jcchristie
Most Powerful And Largest Engine Ever
Thu Aug 28, 2008 11:58 pm
What is the most powerful engine and the largest engine ever put on an airplane? My guess is the GE90, but that has been around for a while.
nomadd22
RE: Most Powerful And Largest Engine Ever
Fri Aug 29, 2008 12:06 am
It's still the GE90-115. The 777-300 is still the most airplane per engine, so they haven't needed anything more yet.
Anon
cal764
Fri Aug 29, 2008 12:12 am
GE90-115B's on 777F as well, correct?
1. Fly to Win 2. Fund Future 3. Reliability 4. Work Together CO: Work Hard, Fly Right...
timz
Fri Aug 29, 2008 12:49 am
As long as you define "powerful" to mean "greatest sea-level static thrust". If you actually mean power then it can get complicated.
T prop
Fri Aug 29, 2008 1:37 am
This one?
Photo © Georg S.
tdscanuck
Fri Aug 29, 2008 5:31 am
Quoting CAL764 (Reply 2):
GE90-110B1
Same engine, different programming plug.
Tom.
EA772LR
Fri Aug 29, 2008 1:57 pm
Certainly the GE90-115B, and probably will be for a along time. Can't beat it!
"During its testing, the GE90-115B set numerous aviation records, including reaching a sustained record 127,900 lbs. of thrust during initial ground testing at GE's outdoor test facility near Peebles, Ohio."
http://www.geae.com/engines/commercial/ge90/ge90-115b.html
Photo © Jean-Charles Sautaux
We often judge others by their actions, but ourselves by our intentions.
Blackbird1331
Fri Aug 29, 2008 6:33 pm
Since the space shuttle flies like an aircraft. I go with the shuttle engines.
Cameras shoot pictures. Guns shoot people. They have the guns.
CrimsonNL
Fri Aug 29, 2008 6:49 pm
What about the biggest Piston engine? For aircraft that is.
aero145
Fri Aug 29, 2008 6:51 pm
Quoting Blackbird1331 (Reply 7):
While it flies like an “aircraft” (actually a glider which only goes down, not up like gliders do usually in good conditions), it’s got no engines. It only uses engines while launching, and not more inside the Earth’s atmosphere.
So, the Rockwell’s don’t count IMO.
Speedbird741
Fri Aug 29, 2008 7:13 pm
How about before the -115b or any of the ge90's....which one was the most powerful ?
Speedbird741
Boa noite Faro, Air Portugal 257 climbing flight level 340
Norcal773
Fri Aug 29, 2008 7:14 pm
Quoting Nomadd22 (Reply 1):
You mean the 77W or 777-300ER.
If you're going through hell, keep going
tjwgrr
Quoting CrimsonNL (Reply 8):
The 36 cylinder 5000 hp Lycoming R-7755, although it was never mass-produced.
The largest mass-produced was the 28 cylinder 4300 hp Pratt & Whitney R-4360.
[Edited 2008-08-29 12:16:03]
Direct KNOBS, maintain 2700' until established on the localizer, cleared ILS runway 26 left approach.
Norcal773
Fri Aug 29, 2008 8:00 pm
Wh do I have a feeling PM will find a way to put some spin on how the GE-90 isn't the most Powerful Engine out there?  wink
Stitch
Fri Aug 29, 2008 8:07 pm
Quoting Speedbird741 (Reply 10):
How about before the -115b or any of the ge90's....which one was the most powerful?
Well the P&W JT9D-7R4H1 on the A300 produced 56,000lbs of thrust. That was the most powerful Pratt before the PW4xxx series. The PW4168 was the most powerful model not designed for the 777, rated at 68,000lbs for the A330 family.
Then there is the Trent RB211-524H(-T) at 60,600lbs for the 747-400 and 767-300. And the Trent 772 at 71,000 on the A330-300.
And the GE CF6-80E1-A3 at 70,000lbs for the A330 family.
[Edited 2008-08-29 13:09:05]
OldAeroGuy
Fri Aug 29, 2008 8:18 pm
Quoting Stitch (Reply 14):
Don't forget the PW4098 at 98K lb. A lot of thrust but unpopular because of its weight and SFC.
Stitch
Fri Aug 29, 2008 8:19 pm
Quoting OldAeroGuy (Reply 15):
True, but I thought we were discussing engines not used on the 777 program.
Speedbird741
Fri Aug 29, 2008 8:50 pm
Yeah i thought of the trent 700, but i think i came after any of the ge90 series engines right ?
Speedbird741
Stitch
Fri Aug 29, 2008 9:28 pm
Quoting Speedbird741 (Reply 17):
It may have. I have a PDF of all the commercial engines currently in service, but it does not have their date of service entry.
rb211tristar
Fri Aug 29, 2008 9:56 pm
Interestingly, I immediately thought of the P&W J58 (even though it wasn't a commercial application). But I was way wrong... only 32,000lbs each.
