Longhornmaniac
Connecting In SJU, How Easy?
Sun May 06, 2007 3:50 am
Hello all,
I am flying from SXM back to AUS on June 6th, through SJU, MIA, and DFW.  biggrin
Our flight, AA 5041, gets into SJU at 1055, and our flight leaves SJU at 12:15 to MIA. Is this enough time to get through customs and back to our MIA flight? I'm very unfamiliar with SJU (though I generally navigate airports well), so I have no idea where our flights go in and out of, terminal wise. We're in C SJU-MIA, if that makes any difference timing wise.
Also, on the ATRs, do they board and deplane out of the front or back? Back, I'm assuming. My mom has semi-bad knees (after this vacation, they'll be on the baddish side I'm sure), so she moves a bit slower, so any tips for getting there shorter/faster are much appreciated.
One more question: No customs/immigration in MIA, correct? SJU is considered a port of entry into the US, right?
Cameron
Cameron
LAXdude1023
RE: Connecting In SJU, How Easy?
Sun May 06, 2007 4:15 am
If I were you I would ask to be put on a flight from SJU-DFW. Sometimes if AA has the seats they will allow it (mostly depending on the fare). This way you could bypass MIA!!! Sometimes they dont, but sometimes they do.
It is what it is...
AlitaliaMD11
Sun May 06, 2007 4:35 am
Quoting Longhornmaniac (Thread starter):
That should be enough time. I have cleared customs before at SJU after coming back from SXM and it only took me three minutes as there was no lines at all. The American concourses are all connected so it is easy to access them.
Boarding and deplaning takes place from the back of the aircraft.
No Vueling No Party
md90fan
Sun May 06, 2007 4:40 am
They board and de-plane in the back using stairs sir. I could recommend you wait at the gate area long before everybody comes, that way one the door opens to walk down the airplane you can beat everybody on  wink
The boarding is pretty much like this:
Photo © Marlo Plate - Iberian Spotters
It's domestic sir  yes
http://www.devanwells.blogspot.com/
Longhornmaniac
Sun May 06, 2007 6:19 am
Quoting LAXdude1023 (Reply 1):
 gasp
But...but...but... if I did that, I'd miss the 777 in F between MIA-DFW. Are you crazy!?!?!?  Smile I'll go through the worst airport in the world if it means a ride in F on a 777.
Quoting AlitaliaMD11 (Reply 2):
That's good to know, I was a bit worried that an hour and 20 minutes wasn't going to be enough.
Quoting MD90fan (Reply 3):
Haha, sounds like a good suggestion to me. I'm trying to decide whether to sit in the very front (right now we have 1 A,B, and C reserved. Exit row, good views from what I hear), or the very back. Back is easy on and easy off, but I do like being toward the front... Any suggestions?
Thanks all for the help!
Cameron
Cameron
AirCop
Sun May 06, 2007 6:44 am
All depends on how fast American Eagle gets the bags to the terminal in SJU. Was on an ATR72 flight from BGI and it took 45 minutes just for the bags to appear, nearly missed the connection to DFW. Generally, you should be okay.
LAXdude1023
Sun May 06, 2007 6:55 am
Quoting Longhornmaniac (Reply 4):
But...but...but... if I did that, I'd miss the 777 in F between MIA-DFW. Are you crazy!?!?!? I'll go through the worst airport in the world if it means a ride in F on a 777.
AHHH, ok. I didnt know that. Thats true, I love me a 777. I was just suggesting somthing that might make it easy. When I went to college in Fort Worth, I flew AA everywhere and If I wanted to bypass a connection, if they had the seat they would let me do it.
It is what it is...
BDL2DCA
Sun May 06, 2007 7:06 am
The rear of a prop is much quieter, fwiw.
146,319,320,321,333,343,722,732,733,734,735,73G,738,744,752,762,763,772,ARJ,BE1,CRJ,D9S,D10,DH8,ERJ,E70,F100,S80
spyderz
Mon May 07, 2007 12:36 pm
When I transit through SJU on an international itinerary, it usually takes me a solid hour to transfer through the international mess that is San Juan.
On arrival, the ATR will deplane from the rear, however a bus will being waiting to shuttle you back to the terminal. The bus will then drop you off at the farthest possible point from immigration with the walk taking approximately 5-7 minutes. While the lines at SJU immigration are never long, the officers in SJU have to be the most incompetent in the entire system. I have continually had issues where the agents did not know the proper regulations and the secondary screening room seems to be a second home. However, if everything is straight forward you should have no problems. Once baggage has been claimed, which can be a crapshoot, the customs form has to be dropped off. I've seen lines snaking to the back of the room, taking approximately 10 minutes to hand off a form, however around noon the lines should not be as long. Afterwards the bags need to be dropped off and security needs to be recleared, which is always a pain. If you survive all these steps in a timely fashion, you'll make your flight.
While every international to domestic connection is not simple, the process in SJU seems particularily bad. You'll be tired, frustrated, and annoyed after going through this process. American needs to take a serious look at this, as I purposely avoid making int'l connections through SJU now.
To answer your question, you should just have enough time to make your connection.....just.
Users browsing this forum: desertjets and 1 guest
