richardnhsv
Runway Lengths At Your Home Airport
Wed Aug 10, 2005 8:16 am
Thought this would be a fun and interesting topic...
Huntsville, AL - HSV
Runway 18R/36L
Dimensions: 12600 x 150 ft. / 3840 x 46 m
Weight limitations:
Single wheel: 90000 lbs
Double wheel: 200000 lbs
Double tandem: 350000 lbs
Dual double tandem: 850000 lbs
Runway 18L/36R
Dimensions: 10006 x 150 ft. / 3050 x 46 m
Weight limitations:
"If you've ever had a filet this good, welcome back." - Ruth Fertel
Longhornmaniac
RE: Runway Lengths At Your Home Airport
Wed Aug 10, 2005 9:04 am
Austin TX-KAUS
Runway 17R/35L-12,248'
Runway 17L/35R-9,000'
Cameron
ZSOFN
Wed Aug 10, 2005 9:11 am
Bristol BRS - EGGD
Runway 9/27 - 6,600ft
Quite short considering we have a daily transatlantic service!
GQfluffy
Wed Aug 10, 2005 9:25 am
I bounce between two airports...here's both-
Helena, MT - HLN
Runway 9/27
Dimensions: 9000 x 150 ft. / 2743 x 46 m
Weight limitations:
Single wheel: 100000 lbs
Double wheel: 160000 lbs
Double tandem: 250000 lbs
Runway 5/23
Dimensions: 4644 x 75 ft. / 1415 x 23 m
Weight limitations:
Single wheel: 21000 lbs
Double wheel: 30000 lbs
Runway 16/34
Dimensions: 2989 x 75 ft. / 911 x 23 m
Weight limitations:
Billings. MT - BIL
Runway 10L/28R
Dimensions: 10518 x 150 ft. / 3206 x 46 m
Weight limitations:
Single wheel: 130000 lbs
Double wheel: 170000 lbs
Double tandem: 285000 lbs
Runway 7/25
Dimensions: 5501 x 75 ft. / 1677 x 23 m
Weight limitations:
Single wheel: 14000 lbs
Runway 10R/28L
Dimensions: 3801 x 75 ft. / 1159 x 23 m
Weight limitations:
Single wheel: 12000 lbs
fluffy
This isn't where I parked my car...
jeffry747
Wed Aug 10, 2005 9:26 am
SDF Louisville
Runway 17L/35R 8,500 ft
Runway 17R/35L 10,000 ft (currently being extended to 12,000 ft)
Runway 11/29 7,200 ft
Photo © Derek Hellmann
In this case Runway 11/29 runs across the airport
C'mon Big B, FLY!
sccutler
Wed Aug 10, 2005 9:28 am
KADS, Addison, Texas.
7,000', and always a welcoming sight to see when coming home.
...three miles from BRONS, clear for the ILS one five approach...
senorcarnival
Wed Aug 10, 2005 9:34 am
SAT San Antonio Int'l Airport
Runway 12R/30L 8502 x 150 ft. / 2591 x 46 m
Runway 12L/30R 5519 x 100 ft. / 1682 x 30 m
Runway 3/21 7505 x 150 ft. / 2288 x 46 m
Oh no, she's getting impatient! Take a stab at it!
777DadandJr
Wed Aug 10, 2005 10:00 am
MDT, Harrisburg Int'l, Middletown, Pa
Elevation: 310 feet
Runway: RW 13/31 ILS; 10,001' L x 200' W
Harrisburg International Airport has been serving Central Pennsylvania for over 100 years. First, in 1898, the Signal Corps of the U.S. Army was stationed here. Then, the first airplanes landed in 1918 at what was then called Olmsted Air Force Base. By the time it was decommissioned in 1969, the base had grown to employ 11,400 civilians. At this point, Harrisburg International Airport began to serve the public, under the ownership of the Commonwealth of Pennsylvania.
Russ
My glass is neither 1/2 empty nor 1/2 full, rather, the glass itself is twice as big as it should be.
kcrwflyer
Wed Aug 10, 2005 10:04 am
CRW
Runway 05/23
Dimension: 6302 x 150 ft / 1920.8 x 45.7 m
Surface: ASPH, Good Condition
Surface Treatment: Saw-cut or plastic Grooved
Weight Limit: Single wheel: 120000 lbs.
