airbus3801
Enough Connection Time In LAX
Fri Feb 02, 2007 12:47 pm
Is two hours enough to get from the Southwest terminal at LAX to Tom Bradley to check in for an EI flight to Dublin? We get in at 2:45 and the flight leaves at 5:00 for Dublin. Just want to make sure we aren't screwing ourselves.
thepilot
RE: Enough Connection Time In LAX
Fri Feb 02, 2007 3:12 pm
you'll be able to get from one terminal to another in time, but I would look into Aer Lingus' policy for checking in on international flights. If WN is slightly delayed, that could be bad. Also, the Tom Bradley security check can be a bitch. If all goes smooth, it should be enough time, but you may be cutting it close.
From YVR
DesertAir
Fri Feb 02, 2007 8:32 pm
I made this connection this past summer. It is about a 10 minute walk. I also agree that security can be a trying experience especially when there are a large number of flights departing.
Users browsing this forum: aerdingus and 10 guests
