amirs
Longest 747-400 Non ER Route
Sat Mar 17, 2007 10:32 pm
Just thought we do one of these, since today they annonced they will stop to produce these fine aircrafts.
So what is the longest 747-400 route flown?
I know there are:
MEL - LAX 6883 nm QF
TLV - LAX 6581 nm LY (discontinued)
LAX - SFO 6445 nm UA, QF
SYD - JNB 6336nm QF
HKG - LAX 6309 nm CX
What are some other?
Was JNB - ATL, iAD or JFK done ever nonstop with a 744?
britannia191a
RE: Longest 747-400 Non ER Route
Sat Mar 17, 2007 10:41 pm
In 1996 United Airlines started Chicago to Hong Kong - 7788miles. that must be the longest, 15hrs 37mins, or is this with an ER version?
Leg 1 - United Airlines 895
Departure Chicago (O'Hare), IL (ORD)
Departure Time 12:18
Arrival Hong Kong (HKG)
Arrival Time 16:55+1
Aircraft Type 744
Meal Lunch, Lunch
Distance 7789mi / 12462km
Duration 15h37m
Operated By United Airlines
vulindlela744
Sat Mar 17, 2007 11:00 pm
I flew on South African Airways from Miami to Cape Town in 1997 aboard a 747-400 (non-ER) version which was 7666 miles each way. It was about 14:45 each way. That was definately one of the longest.
FoxBravo
Sat Mar 17, 2007 11:06 pm
Quoting Amirs (Thread starter):
Yes, SA used to operate ATL-JNB (7334 nm), ATL-CPT (7064 nm) and JFK-JNB (6925 nm). These were only nonstop eastbound (the westbound JNB flights stopped at SID, and the CPT flight stopped at FLL), but I believe they were the longest nonstop 744 routes--ER or non--that were operated regularly. As I have mentioned on other threads, I wish SA would reinstate the JFK-JNB nonstop--it is really a step backwards to have to stop at DKR both ways now!
ORD-HKG was also operated with a regular 744, but was "only" 6773 nm. Still, I believe that would have been the longest nonstop non-ER 744 route flown nonstop in both directions. I remember reading that they towed the aircraft to the runway at ORD so they wouldn't waste fuel taxiing!
Common sense is not so common. -Voltaire
AirplaneFan
Sat Mar 17, 2007 11:16 pm
WOW! LAX to SFO "6445 nm"? Big grin
LAX is less than 500 miles away from SFO.  Wink
AirplaneFan
I GOT YOUR SIX
britannia191a
Sat Mar 17, 2007 11:31 pm
Quoting FoxBravo (Reply 3):
Why do you say was, my reply above is current and they say 7789 miles where do you get "only 6773"
Zkpilot
Sat Mar 17, 2007 11:44 pm
I know there are:
SYD - JNB 6336nm QF
Quoting AirplaneFan (Reply 4):
AirplaneFan
hahaha um I'm thinking that should be SYD-SFO not LAX-SFO...  Wink
NZ does AKL-SFO which is pretty far but not quite as far as QFs flights.
56 types. 38 countries. 24 airlines.
sunrisevalley
Sat Mar 17, 2007 11:48 pm
Quoting Britannia191A (Reply 5):
The "standard" used is, I believe, either nautical miles or kilometer not statute miles. The figure 6773 is probably nautical miles.
amirs
Sun Mar 18, 2007 12:01 am
AirplaneFan
Sorry, that was suppose to be SYD - SFO.
Lets stick to NAUTICAL MILES (nm) - so we are all comparing the same.
MCOflyer
Sun Mar 18, 2007 12:19 am
LAX-HKG UA? 6309NM
ATL-ICN Korean 6215NM
LAX-MNL 6348NM Philippines?
MCOflyer
PhilSquares
Sun Mar 18, 2007 12:33 am
I think if you look at the headwind component on the LAX-HKG segment, it actually is longer than the LAX-MEL segment. While the LAX-MEL segment has some headwinds, it doesn't approach the velocity that you normally see going to HKG from the US.
Fly fast, live slow
Users browsing this forum: B747forever, iloveswiss and 17 guests
