fjnovak1
Same Flight #s You Have Taken Multiple Times
Sun Feb 13, 2005 3:30 am
What are some of the same route/same flight #s you have taken multiple times in your life??? I was just trying to recount some of mine....what was the routing of the particular aircraft and what segment did you fly??
For myself:
Northwest Airlines 52 SFO-DTW (continued to FRA)
-operated with a 757 and changed to a D10 in DTW
Northwest Airlines 929 DTW-SFO (continued to HNL)
-took this at least 4 times in the early to mid 1990s, operated w/ DC-10
Delta Connection 5213 CVG-DTW
-40 seat ComAir CRJ...Taken twice in the past year...aircraft used same approach into DTW both times
Delta 271 SAV-ATL (continued to SLC)
4:45 departure into ATL was packed 3 different times I took it
Delta 731 ATL-PBI
One time it operated with a very new looking 767-300, other time the 767 was slightly older...both times overhead bins opened upon arrival into PBI
Delta 832 CVG-BDL (inbound from SEA)
Both times with a 767-200...one time they didn't play Delta Horizons which was weird...
Okay maybe this is a dumb thread, but you might have fun with it....
Go Blue!!
OB1504
RE: Same Flight #s You Have Taken Multiple Times
Sun Feb 13, 2005 3:33 am
LP 511/510 MIA-LIM-MIA
6 times, going up to 8 in late March. I think that's the only route I've flown multiple times.
LGAtoIND
Sun Feb 13, 2005 3:34 am
I have taken ATA flight 101 (LGA-IND) about 4 times. It left LGA around 530pm and got into Indy around 730, depending on the time of year. It was first operated by the 738, then the 752, then it went back to the 738. It is now discontinued.
N1120A
Sun Feb 13, 2005 3:37 am
LH 456/457 (LAX-FRA-LAX)
UA 285 (MSY-LAX)
UA 278 (LAX-MSY)
UA 6106 (OXR-LAX)
UA 6110 (LAX-OXR)
I have taken so many WN flights LAX-LAS-LAX and BUR-LAS-LAX, I have no idea the flight numbers
Alitalia744
Sun Feb 13, 2005 3:43 am
DL 1185 (LGA-CVG)
DL 1519 (CVG-LGA)
12 r/t this last year
Some see lines, others see between the lines.
SWALoveField
I have been on so many WN flights 2004-2005 my spreadsheet with flight numbers and tail numbers is HUGE:
Flight 7 DAL-HOU 24 times
Flight 50 HOU-DAL 17 times
Flight 52 HOU-DAL 4 times
Flight 54 HOU-DAL 3 times
I also travel DAL-TUL, DAL-OKC, DAL-MCI (through OKC and TUL-damn Wright Amendment) and DAL-STL (again through OKC and TUL) and DAL-AUS every month. I've lost count of most of those flights.
I would guess 70 flights over a 12 month period on WN, mostly the same flight numbers.
Regards - Robb
9V-SPJ
Sun Feb 13, 2005 4:03 am
SQ30 - 4 x
SQ29 - 4 x
SQ6 - 4 x
SQ5 - 2 x
SQ12 - 1 x
SQ412 - 10x
SQ411 - 10x
SQ421 - 1x
SQ422 - 1x
DL202 - 4x
9V-SPJ
isitsafenow
Sun Feb 13, 2005 4:16 am
In the 60's TWA 92, a 707 MKC-ORD three times
In the 60's NW 215, various Boeing eqt JFK-DTW four times
1970..NW 555 720B CLE-DTW everynight for a week
and NW 316 727-200, DTW-CLE everyday for a week
safe
If two people agree on EVERYTHING, then one isn't necessary.
FLY2LIM
Sun Feb 13, 2005 4:41 am
There is a thread going on here about the longest, continuous route (still haven't mastered posting a link to a thread here) in which I talk about flight 917/918, MIA - LIM - MIA. I have taken that flight approximately 50 times in the last 30 years. I started with Braniff, continued with Eastern, and then AA, all with the same flight number and the same (give or take) departure time of 4:50 p.m. I have flown DC-8, L-1011, A300, 757, 727, 767, as far as I recall.
In order to get to that flight, I've taken the 7 a.m. transcon flight SFO-MIA on all of the above mentioned carriers. The most recent is the MIA-SFO flight that AA operates, flt. 431. I know I've been on that flight at least 12 or so times, maybe more. The eastbound flight has changed flight numbers a few times.
Do I win?
