SHUPirate1
What Would You Do If You Were AA's CEO?
Sat Jan 29, 2005 4:43 am
In another thread, http://www.airliners.net/discussions/general_aviation/read.main/1929119/, the joke came up that I was going to be named CEO of American Airlines (please note that the rumor is entirely false). However, I did come up with a business plan for the airline, and was asking for evaluation, as well as your own ideas.
Short-term plans:
-Continue and accelerate the simplification of aircraft into hubs (ie. no 738's at ORD, no M80's at MIA)
-Put MRTC back into all aircraft, at 35 inches on the 777's, 767's, 738's, and M80's, and 33 inches on the AB6's and 757's
-Scale down ORD, to a more O&D focused airport, moving as much connecting traffic as possible to STL, as that 777 going to Heathrow should not be delayed at ORD so somebody can fly from Dubuque to Huntsville, through O'Hare
-Attempt to improve employee morale in any reasonable way possible, ideally leading to the decertification of the unions, and hopefully removing certain scope clauses (perhaps imbedded in the terms of the contract)
-Move American Connection out of STL, making all non-mainline flying American Eagle
-Move all ER3 and ERD flying out of LGA and BOS, and all ERD and ER4 flying out of ORD, in the meantime acquiring more CR7's that would make the aircraft the smallest aircraft flown at ORD and the ER4 the smallest at LGA (the slot rules prevent use of larger aircraft for regional flights) and BOS
-Acquire the Saabs from Chicago Express, primarily for use at STL
-Place an order for 7E7-3's, to create a long-range plan to remove the AB6's from the fleet, for commonality reasons
-Find other ways to improve unit revenue, ideally as little as possible at the expense of unit cost, and streamline operations
-Provide reasonable compensation (ie. hotels, meals) for all inconvenienced passengers, for whatever reason
Long-term plans:
-Add the regional gates back into the JFK project
-Build a new terminal at BOS, with FIS facilities, and convert Boston and New York-Kennedy into the major transatlantic gateways
-Build a new terminal at SJC, with FIS facilities, and turn SJC into the Pacific hub
-Purchase 7E7-8's, to expand and eventually replace the 767's to Europe and South America, and to expand in Asia
-Work with Boeing for a short-range, high-cycle aircraft to eventually replace the MD-80
-Have Executive Air purchase the Q-400 turboprop to eventually replace the ATR-72 on the Caribbean routes from Miami and San Juan
Burma's constitutional referendum options: A. Yes, B. Go to Insein Prison!
AAgent
RE: What Would You Do If You Were AA's CEO?
Sat Jan 29, 2005 4:49 am
It sounds like you've got some really good ideas but the one I have the most passion for is the restoration of MRTC. The More Room Throughout Coach configuration was an American Airlines feature that is sorely missed by many travelers.
AAgent
War Eagle!
AeroWesty
Sat Jan 29, 2005 4:50 am
A lot of us west coast flyers are tired of AA playing peek-a-boo at SJC. DL did a Pacific hub up the coast here at PDX and pulled an AA after a few years. It takes committment, committment, committment, and dependability that the flights will be there to gain the patronage of the passengers and take up on the idea of an SJC hub again.
Just my 2¢.  Smile
Cheers.
International Homo of Mystery
FLY2LIM
Sat Jan 29, 2005 4:53 am
This is what I wrote as a reply to the other thread. I think your plan is nice, sounds great, has good "spirit", but I believe it would drive the company to the ground as it's very expensive, or so it appears. I am an exclusive AA flyer and I have no business background. However, I do notice that you would re-establish all the strategies that they have eliminated as a cost cutting measure. So, using simple logic, your plan wouldn't make sense. My reply follows:
After seeing SHUPirate1's "strategy" for AA, I am starting to think that Arpey is the perfect man for the job. I'm afraid Pirate would finish the job and drive AA straight to liquidation.  Smile
FLY2LIM
Faucett. La primera linea aerea del Peru.
Midway2AirTran
Sat Jan 29, 2005 5:01 am
As a former employee of JI (Midway Airlines). It is my duty to turn down the position to obtain a position to compete against AA!!
