aircatalonia
Joined Flight School - Help Me Choose Plane!
Fri Jan 25, 2008 12:07 pm
So I finally took the decision to pursue my dream of becoming a pilot and joined the local flight school.  Smile
Now I have to choose plane and I have the following possibilities:
Tecnam P92
Cessna 152
Robin HR 20
And then the more expensive ones:
Cessna 172 N
Cessna 172 R
Cessna 172 S
Which planes do you think are more suitable for training? Do you think it is worth the investment to go for a 172 or a 152 should do?
futurecaptain
RE: Joined Flight School - Help Me Choose Plane!
Fri Jan 25, 2008 2:03 pm
Quoting Aircatalonia (Thread starter):
Tecnam P92
Cessna 152
Robin HR 20
I don't know anything about the Tecnam or Robin, but I did get my private license in a C-152. It's a forgiving plane, easy to fly, although a little small on the inside. The redeeming quality of the 152 is the rental rates are usually extremely cheap which will save you money, extremely useful if you are paying for this out of pocket.
Cessna 172 N
Cessna 172 R
Cessna 172 S
I have flown the R and S models of the C-172. Great interior compared to the 152 in my opinion. The plane will be a good 20 kts faster in cruise over the 152. One other advantage is if you continue with this and get an instrument rating you can do that in a 172 also and already knowing the speeds the plane flies at and the systems will save you a few flights later on in the transition period getting to know the aircraft. Also after you get your license if you want to take more than 1 person up at a time, like you would in a 152, you already know the plane.
I'd say go with the 172 if you plan on continuing this through your instrument rating and commercial or if you need the extra room. If you and your instructor fit in a 152, underweight, then go for it. You will probably save 30-40% off the rental rates and have more money left over in the end to get checked out in a 172 after you have your license if you so desire.
2H4
Fri Jan 25, 2008 4:28 pm
Futurecaptain hit the nail on the head. I've flown both models, and agree with every point he made.
Your size will have a lot to do with it. If you're average or larger-sized, and if your instructor is the same, you might want to ante up for the 172 in the name of comfort.
While standardization is beneficial in terms of the shift to instrument training, I personally enjoy learning different aircraft. I love having to learn new systems, procedures, and handling techniques, so I take every opportunity to learn a new model.
To me, the 152 feels like an airplane you strap on. It's lighter on the controls and feels more precise. The 172 is great, but compared to the 152, it feels fatter, slower, and more numb in terms of handling. I'm thinking of crosswind landings in particular.
Having flown many different models of the 172, including the R, I am of the opinion that the newer and more expensive R and S models aren't really worth the extra money. The interiors are more modern, and they're quieter, but to me, they're no more fun or enjoyable to fly. Plus, I rather enjoy the older planes in general. It's tough to beat cream and orange vinyl interior with chrome accents.  biggrin
Finally, a 150/152 tip. If one of your feet starts to get numb and fall asleep, remove your wallet.
2H4
Intentionally Left Blank
swaopsusafatc
Fri Jan 25, 2008 6:22 pm
If weight is not a problem between you and your instructor and eventually you and the local examiner I would go with the C152. It is cheaper and when you get the private license you can just get checked out in a hour or 2 in the 172. I don't know the other planes well enough to add info about them.
Swaops
futurecaptain
Fri Jan 25, 2008 6:42 pm
Quoting 2H4 (Reply 2):
True. After 80 hours strictly flying a 152 for my private license the first time I flew a 172 the controls felt heavy and harder to move. Also the extra weight of the 172 helps with turbulence, the heavier plane is less likely to be bounced around as much. If airsickness becomes a problem, you may want to try the bigger plane.
Blasphemy!  Smile
I've had that happen, could never figure out why. It hurts like he** trying to fly a plane when your foot goes numb. I'll try this out next time.
aircatalonia
Fri Jan 25, 2008 9:41 pm
Hey guys, thanks for the advice.
I already gave them a call and told them I will go with the 152. I'm an average sized guy (tall but thin) so room should not be too much of a problem. I'll just remove everything from my pockets before squeezing my way into the tiny cessna.  Wink
On monday I am having my initiation flight. It's a 45 minute flight to basically get familiar with the aircraft and do some very basic manouvers both in the air and on the ground to feel the controls for the first time. That is what I was told. I've not had any theory yet so I guess it won't be much more than that. Anyway, I'm already looking forward to my first time in the front seat.  Smile
I'll let you know how was my first aerial experience  Wink I'm really excited.
aircatalonia
Pe@rson
Fri Jan 25, 2008 9:51 pm
Hope all goes well, AirC.
Sorry to hijack your thread with my own question:
Do you reckon it´s worth pursuing a PPL (it would be in the UK) if you could only afford one or two flying lessons per month. Sorry for no question mark: this darn computer doesn´t have the key.