Dual wheel: 160000 lbs.
Dual tandem wheel: 260000 lbs.
Runway 15/33
Dimension: 4750 x 150 ft / 1447.8 x 45.7 m
Weight Limit: Single wheel: 30000 lbs.
Dual wheel: 60000 lbs.
RSTD TO 60,000 LBS GWT
jtamu97
Wed Aug 10, 2005 10:07 am
Beaumont, Texas- BPT
Runway 12/30
Dimensions: 6750 x 150 ft. / 2057 x 46 m
Surface: concrete/grooved, in good condition
Weight limitations: Single wheel: 90000 lbs
Double tandem: 230000 lbs
Runway 16/34
Dimensions: 5070 x 150 ft. / 1545 x 46 m
Surface: asphalt/concrete/grooved, in fair condition
RY 16/34 FIRST 4271 FT OF RY 34 GRVD.
Weight limitations: Single wheel: 70000 lbs
Double wheel: 90000 lbs
Double tandem: 145000 lbs
One of the hardest airports to find at night with all the refineries around.
Propeller, we don't need no stinkin propeller
brokenrecord
Wed Aug 10, 2005 10:10 am
ORF - Norfolk International - Norfolk, VA
5L/23R is 9000'
Crosswind 14L/32R is 4876'
6thfreedom
Wed Aug 10, 2005 10:15 am
Melbourne, Australia
North South runway 16/34, 3657 metres in length X 60 width
[Recently extended from 45 m wide to 60 metres for A380]
East West runway 09/27, 2286 metres in length X 45m width
Taxiways 23 metres wide taxiways run the full length of both runways, with high speed runway exits to increase runway efficiency
boeingfan71
Wed Aug 10, 2005 10:19 am
my hometown airport is PGV in greenville, NC and is 150 by about 6,000 feet. Runway 2/20 and is great to see 1000 feet from above.
kaniksu
PSC - Tri-Cities/Pasco
Runway 3L/21R 7,700' x 150'
Runway 12/30 7,700' x 150'
Runway 3R/21L 4,425' x 75'
TPASXM787
Wed Aug 10, 2005 10:27 am
KTPA Tampa International Airport
9/27 6999x150
18R/36L 11002x150
18L/36R 8300x150
My true "home airport"
KCLW Clearwater Air Park
16/34 3500x75
KPIE St. Pete/Clearwater International Airport
4/22 5500x150
9/27 5165x150
17L/35R 8500x150
17R/35L 4000x75
This is the Last Stop.
goCOgo
Wed Aug 10, 2005 10:32 am
Cleveland, OH - CLE
6R/24L - 8,999 ft
6L/24R - 9,000 ft
10/24 - 6017 ft
6C/24C is not currently used, although they might use it during the planned expansion of 6R/24L to 11,250 ft (or so). It is 7096 ft.
All runways are 150 ft wide.
Photo © Gary Chambers
My fellow NE Ohioans can handle BKL and CAK, if they wish. I'm too lazy to look them up.  tired
By the way, should this not be in Polls & Prefs?
"Why you fly is your business, how you fly is ours"
ERJ170
Wed Aug 10, 2005 10:38 am
Raleigh-Durham International Airport
Raleigh-Durham Airport, NC (yes, it is it's own city)
Runway 5L/23R
Dimensions: 10000 x 150 ft. / 3048 x 46 m
Surface: concrete/wired/combed, in good condition
Weight limitations:
Double wheel: 190000 lbs
Double tandem: 355000 lbs
Dual double tandem: 750000 lbs
Runway 5R/23L
Dimensions: 7500 x 150 ft. / 2286 x 46 m
Surface: asphalt/grooved, in good condition
Weight limitations:
Double wheel: 176000 lbs
Double tandem: 335000 lbs
Runway 14/32
Dimensions: 3570 x 100 ft. / 1088 x 30 m
Surface: asphalt, in good condition
Weight limitations:
Double wheel: 54000 lbs
Proposed Runway 5W/23W (estimated construction beginning 2008/2009)
Dimensions: 9500 x 150 ft
Weight limitations:
Aiming High and going far..
jtamu97
Wed Aug 10, 2005 11:12 am
Okay, I am stumped..What is 5W/23W...I only know L, R, C..Is that a new designation?
