fox1211
Longest Passenger Flight In 747
Wed Sep 19, 2007 4:06 pm
Yes I was wondering if someone could tell me what is the longest non stop flight for commercial travel in 747. It seems the answer changes as do Airlines etc but it is hard to get a clear or current (with in 90 days up to current operation). The last I read was from a book, which said there was a nonstop from ORD to HKG. but it only said the time or average duration. Thanks in advance for your help.
P.S. Even if you don't know the source or date rather I would still like to know any best guess or longest you are aware of even if it is no longer flying.
QFA380
RE: Longest Passenger Flight In 747
Wed Sep 19, 2007 5:33 pm
Not too sure, but at a guess I'd say MEL-LAX is surely up there, 6883nm.
Qantas744er
Wed Sep 19, 2007 5:43 pm
Currently the longest is
Quoting QFA380 (Reply 1):
Correct but this is operated by 744ER with hgher MTOW/Range then the 744 and with 6773nm ORD-HKG this flight always takes longer than the slightly longer LAX-MEL becuse of the by far higher head winds then on LAX-MEL.
And this operated by a standard 744 with UA  Wink
Leo
You live and you die, by the FMA
timz
Thu Sep 20, 2007 2:16 am
None of those threads answers the guy's question.
It's not currrent, but probably the longest-ever scheduled 744 nonstop was ATL-JNB.
[Edited 2007-09-19 19:20:11]
[Edited 2007-09-19 19:20:41]
Zkpilot
Fri Sep 28, 2007 11:33 pm
 checkmark  I fly on it often... 15 hours LAX-MEL
Quoting Qantas744ER (Reply 2):
That is true... however QF has at times operated it with standard 744. The 744ER is still classed as a 744 in any case... is a shame that only QF ordered them as pax a/c...
SYD-JNB must be one of the longest also... 6862nm also into headwinds.
57 types. 38 countries. 24 airlines.
andz
Sat Sep 29, 2007 5:55 am
That just pips SYD-JNB at 6,862 miles but JFK-JNB with SAA 744 was 7,969 miles and I have done both.... LOOOONG!!
timz
Sat Sep 29, 2007 6:11 am
Quoting Andz (Reply 6):
7969 statute miles, he means.
andz
Sat Sep 29, 2007 11:31 pm
Quoting Timz (Reply 7):
It is still longer than MEL-LAX at 6,925nm
747fan
Sun Sep 30, 2007 1:12 am
United's ORD-HKG is up there at about 6700-6800 nm. It was the longest flight in the world when it was introduced back around 1997. I believe the longest scheduled pax 747 flight ever was United's JFK-HKG flight, which I believe was discontinued due to 9/11. It was nearly 7000 nm. I've also heard that it was often weight-restricted.
timz
Sun Sep 30, 2007 5:16 am
Quoting 747fan (Reply 9):
It [ORD-HKG] was the longest flight in the world when it was introduced back around 1997.
Not if JFK-JNB was still nonstop then. Don't recall if ATL-JNB had started by then.
That might be second-longest.
Sun Sep 30, 2007 3:53 pm
How long timewise was this in the 744? The 346 covers the distance in 16½ hours, but I believe the 744 cruises faster.
7014 nm according to the Great Circle Mapper. Bound to be a bit longer. IIRC we passed on the other "side" of the pole so did not go straight the whole way.
HKG&PATH-COLOR=red&PATH-MINIMUM=&PATH-STYLE=&PATH-UNITS=mi&RANGE=&RANGE-COLOR=navy&RANGE-STYLE=best&SPEED-GROUND=&SPEED-UNITS=kts" target=_blank>http://gc.kls2.com/cgi-bin/gc?MAP-ST...best&SPEED-GROUND=&SPEED-UNITS=kts
Quoting Timz (Reply 10):
How fast did the 744 cover this? CX schedules this at 16½ hours but the 744 is a mite faster in cruise.
747fan
Mon Oct 01, 2007 12:22 am
Quoting Starlionblue (Reply 11):
I'd imagine a little more than 15 hours on the JFK-HKG leg, as CO's EWR-HKG flight is generally 15 hours, 15 minutes to 15.5 hours long, and the 744 cruises at Mach 0.86 compared to 0.84 for the 777. I know UA's ORD-HKG flight is generally about 14.5 hours, maybe a bit less - ORD-HKG is about 300-350 nm. shorter. The return flights out of HKG are probably close to an hour shorter.
ALexeu
Sun Oct 21, 2007 1:30 pm
How about Johannesburg-Dulles, which is a nonstop flight? It was opereted by 747, altough i don't know if they switched.
747fan
Sun Oct 21, 2007 4:07 pm
Quoting AlexEU (Reply 13):
This flight is nonstop via DKR. I believe it used to be a 744 and it may have been nonstop on the IAD-Johannesburg leg, but the flight is now an A343 one-stop both ways. Recently it was also an A346, which was nonstop eastbound and 1-stop westbound.
readytotaxi
Sun Oct 21, 2007 5:08 pm
In the cold light of day, wot the hell do you do to pass the time?
