LHR T5 Connection Question.
Sat Apr 12, 2008 12:00 pm
I will this summer go for LAX with BA through LHR from ARN. My flight from ARN arrives 09:05 and the flight to LAX departs at 10:05. Will I make it to the LAX flight?? And from which terminal will the LAX flight depart from and which will I arrive in?? Either T5 or T5b.
Any help is appreciated.
kubik
RE: LHR T5 Connection Question.
Sat Apr 12, 2008 3:03 pm
Hi,
as far as I can remember if you clear flight connections and security 35 minutes before LAX departure you should be fine. The long haul flights usually departs from T5b.
Kubik
Sat Apr 12, 2008 3:40 pm
Quoting Kubik (Reply 1):
How do I transfer to T5b?? Will I walk or is it trains??
kubik
Sat Apr 12, 2008 5:06 pm
Quoting B747forever (Reply 2):
You will have the pleasure to use a train in between the terminals.
Kubik
Sat Apr 12, 2008 5:10 pm
Quoting Kubik (Reply 3):
That is nice. So 1hr, what do you think, is it to tight to make the connection??
kubik
Sat Apr 12, 2008 5:27 pm
I definately think that this is tight connection. I would really allow a bit more time unless you like the adrenalin rush of making the connection. Another point is that you will not have much time to enjoy this beautiful terminal and plane spotting which is all around.
Kubik
