UAEflyer
Do You Feel Dry While Flying?
Wed Dec 06, 2006 5:53 pm
I was always asking my self why the skin become very dry while flying and even the eyes.
I know it is always good to drink plenty of water during the flight, but is there any system or mechanism that can let your skin normal while flying. Lotions, water, and other moisturisers i know they can do the job. What else can help, anything through the AC or anything else.
GuyBetsy1
RE: Do You Feel Dry While Flying?
Wed Dec 06, 2006 6:02 pm
Inflight air, although cool only contains about 10-20% humidity level.. which can be as dry as a desert.
You basically have to drink lots of liquids, and put on moisturisers inflight. And avoid alcohol and caffeine.
wing
Wed Dec 06, 2006 6:03 pm
What I do is, before every flight I take a bottle of water and fill it with lemon.I try to drink all of it during the flight.The natural way of moistrising yourself.I am generally against any artificial form of anything if it can be done naturally.
follow me on my facebook page" captain wing's journey log"
UAEflyer
Wed Dec 06, 2006 6:48 pm
Quoting GuyBetsy1 (Reply 1):
20% is nothing, but is their a research that took place recently studied this case?
Cant they increase the humid level in the aircraft AC
Quoting Wing (Reply 2):
LooL i loved the idea i will do it in my next trip
Buyantukhaa
Wed Dec 06, 2006 8:06 pm
Isn't it even less than that still? I always thought it was about 1-3%, especially on longer flights.
"Edit:"
Seems that literature is divided on the issue, but this article may shed some light on cabin environment (interesting reading!):
http://www.boeing.com/commercial/cabinair/ventilation.pdf
It gives a range of 5-35%.
I scratch my head, therefore I am.
EWRCabincrew
Thu Dec 07, 2006 12:17 am
Quoting UAEflyer (Reply 3):
I live in the desert and we get as low as 3%, especially now, in winter. Onboard: drink lots of water. Avoid alcohol. Stretch and walk a bit, too.
There are times when I fly, long haul mostly, I still get bloody noses. Mostly because I don't drink enough water. Dryness affects everyone. Even crew.
You can't cure stupid
captaink
Thu Dec 07, 2006 1:04 am
For me it is especially noted when I wake up after sleeping an hour or two. The effect feels worse, I drank alcohol before. Big grin
Question: Is it the same on all airplanes? Cause I am sure I read somewhere that newer develop airplanes boast higher humidity levels hence a more comfortable cabin.
There is something special about planes....
HAL
Thu Dec 07, 2006 2:04 am
Quoting UAEflyer (Thread starter):
It affects everyone, including the us (the crew). I fly longhaul (5+ hrs) for Hawaiian, and if I don't drink a lot of water I feel it after we land.
The problem is that the air itself at altitude is very dry, so the only way to increase the humidity is to actually introduce moisture into the air as it enters the aircraft. That introduces all sorts of other problems when dealing with the average bleed air/AC pack system on airliners. If you put the water in before it got to the AC system, the moisture would freeze and destroy the AC system. Put it in after, and you risk creating puddles in the ducting that could leak on the passengers. Carrying all that water around would cost the airline in fuel and payload penalties. It would also be another system to service and certify, the moisture would lead to additional corrosion problems, and it would be difficult to prevent mold and bacteria growth problems in the system. I know that Boeing will do something about it in the 787, but they have a different type of pressurization system, and a composite fuselage (no corrosion problem).
In today's aircraft, the only thing to do is drink lots and lots of water, and avoid caffeine and alcohol. Good luck!
HAL
One smooth landing is skill. Two in a row is luck. Three in a row and someone is lying.
ZRHnerd
Thu Dec 07, 2006 2:11 am
Has anybody ever been to the Maledives? When you walk out the door at Male Airport after a 7 hours flight you feel like walking into a wall as humidity in Male is about as high as it can get Big grin
HiJazzey
Thu Dec 07, 2006 2:45 am
Quoting ZRHnerd (Reply 8):
Haven't been to the Maldives (would love to though), but I get that whenever I fly in to JED. It's like a steam room when the doors are open, you sometimes have a mist of condensating air around the door Big grin ! Horrible. You feel sticky before you even reach the bus at the bottom of the stairs.
Regarding dehydration. There are no easy solutions now with the restrictions on liquids. I guess we have to just hassle the attendants a bit to get us more water.
The lemon idea sounds interesting.
roseflyer
Thu Dec 07, 2006 6:21 am
The airplane would have to carry the water, which would be expensive since water is so heavy.
Also low humidity is good since it reduces corrosion. Humid environments promote corrosion and bacteria growth which are bad to have on airplanes.
articulatexpat
Thu Dec 07, 2006 8:11 am
I go to extremes, but I don't want to get sick. I got this tip from my stepmother, who's a nurse. Dry sinuses my crack and permit airborne germs may enter. If I'm not in such a hurry that I forget, I stop in the men's room before boarding to put antibiotic ointment in my nose. (In a stall. This is not something I'd want an audience for.) A dab of Neosporin or its equivalent, some tissue... it works like lotion on dry skin, but it will also kill anything bacterial that ought not to be there.
I take a 1L bottle of water with me when I fly. Always. More (1.5 or so) if it's a long-haul flight. Without my caffeine fixes, properly timed, I get pounding headaches, so I permit myself the necessary minimum, but I don't binge. No alcohol unless I'm on a good carrier and I'm not feeling parched, and then only one small glass of wine with my dinner.
Lotion for the backs of my hands. Moisturizer for my face. And I shave before I leave home: if I don't, the dry skin plus the razor stubble looks kinda gross. Partly this is self-care; partly this is vanity. Besides, going through customs and immigration these days, it doesn't hurt to be presentable.
iflyswa
Thu Dec 07, 2006 9:04 am
Ladies, this sounds like a personal problem! If it includes itching, irritation, discomfort or pain, you may want to consult with your physician or a gynecologist. Where indicated, products like Vagisil and KY Jelly have demonstrated proven efficacy in relieving these symptoms.
 rotfl   rotfl   rotfl
Just some mild humor, don't flame me!
 duck
iflyswa
Opinions expressed by "iflyswa" are not those of Southwest Airlines Officers, Directors, or Employees.
kaddyuk
Thu Dec 07, 2006 9:46 am
Quoting EWRCabincrew (Reply 5):
Bah... Whats the point in flying? I get a free bar at 38,000ft...!
UAEflyer
Thu Dec 07, 2006 12:55 pm
I heard somewhere that Boeing did introduce a system that increase humid in the aircraft and it is fitted on one of the private 747-400, not sure which one.
TupolevTu154
Fri Dec 08, 2006 11:22 pm
Exactly the same for me. It can last for a few days afterwards occasionally.
I usually fall asleep with my mouth open on long flights, and wake up with a dry mouth, not nice  boggled
Tom Big grin
Superfly
Sat Dec 09, 2006 12:23 am
And avoid alcohol
Are you kidding?!?!?!  Wow!
I like drinking on flights, especially longhaul.
Quoting TupolevTu154 (Reply 15):
Ever have a prankster sit in front of you? Big grin
Bring back the Concorde
BA787
Sat Dec 09, 2006 4:37 am
I always have a dry throat after a flight, but then I get dry throats a lot anyway so they don't bother me