ERJ170
Wed Aug 10, 2005 11:14 am
5 West/ 23 West.. There is already a Left and Right.. and this runway is going west of 5L/23R..
GQfluffy
Wed Aug 10, 2005 11:16 am
Hey ERJ, I've been in and out of Raliegh more then several times...where in the heck are they gonna put that new runway? does 'W' stand for west??? That's the only place I think they could put it.
jtamu97
Wed Aug 10, 2005 11:19 am
I figured that, but I just have never heard of West being used as a designation for a runway...If another one is added, seems like it should be 5L, 5C, 5R.
[Edited 2005-08-10 04:25:17]
Indy
Wed Aug 10, 2005 11:26 am
Indianapolis International Airport
Runway 5L/23R
Dimensions: 11200 x 150 ft. / 3414 x 46 m
Weight limitations:
Single wheel: 145000 lbs
Double wheel: 300000 lbs
Double tandem: 550000 lbs
Runway edge lights: high intensity
Runway 5R/23L
RYS 05R/23L & 14/32 HAVE 200 FT BLAST PADS BOTH ENDS. RWY 5L/23R HAS 400 FT BLAST PAD BOTH ENDS.
Weight limitations:
Runway 14/32
Dimensions: 7605 x 150 ft. / 2318 x 46 m
HAS 200 FT BLAST FENCE BOTH ENDS.
Weight limitations:
Indy = Indianapolis and not Independence Air
ramerinianair
Wed Aug 10, 2005 11:29 am
Not the closest but the one I fly out of:
KHWV: Brookhaven Calabro Airport; Shirley, NY
Runway 6/24
4,000 feet X 150 feet
ILS 6
Runway 15/33
Now the closest:
KISP: Islip MacArthur Airport; Islip, NY
Runway 6/24
7006 feet X 150 feet
ILS 6 & 24
Runway 15R/33L
5186 feet X 150 feet
Runway 10/28
5034 feet X 150 feet
Runway 15L/33R
3175 feet X 75 feet
H1 & H2 both 50ft. by 50ft.
-Steven
W N = my Worst Nightmare!!!!!
ERJ170
Wed Aug 10, 2005 11:33 am
Quoting Jtamu97 (Reply 20):
FAA.. go figure.. Appendix C Page 2.
It's from 2003 but the most up to date.. It states the FAA recommendation is to extend 5R/23L and add 5W/23W.. and all of this is post-Midway
ERJ170
Wed Aug 10, 2005 11:37 am
How odd.. IND has the exact same runways as RDU.. who would have thunked?
jtamu97
Wed Aug 10, 2005 11:38 am
Hmmm, thanks for that, plus I noticed E, N, and W. Guess they are planning to change them soon OR I missed a big update. That was just the first time I heard of that designation.
Later,
J
ERJ170
Wed Aug 10, 2005 11:47 am
Check this out..
FAA
Seems like CLT (18W/36W) and SEA (16W/34W) will get the first "W" runways..
ZK-NBT
Wed Aug 10, 2005 11:59 am
Auckland
RWY 05R-23L
3635 Metres long x 45 wide (widening beganthis year and will be completed next year to 60 metres for the A380.)
navairjax
Wed Aug 10, 2005 12:04 pm
JAX
Jacksonville International
7/25
10000 x 150
13/31
7701 x 150
Indy
Wed Aug 10, 2005 12:11 pm
Quoting ERJ170 (Reply 24):
What are the odds? At least they aren't the same length. I'd have to be buying a lottery ticket  Smile
STARalliance24
Wed Aug 10, 2005 12:50 pm
Pierre Elliot Trudeau International Airport (YUL)
Montreal Airport
24L/06R - 9600ft
24R/06L - 11 000ft
10/28 - 7000ft
Photo © Youri Thonon - Contrails Aviation Photography
[Edited 2005-08-10 05:51:07]
HT
Wed Aug 10, 2005 2:33 pm
Rather than copying in all the information here, there´s a lot of info on http://www.boeing.com/commercial/noise/list.html
Or more specific http://www.boeing.com/commercial/noise/hannover.html for my home base HAJ .