FLY2LIM
Faucett. La primera linea aerea del Peru.
panam330
Sun Feb 13, 2005 4:48 am
COex 2962 SYR-CLE
CO 1071 CLE-MCO
B6 69 SYR-JFK-MCO
DAL767400ER
Sun Feb 13, 2005 4:57 am
DL61/60 HAM-ATL/ATL-HAM, some 8 times
DL125/124 BRU-ATL/ATL-BRU, 5 times
Also, basically always the same flights from ATL to JAX, departing at around 5:30 pm, ca 15 times, but the number always changes.
PanAm747
Sun Feb 13, 2005 5:03 am
From 1984 almost until the very end of AA service to BFL in 1997, the 6:30 PM departure of MD-80 AA flight DFW-BFL was #607. Other flights in/out changed constantly, but 607 stayed the same. And yes, I took this flight many times after connecting from FSM coming to my (former) home airport, BFL.
Pan Am:The World's Most Experienced Airline - P(oor) S(ailor's) A(irline): San Diego's Hometown Airline-Catch Our Smile!
MADtoCAE
Sun Feb 13, 2005 6:42 am
Delta MAD-ATL-CAE
CAE-ATL-MAD
Done more than 10 times.
Operator!!! Give me the number for 911!!
fbgdavidson
Sun Feb 13, 2005 6:50 am
BA116
BA117
BA222
BA223 - now defunct and BA293
BA282
BA283
BA478
BA481
IB1238
IB1248
BA982
BA987
flyingnanook
Sun Feb 13, 2005 10:57 am
I've been scheduled on AS146 oodles of times (almost every time I fly out of the state). It's the last flight of the day FAI-ANC. I say scheduled, because more often than not, it runs late and I get rescheduled on AS140 (which should leave an hour earlier, but usually leaves at the time scheduled for 146)
Semper ubi sub ubi.
aerorobnz
Sun Feb 13, 2005 11:39 am
I have never had a repeat flight number yet, although the most likely candidate will be SQ282.
Flown to 126 Airports in 47 Countries on 80 Operators. Visited 56 Countries and counting. Wanderlust is like Syphilis, once you have the itch it's too late for treatment.
Cory6188
Sun Feb 13, 2005 12:17 pm
I have flown on CO1903 and CO1902 EWR-STT and STT-EWR, respectively, 4 times, soon to be 5 in March. We have a timeshare at the Westin in St. John, and the CO nonstop is by far the easiest way for us to get to STT.
zippyjet
Sun Feb 13, 2005 2:17 pm
From present and then journeying back in the day Big thumbs up
1. FL 486 MIA - BWI, FL 447 BWI-ATL
2. FL 478 and or 462 (now 1762) ATL-BWI This decade
3. National Airlines 103 BWI-MIA late 60's early 70's
4. Eastern Airlines 173 BWI-MIA and always returned on Eastern 172 MIA-BWI.
Would you believe flying on Eastern 172 5 times?
The Eastern BWI-MIA flights in the late 70's and early 80's would be A 300 and L1011 service. Alas, I always flew in the late spring and late summer months (slower time of year to MIA back in the day) so, all my Eastern flights listed above were on 727's with the ecception of one flight on 172 in August of 1970 which was a DC 9.
Photo © John Jauchler
Photo © Robert L. Bradley
Photo © Mick Bajcar
Photo © Don Boyd
Photo © Peter de Groot
I'm Zippyjet & I approve of this message!
ZKSUJ
Sun Feb 13, 2005 5:03 pm
SQ285, SQ286, NZ5073, NZ5071, NZ5077, NZ 478
Cactus739
Mon Feb 14, 2005 12:48 am
Back in the day when I was a much more frequent flyer...some of my regulars were..
WN 117 PHX-LAS (every day for a week)
WN 1293 LAS-PHX (every day too)
WN 463 PHX-HOU
WN 1288 HOU-PHX (I think that was the flight #)
CO 1924 PHX-EWR
CO 1923 EWR-PHX
HP 592 PHX-MCI
You can't fix stupid.... - Ron White
September11
Mon Feb 14, 2005 1:24 am
TW #118 STL-CMH
(afternoon flight)
Airliners.net of the Future
PlymSpotter
Mon Feb 14, 2005 2:46 am
PLH-BRS WOW302 x 4
BRS-PLH WOW307 x 3
LHR-BCN IB x 16
BCN-MAH IB x 16
MAH-BCN IB x 14
BCN-LHR IB x 14
LTN-MAH MON x 8
MAH-LTN MON x 8
Flying my favorite route LHR-BCN-MAH tomorrow Big thumbs up
Dan Smile/happy/getting dizzy
DAL7e7
Mon Feb 14, 2005 2:51 am
Most of the TLH-ATL flights.