AF340
Fri Jan 25, 2008 10:13 pm
Quoting Pe@rson (Reply 6):
I do that pretty much only because of wx conditions. VFR sucks in Canada! It will, of course, take you longer, but only a couple years at most.
Liam spin
Pe@rson
Fri Jan 25, 2008 10:22 pm
Quoting AF340 (Reply 7):
Yep. Which means I´ll probably not advance so quickly, which means I would ultimately spend more on getting my PPL.
However, if it´s a choice between starting at a later date, say 5 years away, and doing it pretty intensively (in theory), or starting pretty soon, e.g. in 7 months, and having one or two lessons a month, which would you choose and why?
2H4
Fri Jan 25, 2008 10:25 pm
Quoting AirCatalonia (Reply 5):
Do keep us posted, AirCatalonia. I'm looking forward to hearing updates.  yes
Two thoughts:
1) No training is worthless. With the right attitude and the right mindset, you'll learn something from every flight. In my opinion, this in and of itself makes for an enjoyable use of time and money.
2) While no training is worthless, the effectiveness of training can vary greatly. Flying one or two lessons per month will result in very, very little progress toward a certificate or rating. Half or more of each lesson will be spent reviewing the last lesson and "brushing the rust off", as opposed to building upon what you've learned.
Think of it this way - if each lesson is a step forward, each week of non-flying is a half-step backward.
Flying one or two lessons per month will teach you things, but at that rate, your progress toward a certificate or rating will move forward at the pace of a glacier. If the goal is simply to fly and learn for the sake of flying and learning, that's fine....but if the goal is to earn a certificate or rating, training at this pace will end up costing much more in the long run.
2H4
Pe@rson
Fri Jan 25, 2008 10:31 pm
Thanks, 2H4. That puts it all into perspective.
2H4
Fri Jan 25, 2008 10:53 pm
Quoting Pe@rson (Reply 8):
Question for you, Pe@rson - what is your goal?
If your goal is to progress through your ratings and eventually fly for a living, than efficiency...in terms of both time and money...really should be taken into account.
If your goal is simply to earn your PPL and fly for the enjoyment of flying, there's really no rush. Taking it slowly and investing in more dual (in the long run) can be enjoyable.
Case in point - I took my sweet time getting my PPL. Part of it was due to the dismal Michigan weather, but a lot of it was due to the fact that I was involved in a very enjoyable flying club. I'd hang out at the club and sometimes go up with people with no rigid lesson plan in mind. I also had a couple of years before my more advanced training began.
So I took my time. I'd grab my instructor and go work on various things in a relaxed manner. We'd make an afternoon out of it and go grab lunch, perhaps working on maneuvers on the way out, and pilotage and dead reckoning on the way back.
We'd hop over to bigger, more complex airports for pattern work for the experience. It may have cost more time and money to spend 30 minutes in transit to that larger airport, but I got a great feel for busy frequencies, heavy traffic, parallel runways, and all the things a smaller airport lacks.
It certainly wasn't the most efficient use of my time or money, but at the time, I had a good amount of both. As a result, my training provided me with very interesting real-world experiences and quality time with good friends, as well as with the expected technical training.
It cost more, but I don't regret a minute of it.
2H4
Pe@rson
Fri Jan 25, 2008 11:05 pm
Thanks again, 2H4. Very informative.
Quoting 2H4 (Reply 11):
Just getting my PPL for fun/enjoyment. I won´t be flying as a career. You see, I´m returning to university (age 26!) this Sept (I´ll be doing Airline Management, so that´ll be my career) and I´m just contemplating whether to do my PPL training during that period (I could afford to do it monthly or bimonthly) or to wait until I´ve got my new career and have sufficient cash to do it quicker. Hmm. Lots to think about!
ZBBYLW
Sun Jan 27, 2008 8:38 am
I did all my training on a 152 and I am 6'4 and 200 ibs... its a tight squeeze but I much preferred the 152 to a 172. Now if you could land a Citabria, I would say go for that for sure!
Well like 2H4 had mentioned its a trade off. I did mine as intensively as the weather would allow, I was always on the ball and ready for the next lesson, half way through however the weather crapped out on me for 3 weeks (low ceiling, icing etc...) my first flight back was a little rusty. With experience behind you however you do not really get that rusty within the same time frame. For me I can now go a month without flying and feel comfortable in an aircraft (1 month is the longest I have gone without flying since getting my PPL 2 years ago). If I were you I would consider waiting, however if you are anything like me, I know you would just want to go out there and fly, fly, fly. Simply put do what you want... If you want to save the money and time, wait untill you are ready, if you want to fly, fly, fly, I would suggest starting soon!