My current longest flight is 12 hours, and I was climbing the walls, even in Club Class.
I plan to fly to AKL soon via Singapore and take a 2 day break there, before flying on,should I take some sleeping pills, get drunk, do yoga, or upgrade to First Class? Not looking forward to all that "dead" time.
Transpac787
Sun Oct 21, 2007 6:02 pm
"Often" is not a good word to describe it. "Heavily" would be a better word to describe it!!! CX operates JFK-HKG nonstop on the 346 or with a fuel-stop in YVR on the 744. UA operated JFK-HKG nonstop on the 744, with weight restrictions upwards of 80 seats.
The 744 is currently the fastest-cruising widebody.
BWilliams
Mon Oct 22, 2007 2:07 am
What about KE's JFK-ICN route? My friend flew that this summer, and he remembered that he was on a 747 (well, he remembered that the plane had a small second floor, but same difference).
I think he said that it was 16 hours or something.
Regards, Brad Williams
thepilot
Mon Oct 22, 2007 2:51 am
Quoting Transpac787 (Reply 16):
Correct me if I'm wrong, but I believe that honor belongs to the Lockheed L-1011. Cruising speed of mach .90, compared to mach .85/.86 on the B744.
From YVR
PhilSquares
Mon Oct 22, 2007 3:15 am
Quoting Thepilot (Reply 18):
IIRC the 1011 will cruise at .84 and as low as .80 for LRC. The 744 will cruise between .855-.86.
Fly fast, live slow
citationjet
Tue Oct 23, 2007 10:41 am
Quoting Fox1211 (Thread starter):
Do you define "long" in terms of distance taveled (miles) or duration of flight time (hours)? You are getting both types of answers. One measure of long is impacted by winds aloft and the other isn't.
Boeing Flown: 701,702,703;717;720;721,722;731,732,733,734,735,737,738,739;741,742,743,744,747SP;752,753;762,763;772,773.
AJ
Tue Oct 23, 2007 12:40 pm
Still standing as the longest flight in my logbook is LAX-MEL in 'standard' Boeing 747-438 VH-OJQ: 15 hours and 40 minutes. The next after that was same aircraft same route in 15 hours 14 minutes.
andz
Tue Oct 23, 2007 4:23 pm
The other way round maybe.
747fan
Tue Oct 23, 2007 4:31 pm
Quoting Andz (Reply 22):
 checkmark  Not only do you have to take into account the headwinds, but a fully loaded 744 (or A340 for that matter) can't make it out of JNB due to its high elevation. However, I believe the 77L be able to fly out of there with a relatively full load of pax/fuel as DL is likely planning on using it to fly ATL-JNB-ATL nonstop, correct me if I'm wrong.
n710ps
Tue Oct 23, 2007 6:17 pm
Anything departing from JFK after 5 PM if you count it as time spent on your ass in a seat maybe?  duck
There is plenty of room for Gods animals, right next to the mashed potatoes!
BCNGRO
Wed Oct 24, 2007 12:04 pm
What about Europe-South America?
FRA-EZE is 6,200nm
At the bus station, buses stop. At the train station, trains stop. At my desk, I have a work station.
EZYAirbus
Wed Oct 24, 2007 5:47 pm
I once flew SIN-LHR with BA on a 747-400 once and due to really really strong headwinds it was almost 16 hours and the captain announced that we might have to stop at FRA for fuel en route!
Glenn
http://www.glenneldridgeaviation.com
747fan
Wed Oct 24, 2007 6:04 pm
Quoting BCNGRO (Reply 25):
FRA-EZE is 6,200nm
That's definitely one of the longer 747 pax flights, longer than LHR-SIN (a shade under 6000 nm.)which is the longest nonstop route from LHR. But there are many 747-400 flights that are longer, such as SFO-SYD, LAX-SYD, LAX-MEL, LAX-HKG, ORD-HKG, and SFO-HKG. ATL-ICN (flown by a KE 744 in addition to the DL 772) is also probably up there.
planeguy727
Sat Oct 27, 2007 1:15 pm
For the sake of a flashback - when PA was operating SYD-LAX with the 747SP it was the longest at the time. I did this flight in Aug 1984. Long but enjoyable.
And to add the humour aspect - I have been on flights of less than 200nm that were over 2 hrs in the air - thanks to many many circles...
I want to live in an old and converted 727...
InbarD
Sun Oct 28, 2007 2:22 am
HKG-LHR Approximately 13 hours long on a Qantas 747-400ER
LAXspotter
Sun Oct 28, 2007 3:19 am
Just wondering, couldnt anet "publish" a list of all these superlatives, because I used to start these threads too, but I realized we all get conflicting answers, I guess the point of it is someone starts a thread, we discuss our opinions and finally find the correct answer  Big grin
"Patriotism is the last refuge of the scoundrel" Samuel Johnson
