sam1987
Ryanair - Go Via DUB!
Thu Aug 03, 2006 7:45 pm
I thought this was so unusual... so I had to share it.
Later this year, I need to get from Leeds (nearest airport: LBA) to Sussex (nearest airport: LGW). I'm not too fussed about how long the journey takes, so when I usually travel this route, my form of transport is the train (upwards of 5 hours to my final destination).
I usually look at flights, just in case they are cheaper. No one actually flies between LBA and LGW, so when I do fly I have to go with BD to LHR, and get someone to pick me up and drive the rest of the way.
BE also fly from LBA to SOU, so although I've never flown the route before, it is always considered just in case they have a really cheap fare.
Whilst booking flights between LGW and DUB for later this month, I realised how cheap FR really are.
To cut the story short, this October I am going to fly LBA to DUB, then DUB to LGW. It takes about the same time as the train and is half the total price! Quite extraordinary.
Has anyone else gone via DUB (or any other FR base actually) on a journey, just because it was so much cheaper?!
Next flights: LGW-LBA-LGW, LHR-SIN-SYD, SYD-BKK-LHR, LGW-GRO, GRO-CIA, CIA-MAD, MAD-LGW
747400F
RE: Ryanair - Go Via DUB!
Thu Aug 03, 2006 8:21 pm
Go for it - if you want to subject yourself to FRaudair! - but be aware that you have sod all in the way of rights in case your first flight is late causing you to miss the next flight. I personally would never bank on a LCC when making a trip with connections.
All humans have the right to marry the one they love
Pe@rson
Thu Aug 03, 2006 8:24 pm
Done it several times and would happily to it again. I have, for example, done NQY-STN-overnight STN-BLK. Now, what about MAN-DUB-LPL?  Silly  Wink
mhodgson
Thu Aug 03, 2006 8:29 pm
I'd do it if I could find the right fares - I have looked into it in the past, but it never worked out!
Focus
Thu Aug 03, 2006 8:45 pm
I needed to get from Berlin to Amsterdam a few years ago. Both the train and the direct flights were too expensive.
So, I ended up flying FR SXF-STN, and then EZY STN-AMS. I did make sure I had 3 hours to make the connection.
The down side: multiple check in, multiple security lines, having to go through immigration at STN and multiple baggage claims.
The up side: Two new airlines for me, two aircrafts, two great flights, and much much cheaper. The whole thing (incl taxes) was just about 60$.
Both flights departed on time, and everything went smooth.
I did have a backup plan in case I miss the connection, however, which was to get to LHR and fly BD to AMS.
All in all, a great and recommended experience - especially if you love flying.
--Focus
gayrugbyman
Thu Aug 03, 2006 9:31 pm
If your flight is late in to DUb from LBA, then you are screwed though.
FR will just laugh at you, instead of helping you like an interlining airline would.
Pe@rson
Thu Aug 03, 2006 9:37 pm
Quoting GayrugbyMAN (Reply 5):
It won't laugh - it'll just not help you. It is spelled out on its website that it is not a connecting airline.
Almost all European low-cost airlines also won't help you.
ANother
Thu Aug 03, 2006 9:40 pm
This is what they say on their website: http://www.ryanair.com/site/EN/faqs.php?sect=pnr&quest=connections
Can I book a connecting flight with Ryanair?
No. Ryanair is strictly a ’point-to-point’ airline. We therefore do not offer, and cannot facilitate, the transfer of passengers or their baggage to other flights, whether operated by Ryanair or other carriers. You should therefore not book onward flights with Ryanair or indeed with any other air or surface carrier. Ryanair accepts no responsibility for making connections and therefore will not be liable for any losses or expenses arising out of any failure to achieve a planned connection.
BCAL
Thu Aug 03, 2006 9:42 pm
Typical FR Bashers' comment! FR will not laugh at you if you miss your connection. They (or their handling agents) will help you to the best of their ability but you will be liable for any additional costs for getting on a later flight, as it is clearly pointed out in FR's terms and conditions that they are a point to point carrier and 'connections' do not exist in their vocabulary. This is why their fares are cheap.
MOL on SRB's latest attack at BA: "It's like a little Chihuahua barking at a dying Labrador. Nobody cares."
gayrugbyman
Thu Aug 03, 2006 9:52 pm
Basically, you take the risk, and it is a big risk. You could end up paying god knows how much the train fare!
richardw
Fri Aug 04, 2006 12:10 am
I've heard a number of people doing this, it is happening.
ReverseThrust
Fri Aug 04, 2006 12:26 am
I think as long as common sense in the passenger prevails when booking (i.e allowing for a decent few hours connecting time - minimum 3-4, especially at Stansted with their infamous queues!) then there is no reason why it can't be done.
Just build in enough time to wait for your baggage and to reach the new check-in desk before the closing time of 45 minutes before the scheduled departure of the flight.
If you risk it with not enough time and it fails, you only have yourself to blame.
Flown MD11/81/82/83/87/90,B732/733/734/735/737W/738/739/742/752/753,F70/100,A300/319/320/321/332/333/343,TU134A/154M,L10
sam1987
Fri Aug 04, 2006 1:50 am
Quoting ReverseThrust (Reply 11):
Very true.
The LBA flight lands at DUB at 17:40, and the LGW flight leaves DUB at 19:10, and check in closes at 18:30.
So I would have a whopping 50 minutes between touchdown and check in closing. Is that cutting it fine?!
Me thinks I should get the lunchtime LBA flight.
Has anyone here connected through DUB before? Is departures close to arrivals?
Pe@rson
Fri Aug 04, 2006 2:10 am
Quoting Sam1987 (Reply 12):
Extremely fine.
Both in the same building with one above the other.
Yep.  Smile
ushermittwoch
Fri Aug 04, 2006 3:49 am
What I did in June was to fly BUD to BGY on SkyEurope and then BGY to DUS with Air Berlin, 110 minutes connecting time. It was WAY cheaper than BUD to DTM and due to an equipment change I got to fly on my first 73G. Big grin
Where have all the tri-jets gone...
Ryanair737
Fri Aug 04, 2006 7:27 am
Why don't you get the bus/train to MAN from Leeds, and then fly from MAN to LGW either with BA or Jet2?
Ryanair737
LAST FLIGHTS= Ryanair LPL-BGY-LPL - EI-DPS/DWV - MAY 08 // NEXT FLIGHTS= TBC
FlyKev
Fri Aug 04, 2006 8:02 am
Are you travelling with suitcases then?
If not, the why not take advantage of the online check in instead, you can check in for both (or all) flights before you even leave. You need be at the gate 30 mins before departure.
Kev
sam1987
Fri Aug 04, 2006 9:28 pm
Quoting Ryanair737 (Reply 15):
Cost. The prime reason for me going via DUB is because it is about the same price as the train all the way down south. BA and LS aren't half as cheap as FR, especially once the train fare to MAN is added on.
Quoting FlyKev (Reply 16):
I was going to, but if I want to be sure about the connection, it is probably best not to. Then I can check in online and walk from arrivals straight to security, without going to a check in desk.
I also save £5 without suitcases!
pilot320
Sun Aug 06, 2006 6:08 am
I had to go from Dubrovnik to Rome 2 months ago, and direct flight with Croatia Airlines costs about 215 €. This fare was too expensive for me, and on SkyEurope's website I found one-way ticket for only 55 € (via PRG).
Users browsing this forum: No registered users and 17 guests