-HT
floorrunner
Wed Aug 10, 2005 5:21 pm
CMH
Port Columbus International Airport
Columbus Ohio
10R/28L
Dimensions: 10251 x 150 ft. / 3125 x 46 m
10L/28R
Dimensions: 8000 x 150 ft. / 2438 x 46 m
jorge1812
Wed Aug 10, 2005 6:35 pm
http://www.boeing.com/commercial/noise/dresden.html
for my home airport DRS/EDDC - Dresden
Photo © Georg Noack
rwy lenght 2500m - how many feet is this? Arond 7000ft?
Georg.
Aaron747
Wed Aug 10, 2005 7:00 pm
Chubu Centrair International Airport - Nagoya, Japan
NGO/RJGG
Runway 18/36 - 3500 x 60 m (11,782 x 196 feet)
HT
Wed Aug 10, 2005 7:18 pm
Quoting Jorge1812 (Reply 33):
1 ft = 0.305 m
2500 m / 0.305 = 8196.7 ft
 Smile
BTW: For those too lazy to look into Boeings website, the longest rwy at HAJ (09R/25L) is 12467 ft (3800 m) X 148 ft (45 m), making it a shared #3 in runway-lengths in Germany (for commercial airports).
#1: FRA 18 4500 m - I never noticed that this one is THAT long !
#2: 2x MUC (8L & 8R) , 2xFRA (7L & 7R) 4000 m
#3: HAJ 09R, CGN 14L 3800 m
-HT
AC_B777
Wed Aug 10, 2005 7:25 pm
St. John's International Airport-CYYT/YYT
11/29 - 8500ft
16/34 - 7000ft
02/20 - 5025ft
Photo © TriplET
In life, some days you are the bug..... some days you are the windshield!
PMN
Wed Aug 10, 2005 7:52 pm
LBA is my home airport.
Rwy 14/32 2250m
Rwy 09/27 1100m
Photo © Steven Grace
Paul
Edith in his bed, a plane in the rain is humming, the wires in the walls are humming some song - some mysterious song
BNAflyer78
Wed Aug 10, 2005 11:01 pm
BNA - Nashville International
Runway 13/31
Dimensions: 11030 x 150 ft. / 3362 x 46 m
Surface: asphalt/concrete/grooved, in good condition
Weight limitations: Single wheel: 75000 lbs
Double wheel: 175000 lbs
Runway 2C/20C
Dimensions: 8001 x 150 ft. / 2439 x 46 m
Double wheel: 209000 lbs
Runway 2R/20L
Runway 2L/20R
Dimensions: 7703 x 150 ft. / 2348 x 46 m
Weight limitations: Single wheel: 100000 lbs
Double tandem: 390000 lbs
Long live the Widget!
xjramper
Wed Aug 10, 2005 11:15 pm
DUH (My flight school airport):
9/27
5,013 x 50 ft/1528 x 15 m
TOL (commercial service)
7/25
Dimensions: 10600 x 150 ft. / 3231 x 46 m
Weight limitations:
Double wheel: 174000 lbs
Double tandem: 300000 lbs
Dual double tandem: 550000 lbs
16/34
Dimensions: 5599 x 150 ft. / 1707 x 46 m
Surface: asphalt/grooved, in fair condition
Weight limitations:
And for good measure, the original Toledo airport(no commercial service):
TDZ
14/32
Dimensions: 5830 x 100 ft. / 1777 x 30 m
Weight limitations:
Single wheel: 63000 lbs
Double wheel: 85000 lbs
4/22
Dimensions: 3664 x 150 ft. / 1117 x 46 m
Surface: asphalt, in fair condition
Weight limitations:
XJR
Look ma' no hands!