[Edited 2005-01-28 21:08:52]
"Life is short, but your delay in ATL is not."
gigneil
Sat Jan 29, 2005 5:02 am
What commonality reasons?
Don't get me wrong, I think the 7E3 is perfect to replace AA's AB6, but I don't follow your reasoning.
N
tommy767
Sat Jan 29, 2005 5:04 am
AA is my favorite airline. I'll give a go about my ideas: OH and these ideas being if AA had more cash to play around with.
Continue to build up MIA
Retrofit the 757s and A300s with new interiors.
Add PTVs to 767s (international runs)
Downsize LGA, add more domestic at JFK in preparation for new terminal.
MRTC? I am not quite sure if AA was smart in doing this or not. I would keep it very "2003" and add it back to 777, 738, MD-80, and 767, and keep A300 and 757 as leisure birds.
Order 10 7E7 for the eventual replacement of the A300.
ADD: Routes
EWR-SJC or EWR-SFO
RDU-LAX
Wishful thinking  Smile
"KEEP CLIMBING" -- DELTA
ushermittwoch
Sat Jan 29, 2005 5:05 am
I would change the livery!
 Smile
Especially if ordering some 787's! The composite materials just don't go well with the "bare" look, IMHO.
Where have all the tri-jets gone...
SHUPirate1
Sat Jan 29, 2005 5:06 am
Gigneil-The AB6 is the only Airbus plane remaining in the fleet. Once those are gone, you have an all-Boeing fleet with the exception of the trillions of MD-80-series aircraft (of course, there are people that will argue that the MD-80's ARE Boeing)
moman
Sat Jan 29, 2005 5:11 am
Shup:
All your goals sound great to me and I support each one, especially this one:
This makes the absolute most sense to me (and not only because I'm a STL supporter). STL has less weather problems, less congestion, and is a simpler airport to navigate.
Where are you going to move American Connection to? What about the small towns in the midwest?
Moman
AA Platinum Member - American Airlines Forever
SHUPirate1
Sat Jan 29, 2005 5:17 am
"Where are you going to move American Connection to? What about the small towns in the midwest?"
That's why I included acquiring the Chicago Express Saabs, because those small towns in the midwest would instead be served with those Saabs. American Connection, and American's contracts with Chautauqua, Corporate, and Trans-States, would simply cease to exist.
ERJ170
Sat Jan 29, 2005 7:04 am
Here's a suggestion...
Upgrade the remaining EMB orders to the E170 for Eagle.. there are enough E135, E140, E145... and what about my hometown.. no mention.. also, allow AE to serve some of the small airports around the NC, VA, GA, SC, through my home airport (which shall remain nameless cause I talk about it way too much)..
Don't forget to scale down BNA if you are going to make STL more active.. no need in having all those flights out of BNA is STL is close enough and can handle all the same destinations..
Aiming High and going far..
gigneil
Sat Jan 29, 2005 7:50 am
That doesn't really matter that the brand is the same. The 7E7 will offer zero commonality with any of the rest of their fleet, and add another sparing and maintenance plan.
Then, there's always the argument that a single-source solution is simply bad business. I know I would never run my business that way.
N
aerobalance
Sat Jan 29, 2005 8:05 am
Buy the A380 (we'll even subsidize your purchase).
Signed,
The European Union
"Sing a song, play guitar, make it snappy..."
A350
Sat Jan 29, 2005 9:47 am
SHUPirate1 ,
sorry, but your program paves the way into bankruptcy. If you see the state of the industry, the vast majority of pax want the flight to be:
1) cheap
2) cheap
3) cheap
so, forget about MRTC.
Furthermore, AA simply is not in the position to make big investments, they have to reduce losses first. And it's doubtful if pax will honor new terminals for reasons mentioned above.
787s would well fit into the fleet for sure, but how to pay for? The A300s, finally, are still money-makers, why change?
The biggest fleet issue is the future of the Mad Dogs. The 738s are excellent replacements, but again, where to get the money?
Greetings from Berlin
A350
Users browsing this forum: rhuns and 2 guests