DAL7e7 is wondering... Do pilots take crash courses?
jm017
Mon Feb 14, 2005 1:33 pm
Well, my username gives away the answer to this question:
JM017 KIN-JFK (nine times)
JM010 JFK-MBJ-KIN (three times)
JM016 JFK-KIN (four times)
JM040 BWI-MBJ or BWI-MBJ-KIN (six times)
JM041 KIN-MBJ-BWI or MBJ-BWI (seven times)
For the last two flight numbers, sometimes the flights originated or terminated in KIN, sometimes not.
"It's okay to cheat, if you just really don't like to lose."
burnsie28
Mon Feb 14, 2005 2:22 pm
NW 1224 DEN-DTW about 70 times
NW 1225 DTW-DEN about 70 times
NW 1230 COS-MSP about 5 times
NW 1231 MSP-COS about 5 times
Airlinerfreak
Mon Feb 14, 2005 3:32 pm
AA flight 455
AA flight 451
I used to take them both all the time, then they changed the aircraft.....
jfrworld
Tue Feb 15, 2005 5:30 am
WN flt 95 between ELP-PHX has operated since at least 1989 and still does. I myself have flown it at leats a dozen times since then. It used to operate mid-afternoon and now its a late morning flight, but its still around.
NWADC9
Tue Feb 15, 2005 7:15 am
NW1051
NW1753
NW1751
Those are all I can remember...
I convert Jet A and 100LL into noise.
ba97
Tue Feb 15, 2005 10:57 am
Internationally: what else....BA97. For the last 3 years once a month.
there is economy class, business class, first class...then Concorde..pure class
speedbirdegjj
Tue Feb 15, 2005 9:55 pm
To the best of my knowledge BA8034 JER-LGW the dreaded red eye on no less than 108 occasions (a futher 14 on Flybe's similarly timed service to LGW the BE953)
JGPH1A
Wed Feb 23, 2005 11:38 pm
DL82 JFK NCE 3x
BA343 NCE LHR 5x
BA348 LHR NCE 5x
BA345 NCE LHR 6x
SA235 LHR JNB 6x
BA352 LHR NCE 7x
Young and beautiful and thin and gorgeous AND BANNED ! Cya at airspaceonline.com, losers
WidgetBoi
Fri Feb 25, 2005 7:41 am
I've flown on Delta 581 (LaGuardia to Atlanta) at least a dozen times (6 L1011s, 5 763s and 1 752).
I'm sure there are more, but that's the only one I'm positive about.
BA380
Fri Feb 25, 2005 8:20 pm
I have taken various of the flights BA 94X scores of times from LHR-DUS-LHR. Have been on BA 179 LHR-JFK a few times too.
cabin crew: doors to automatic and cross-check...
icarus75
Fri Mar 04, 2005 1:21 am
Back in the 80's :
ORY - PGF at least 30 times on fridays at 0730pm
PGF - ORY at least 30 times on sundays at 0930pm
Sorry I can't remember flight numbers. I can say it was with the defunct Air Inter
CDG - ORD - LAX - ORD - CDG : United Airlines x 4
CDG - STR - CDG : Air France x 6
Flying is amazing!
Eric777
Fri Mar 04, 2005 11:34 pm
The only big repeaters I have are:
AA 655 JFK-STT B757
AA 412 STT-JFK B757
I have done these probably 6 times, probably will add a seventh before summer's end. It has almost always left JFK at 8am and arrived at JFK around 530pm.
Eurohub
Sat Mar 05, 2005 12:21 am
BA1741 BHX-STR on an ER4, always on a Thursday morning! Twice in 2004 and I'm planning at least twice again this year. Oh yes, and I always sit in row 12.
skidmarks
Sat Mar 05, 2005 1:48 am
BA4321 IOM-LHR/IOM-LGW
BA4328 LHR-IOM/LGW-IOM
BA4401 IOM-MAN
BA4410 MAN-IOM
Only ones I use regularly, being as I work for BACX and this is the only way to get off the island without paying big bucks or getting a (heaven forbid!!) ferry.
IOM-LHR route changed to LGW after BA stole our slots at LHR - oops, sorry, re-allocated them!
Andy
Growing old is compulsory, growing up is optional
United4everDEN
Sun Mar 06, 2005 3:20 am
Years ago, I took a DL flight from SLC-PDX on a 727. I don't know the flight number but it left at about 830AM, we took it twice . This last summer, we took a UA flight DEN-SEA a few times. Other than that, we really haven't done much more.
Fly2HMO
Sun Mar 06, 2005 4:11 am
AM115,AM114,MX446,MX447 more than 10 times each MEX-HMO. (MX flight no. might be wrong)
buckieboy
Sun Mar 06, 2005 5:47 am
Quite difficult, as I don't record flight #s as I let the frequent flyer cards do this for me:
Recently: the LH727/8 pairing, MUC/PVG gets my vote for the longhaul; every 2 months + since last July and likely to continue to the end of 2005
Others:
BA1691/2 ZRH/MAN/GLA is quite covenient for me: maybe 5 times in last 2 years
LX766/7 BSL/BRU is common with work; less so from now on for myself
Over the years, LHR & LGW to GLA & EDI: many flights, however, at different times of the day to pin down flight #s. Ratio BA to bmi would be 9.5:1, however.