Keep the shinny side up!
swiftski
Sun Jan 27, 2008 10:03 am
I flew a C152 for the first time yesterday, ex Manston, and loved it. Very easy to fly.
aircatalonia
Sun Jan 27, 2008 4:41 pm
Quoting Swiftski (Reply 14):
I'll be doing that tomorrow morning! Big grin
N231YE
Sun Jan 27, 2008 5:04 pm
No PA-38s or PA-28s? What kind of flight school is this?!  eek
2H4
Sun Jan 27, 2008 5:13 pm
Quoting N231YE (Reply 16):
One with good taste!  duck
I kid, I kid....I'm just more of a Cessna guy.
2H4
N231YE
Sun Jan 27, 2008 5:33 pm
Quoting 2H4 (Reply 17):
I like the feeling of an airplane beneath my seat, not one of a foam model airplane  wink
[Edited 2008-01-27 09:41:31]
2H4
Sun Jan 27, 2008 5:59 pm
Quoting N231YE (Reply 18):
Pity a four-foot-thick wing is there, instead.  Wink
Personally, I like the feeling of floats and tundra tires beneath my seat, but rarely can Piper pilots relate to such coolness.
 biggrin
2H4
Pe@rson
Sun Jan 27, 2008 9:41 pm
Thanks 2H4 and ZBB!
I could afford 2 lessons per month in winter, spring and autumn, and either 3 or 4 per month during the summer. Thus, I could hopefully obtain my PPL in 2 years (based on about 50 lessons). That isn´t, I suppose, too bad.
I´d probably choose the C152 for training over the PA28.
Of course, I need to get my CAA-approved medicial before I proceed – and I´m hoping my eyesight (I wear contacts) will be acceptable.
Now, I´m British and would be training in the UK. Despite most replies from Americans and Canadians, I´d appreciate your answers to the following questions:
1) I´d probably choose a flying school at East Midlands Airport (close to where I´ll be living from this September). It´s a relatively busy airport, with medium-sized jets. Would that environment be OK for training?
2) Once I´m qualified, what single-engine aircraft would I be permitted to fly? I´m confused about this.
Anyway, looking ahead, I´m hoping, if all goes to plan, to gain my night-, IMC-, and multi-engine ratings in about the next 5 years. Ambitious, especially as I haven´t yet even begun my PPL, but that´s what I´m presently thinking about for the longer-term. Of course, that´s some distance away.
Cheers all!
James.
2H4
Sun Jan 27, 2008 11:18 pm
Quoting Pe@rson (Reply 20):
 highfive
I think it depends a lot on the number of operations per hour or per day. If it's fairly busy, you'll likely end up spending a lot of time and concentration dealing with traffic. Looking for other airplanes, extending your downwind, holding short on the taxiway, etc. While these are all good things to learn and become proficient at, I suspect they would intrude upon your learning the fundamentals.
That said, just have a chat with one of the local instructors. They'll know. It could be that they take primary students up all the time, and simply hop over to a sleepy airfield nearby. Regardless, I'm sure they've got a system figured out. A flight school that trains primary students wouldn't be in business otherwise.
Not sure on the regs on your side of the pond, but over here, your PPL will qualify you to fly any single-engine propeller-driven aircraft under 12,500 pounds, with some exceptions:
- If you want to fly an airplane with retractable landing gear, you'd need to do a bit of training and get a "complex" endorsement.
- To fly an airplane with over 180hp, you'd need to get a "high-performance" endorsement.
- To fly an airplane with a tailwheel, you'd need a tailwheel endorsement.
- To fly a pressurized airplane, you'd need a "high altitude" endorsement.
Oh, and for the record, the fabric Pipers are cool, and are generally excluded from my snarky anti-Piper remarks.  Wink
2H4
N231YE
Sun Jan 27, 2008 11:42 pm
My condolences  wink
Pe@rson
Sun Jan 27, 2008 11:44 pm
Thanks, folks.
Quoting N231YE (Reply 22):
My condolences
LOL. I am presently basing my preference on one thing: money.  Big grin When I need a more poweful machine, I´ll upgrade. But for training, slow and cheap are good. :P
2H4
Mon Jan 28, 2008 12:02 am
Quoting Pe@rson (Reply 23):
So are effective flaps.  biggrin
2H4
Scooter01
Mon Jan 28, 2008 12:09 am
Quoting 2H4 (Reply 24):
-Ever flown a Piper Colt?
Scooter01  duck
aircatalonia
Mon Jan 28, 2008 1:52 pm
I just arrived from the airport and loved it too.
Very easy to fly.
Agreed 100%. Plus I was very lucky with the weather today: clear and winds calm.
I am already looking forward to my next flight.  Smile
Users browsing this forum: Google [Bot], stlgph and 2 guests