MattRB
Wed Aug 10, 2005 11:53 pm
YKZ (flight school)
Photo © Angus Wighton
15/33: 3902x100
03/21: 2693x80
NC3 (local GA airport)
15/33: 3500x75
08/26: 2500x75
YYZ (local commercial)
05/23: 11120
06L/24R: 9697
06R/24L: 9000
15L/33R: 11050
15R/33L: 9088
Aviation is proof that given, the will, we have the capacity to achieve the impossible.
carmenlu15
Wed Aug 10, 2005 11:57 pm
La Aurora International Airport, Guatemala City (GUA/MGGT)
Runway 01/19 - 9800 ft
Photo © Thomas D. Mayes, Jr.
Since the airport is inside the city, there is no room for expansion.  Sad
Don't expect to see me around that much (if at all) -- the contact link should still work, though.
IBERIA747
Thu Aug 11, 2005 12:50 am
Madrid Barajas Airport. Madrid, Spain (LEMD/MAD)
18R-36L : 14,563 ft (4,440 m).
15R-33L : 13,484 ft (4,111 m)
18L-36R : 11,500 ft (3,500 m)
15L-33R : 11,500 ft (3,500 m)
Photo © Pedro Peña
[Edited 2005-08-10 17:51:48]
¡¡VIVA ESPAÑA!!
dragon-wings
Thu Aug 11, 2005 5:13 am
Islip MacArthur Airport (ISP/KISP)
Runway 6/24 7,006 ft. Surface: asphalt/grooved, in fair condition
Runway 15R/33L 5,186 ft. Surface: asphalt/grooved, in good condition
Runway 15L/33R 3,175 ft. Surface: asphalt, in good condition
Runway 10/28 5,034 ft. Surface: asphalt, in fair condition
Don't give up don't ever give up - Jim Valvano
WA727
Thu Aug 11, 2005 6:12 am
PHX has 3 parallel runways, but are two designated 7/25 and the other 8/26.
here's the link http://204.108.4.16/d-tpp/0508/00322AD.PDF
[Edited 2005-08-10 23:16:32]
[Edited 2005-08-10 23:20:10]
atco2b
Thu Aug 11, 2005 6:28 am
Southampton Eastleigh (EGHI/SOU)
Runway 02/20
1723 x 37m Asphalt
but my home at heart Big grin
London Gatwick (EGKK/LGW)
Runway 08R/26L
3316 x 46m Asphalt/Concrete
Runway 08L/26R (Taxiway mainly)
2565 x 45m Asphalt/Concrete
Tom
Hey, you want to go out for pizza and some sex? What, you don't like pizza?
AsstChiefMark
Thu Aug 11, 2005 7:08 am
City: Baldwin, Wisconsin, United States
FAA: WI14
Latitude: 44.966632
Longitude: -92.387691
Elevation: 1104 ft
Runway: 18/36
Length x Width: 1950 ft x 120 ft
Type: Turf
Timezone: UTC-6 (DST-5)
[Edited 2005-08-11 00:11:51]
Red tail...Red tail...Red tail...Red tail...Red tail...Red tail...Red tail...Red tail...Damned MSP...Red tail...Red tail
JBo
Thu Aug 11, 2005 7:11 am
Muskegon, MI - KMKG
Runway 6/24 - 6,500' x 150'
Runway 14/32 - 5000' x 150' [to be extended to 6500' plus 1000' safety zone off Rwy 14 approach end]
Runway 18/36 - 3200' x 100'
Photo © TZ Aviation
I'd take the awe of understanding over the awe of ignorance any day.
flyerboyek
Thu Aug 11, 2005 8:01 am
White Plains, NY/Westchester County
FAA: HPN
ICAO: KHPN
Runway 16/24: 6548 x 150 ft. / 1996 x 46 m
Runway 11/29: 4451 x 150 ft. / 1357 x 46 m
Photo © Robert Friedlander
PlymSpotter
Thu Aug 11, 2005 9:15 am
Home Airport: Roborough Airfield; PLH/EGHD (Plymouth):
Runway 13/31 1,170m (3,838ft).
Runway 06/24 752m (2,467ft).
Both runways are paved, largest aircraft to land is a BAe146, regular passenger service with DHC8's and ATR42's, both have a maximum load of around 30 passengers due to short runway.
Second Home Airport: Mahon, Menorca International: MAH/LEMH
Runway 01/19 2,350m (7,709ft).
Dan Smile