Buckieboy
I'm taking orders from bottles of wine
ANCFlyer
Sun Mar 06, 2005 12:49 pm
A few off the top of my head . . .
AS195
The former US33 (SEA-HNL)
CO1794
CO1
CO2
US1
US1989
LJ45
Sun Mar 06, 2005 6:24 pm
JFK-RSW,JFK-PBI, and MCO-JFK on jetblue nowadays. I fly them about on average maybe 2-3 times a year maybe.
I used to fly to florida regularly on USair back when i was little...can't remember the flight #'s on those trips either.
SignalOne
Sun Mar 06, 2005 8:06 pm
Hi,
The only flight I've taken Multiple times is:
(Returns)
AMM 857C/D air2000-Nottingham East Midlands to Palma de Mallorca-03'
FCA 857C/D First Choice- Nottingham East Midlands to Palma de Mallorca-04'
AMM rebranded to FCA in around Winter 03/04, that's why different flight codes.
Cheers Ryan  airplane
Golf - Bravo Romeo India Foxtrot
vatveng
Sun Mar 06, 2005 9:19 pm
AirTran #901 PHF-ATL, departure time 5:35am, used to be 5:55am. I use this flight nearly every time I fly FL.
KDTWflyer
Mon Mar 07, 2005 6:26 am
NW 257 DTW-PHX x2
NW 32 DTW-LGW x2
NW 68 DTW-AMS x2
Not too impressive lol..
NW B744 B742 B753 B752 A333 A332 A320 A319 DC10 DC9 ARJ CRJ S340
PHLBOS
Wed Mar 09, 2005 6:35 am
FL 510 (PHL-BOS) 717
FL 772 (PHL-BOS) 717
FL 775 (BOS-PHL) 717
FL 341 (BOS-PHL) 717
NW 1783 (PHL-DTW) DC-9
NW 1782 (DTW-PHL) DC-9
NW 1784 (DTW-PHL) DC-9
There's probably a few others but I would have to check through my old ticket stubs or receipts for the flight numbers. Possible repeat flight numbers for:
XJ (DTW-TOL) Saab 340
XJ (TOL-DTW) Saab 340
US Express/TransStates (PIT-TOL) EMB-145
US Express/TransStates (TOL-PIT) EMB-145
WN (PVD-PHL) 737
"TransEastern! You'll feel like you've never left the ground because we treat you like dirt!" SNL Parady ad circa 1981
TWA902fly
Sun Mar 13, 2005 6:26 am
United 363, the last IAD-ORD flight of the day... departure times varied from 9:05PM to 9:50PM
3/6/00 Boeing 757-200 9:50PM
9/18/02 Boeing 737-500 9:15PM
6/19/03 Airbus A320 9:25PM
2/22/04 Airbus A320 9:45PM
4/4/04 Boeing 757-200 9:45PM
7/6/04 Boeing 737-500 9:45PM
United Shuttle 2810 (obviously done flying) 1:30PM SLC-DEN
7/21/01 Boeing 737-300 1:20PM
8/18/01 Boeing 737-500 1:32PM
United 1439 ORD-SLC first morning to SLC
6/24/01 Boeing 727-200 9:15AM
8/12/01 Boeing 727-200 9:05AM
6/23/02 Boeing 737-300 10:05AM
Delta 418 the only Delta redeye out of SLC to ATL
7/11/03 Boeing 757-200 11:50PM
4/18/04 Boeing 737-800 11:55PM
Here's the same flight number, different flights United 565
2/5/99 ORD-EWR Boeing 757-200 4:44PM
1/24/03 ORD-SLC Boeing 737-300 7:35PM
Thats all i could find for now
TWA902
life wasn't worth the balance, or the crumpled paper it was written on
jorge1812
Sun Mar 13, 2005 6:57 am
Flown twice on DE 757 DRS-CFU-DRS and on FR 733 AOC-STN-AOC.
Not more.
Bye, Georg.
DeltaRules
Mon Mar 14, 2005 10:52 am
DL 189 SJU-ATL 3 times...L-1011 all three times
DL 275 ATL-SJU 3 times...same as above.
DeltaRules
sdate747
Tue Mar 15, 2005 2:29 am
I live on UA 917 (FRA - IAD) and her sister UA 932 (IAD - FRA) which is the last direct flight to FRA from Dulles for the day.
Users browsing this forum: Bing [Bot] and 1 guest
