surfrider1978
Airports That May Be Cursed
Fri Feb 29, 2008 6:32 pm
I was thinking about airports that have quite a bit of incusions or incidents and wonder if some airports carry a hex over them. One that comes to mind to me is BUR.
Famous B6 incident of the sideways nosegear - diverted to LAX after takeoff
WN sliding through the fence onto Hoolywood Way and into the Chevron station
WN losing a tire on takeoff, tire rolling into a UA belt loader slightly damaging the UA 733 at the gate
WN flight, I believe in 1995 that was BUR-LAS and diverted to ONT for belly landing after the gear was inop
A-Rods g-4 hitting the new soft barrier installed after the WN incident.
Some airports seem to have alot of incidents ties to them.
LAX seems to have alot of fateful flights originate there.
Swissair crash off long island
Egyptair crash into atlantic
TWA 800
lijnden
RE: Airports That May Be Cursed
Fri Feb 29, 2008 6:49 pm
You mean JFK instead of LAX...
SR111 was a JFK-Geneva flight
Egyptair was also JFK-Cairo flight
TWA 800 was JFK-CDG
Be kind to animals! Next trip: ORF-ORD-NRT-IAD-ORF
surfrider1978
Fri Feb 29, 2008 6:55 pm
Quoting Lijnden (Reply 1):
They all originated at LAX before JFK
dtwclipper
Fri Feb 29, 2008 7:14 pm
Quoting Surfrider1978 (Reply 2):
SR 111 did not originate in LAX.
Also, the aircraft used for TW 800 arrived at JFK from ATH as TW 881 at 1638.
[Edited 2008-02-29 11:20:38]
Compare New York Air, the Airline that works for your Business
zTagged
Fri Feb 29, 2008 7:27 pm
Superstitious! I wouldn't quite call these airports 'hexed', as a metric fuckton of traffic goes through them every day, so I'm sure incidents are bound to happen. JFK and LAX especially fit this profile. I'm sure if you did a ratio of # of incidents per year to # of flights per year, and compared it to another airfield (Let's use PIT), I'm sure you'd find the ratios are fairly similar to some extent.
Something awful.
bruin787
Fri Feb 29, 2008 7:57 pm
Quoting Surfrider1978 (Thread starter):
waaaaa?
LAX has been the final destination for a lot of fateful flights, 3 of the 4 9/11 flights for example, SQ006, and both 191's for AA and DL, etc. But in terms of origin, after Egypt Air 990, I think you have to go back to 1979 for the next one.
http://taxiwayalpha.blogspot.com
us330
Fri Feb 29, 2008 8:12 pm
It's not an issue of these airports being cursed in regards to terrorist attacks. It's just that terrorists would likely prefer to attack flights bound or leaving from airports like LAX and JFK because they are big markets and will garner lots of attention.
In regards to non-terrorist incidents, I am willing to bet that if you looked at the data analyzing the flight records at all the major airports in the world, the odds of any one flight crashing are probably around the same--basically, the law of averages.
roseflyer
Fri Feb 29, 2008 8:26 pm
Burbank has a short runway, so diversions will go to other airports nearby with longer runways and better emergency facilities if pilots declare an emergency.
I also think Burbank might be well covered since it is in LA and the media can easily pick up on it. The same stories wouldn't come out of a similarly sized airport out in Kansas since no one would care.
USADreamliner
Fri Feb 29, 2008 8:30 pm
Quoting Bruin787 (Reply 5):
So?
all airlines should stop flying to LAX? Or maybe besides the air marshalls , airlines should carry an exorcist too?
surfrider1978
Fri Feb 29, 2008 8:37 pm
Quoting USADreamliner (Reply 8):
Okay, now you are going way overboard, were just speculating a superstition not saying the airports should close or clamp down on flights to/from these places
krje1980
Fri Feb 29, 2008 10:05 pm
And let's not forget Oceanic Flight 815. . .
Sorry, couldn't resist  Wink
staralliance38
Fri Feb 29, 2008 10:47 pm
In the development of DEN, the airport had a lot of controversy from the runway patterns to the cornerstone. You can look on this site:
www.anomalies-unlimited.com/Denver_Airport.html
Roar, lion, roar
AF340
Sat Mar 01, 2008 4:16 pm
Quoting Krje1980 (Reply 10):
 rotfl
Oh man, I was just about to put that in.
Nice!
Liam spin
PlunaCRJ
Sat Mar 01, 2008 5:12 pm
Isn´t (or at least wasn´t at some point) BKK haunted?
vhqpa
Sun Mar 02, 2008 12:58 pm
I could be completely wrong but wasn't that flight ONT-JFK ?
Vhq
"There you go ladies and gentleman we're through Mach 1 the speed of sound no bumps no bangs... CONCORDE"
PlunaCRJ
Sun Mar 02, 2008 5:08 pm
Quoting Vhqpa (Reply 14):
But the grand arrival occured at LAX.
burnsie28
Sun Mar 02, 2008 7:01 pm
Denver is supposidly cursed because they built over a indian burial ground and found bodies, they also managed to bury a front-end-loader...
Users browsing this forum: No registered users and 4 guests
