 am
Almost always CLE, obviously with COex/ CO. Although, as of late, I've been flying B6 through JFK an awful lot.
AFC_Ajax00
Mon Sep 13, 2004 9:16 am
Usually at CDG or AMS.
Once you have tasted flight, you will walk the earth with your eyes turned skyward; for there you long to return
COFreqFlyer
Mon Sep 13, 2004 9:35 am
IAH the most.
EWR a close second.
LGW a far third.
The Proud Bird with the Golden Tail
ba97
Mon Sep 13, 2004 9:53 am
Heathrow. Almost 20 times a year. All others are a distant 2nd
there is economy class, business class, first class...then Concorde..pure class
OpsGuy
Mon Sep 13, 2004 2:34 pm
EWR because of CO
JFK next
LGA when the price is right!
Is this the Delta House?
ATLhomeCMH
Tue Sep 14, 2004 2:07 am
CMH. Here's the new tower.
Photo © Stephen Dobbins
That is, currently, my home airport.
"The most terrifying words in the Engligh language are, 'I'm from the government and I'm here to help.'"-Ronald Reagan
dcrusafon
Tue Sep 14, 2004 10:56 pm
Being in PMI (Palma de Mallorca) I use to use BCN or MAD.
sw733
Wed Sep 15, 2004 6:30 am
MDW and MCI because those are the two cities in which I call home
Adam T.
Thu Sep 16, 2004 4:03 am
I live in NC and since I live near Charlotte I usually fly out of CLT.
Adam
767-332ER
Thu Sep 16, 2004 5:29 am
My airports are ATL, MAD, though I prefer BCN like many others in the forum.
Twinjets...if one fails, work the other one twice as hard!!!
PHLBOS
Thu Sep 16, 2004 5:46 am
PHL, mainly because it's my home airport.
"TransEastern! You'll feel like you've never left the ground because we treat you like dirt!" SNL Parady ad circa 1981
AA300B
Thu Sep 16, 2004 9:04 am
MAD on flights to BCN
SJU on flights to the Caribbean
PTY to South America
SCL to Argentina
GYE to South America
E145, E170, E190, A310, A300, A319, A320, A321, A330, A340, A380, 717 727, 737, 747, 757, 767, 777, 77W, 787
navairjax
Thu Sep 16, 2004 1:04 pm
Since I usually fly UA or DL
ORD
IAD
CLT ( from the occasional US codeshare)
ATL
trickijedi
Thu Sep 16, 2004 3:16 pm
Home airports don't count as transit airports guys. Insane
PHLBOS
Fri Sep 17, 2004 2:06 am
That being the case, this year it's a toss-up between BOS and PVD (FL & WN).
Last year, it was a 3-way tie between DTW, TOL & BOS (FL & NW).
DeltaRules
Mon Sep 20, 2004 8:38 am
ATL, PHL & CLT would be my top 3.
DeltaRules
airbus3801
Mon Sep 20, 2004 12:44 pm
PHX Sky Harbor Intl. I live in PHX so obviously that is the one but it is still my favorite name and airport in the USA, outside the USA, I tend to like the name Changi for some reason.....
LH423
Mon Sep 20, 2004 1:48 pm
As Trickijedi said, home/destination airports don't count. The definition of a transit airport is one where a passenger arrives and departs within a given period of time, usually within 24 hours.
For me, PHL or CLT have to rank as number 1 (probably PHL).
LH423
« On ne voit bien qu'avec le cœur. L'essentiel est invisible pour les yeux » Antoine de Saint-Exupéry
kilavoud
Mon Sep 20, 2004 5:24 pm
When flying Switzerland-southern India-Switzerland :
In 2004 : 4 X FRA (LH) and 8 X SIN (SQ)
Now : every month RUD or JED (SV)
Kilavoud.
Convair990
Mon Sep 20, 2004 10:54 pm
The last few years I have gone through DTW more often than any other hub since I'm a NW frequent flyer (and can't beat the new MacNamara terminal as well)
The University of Georgia Bulldogs are girlie men!!
soups
Tue Sep 21, 2004 1:37 am
BEY on my way to ACC
AMS on my way to BEY and ACC
Next destinations, Suarabaya, beirut, paris, Accra
LHMark
Wed Sep 22, 2004 1:40 am
I've done most of my transiting through JFK, with FRA second and ORD third.
"Sympathy is something that shouldn't be bestowed on the Yankees. Apparently it angers them." - Bob Feller
MADtoCAE
Wed Sep 22, 2004 1:58 am
Mine are:
Madrid-Barajas
Atlanta
Columbia Metropolitan Airport,South Carolina(10000 people on A.net and I haven't found any A.net living there yet  Wow! )
Operator!!! Give me the number for 911!!
UA777lover
Wed Sep 29, 2004 6:56 pm
The airports I transit through the most are SFO, ORD, DEN, YYC and (shudder) YQR
ArmitageShanks
Wed Sep 29, 2004 11:46 pm
That would be ATL for me, followed by JFK.
CXA330300
Thu Sep 30, 2004 4:28 am
My home airport is JFK, but I nearly always go through LHR- I've transferred in every single terminal 3+ times.
Home airport now: JFK
RKDFlier
Sat Oct 09, 2004 5:34 pm
BOS. only destination out of RKD.
I never profesed to be perfict
Users browsing this forum: MANMatthew and 4 guests