Blackbird1331
Fri Aug 29, 2008 10:38 pm
Think of the "Gimly Glider". The engines got it up, gravity pulled it down. The shuttle engines get it up. Pure power.
Stitch
Fri Aug 29, 2008 10:56 pm
Quoting Blackbird1331 (Reply 20):
But they are not jets, nor is the Space Shuttle a commercial aircraft,
Now, I suppose we could call the Soyuz platform a commercial vehicle, since civilians can take a trip and actually arrive at a destination and return. Big grin
HSVflier
Sat Aug 30, 2008 1:47 am
i thought i read somewhere where the JSF engine set a world record for the highest sustained thrust for a jet engine during testing. could be wrong but i might have seen it in the guiness book of world records. but for commercial aviation it is definitely the GE90
Flown DL, UA, CO, WN, LH, TZ, WO, AA, US, LO, HA, PX, NW, KE, AB, QR, LX, EE, 5Y
A330323X
Sat Aug 30, 2008 1:50 am
Don't forget the PW4173.
Oh, wait...  Wink
I'm the expert on here on two things, neither of which I care about much anymore.
SpeedBirdA380
Sat Aug 30, 2008 1:59 am
Quoting Norcal773 (Reply 13):
Yeah sure it is the most powerful engine but I am sure Rolls Royce could make an engine as powerful as the GE-90 If the need ever arose.
Stitch
Sat Aug 30, 2008 2:37 am
Quoting SpeedBirdA380 (Reply 24):
They did perform studies on the Trent 8104 (105.000lbs) and Trent 8115 (115,000lbs) for the 777X (77L/77W) program back when Boeing was seeking RFPs to power those models.
YULspotter
Sat Aug 30, 2008 2:44 am
Video on YouTube of a startup of the GE90-115B in case anyone is interested in hearing it.
Awsome sound. To me, it doesn't get much better.
YULspotter
rb211tristar
Sat Aug 30, 2008 4:34 am
Quoting Stitch (Reply 21):
I guess we could specify "turbofan". But before we do that, the Rocketdyne F-1 engines on the Saturn V take the cake at ~1,500,000lbs each.
Oops, edit #2. I just realized the initial post said "airplane". Oh well.
[Edited 2008-08-29 21:37:06]
Norcal773
Sat Aug 30, 2008 7:42 am
Quoting YULspotter (Reply 26):
Isn't that dude walking dangerously close to the engine at start-up?
David L
Sat Aug 30, 2008 9:13 am
But the space shuttle never uses those engines to fly like an aircraft.  Smile
CrimsonNL
Sat Aug 30, 2008 9:19 am
Quoting Norcal773 (Reply 28):
No, he's outside the dangerous zone where he risks getting sucked in. However I hope he's wearing ear protection.
r2rho
Sat Aug 30, 2008 11:57 am
How about turboprops?
The most powerful turboprop ever built is the Kuznetsov NK-12, powering the Tu-95 couter-rotating props at 15000shp.
The most powerful turboprop in the Western world is the new TP400-D6 at 11000shp.
Anyone have an idea about piston-props?
rwy04lga
Sat Aug 30, 2008 12:24 pm
Quoting David L (Reply 29):
The Space Shuttle is an aircraft, but not an airplane. The OP specified 'airplane'.
I've heard, but can't verify, that just one of the STS main engines could generate the electricity needs of New York state (not city)!
Does anyone know for sure?
Just accept that some days, you're the pigeon, and other days the statue
OldAeroGuy
Sat Aug 30, 2008 2:17 pm
Quoting Stitch (Reply 16):
No, just non-GE90's.
Blackbird1331
Sat Aug 30, 2008 9:09 pm
Let's strap a couple of these babies on a 777 and see what happens. NYC to LA in 3 minutes. Smile
jacobin777
Sat Aug 30, 2008 9:20 pm
Quoting Tdscanuck (Reply 5):
GE90-110B1
..what a monster!  Wow!
MyAviation.net photo:
Photo © Jacobin777
"Up the Irons!"
Stealthz
Sat Aug 30, 2008 9:31 pm
Quoting R2rho (Reply 31):
See reply 12
jetjeanes
Sat Aug 30, 2008 9:46 pm
I will say this, there is one on a test bed in china now That has been running nonstop for 14 months. the other was brought down. India provided much of the equipment and a secondary engine on a testbed went down after 8 months. These are supposed to be some new type of trent engines RR.. This is about all he would tell me. I had questions like oil ect , of course and unlimited supply of fuel and in broken english the pil is put in through hoses while the engine is running.. They can pull the engine up on a website and check it from 7,000 miles away,,, very odd. Some of the equipment came from the us to india and back to china,and it was huge in crates as many of the componets could barley fit in an 18 wheeler , and flown ups to madras
i can see for 80 miles
Viscount724
Sat Aug 30, 2008 11:10 pm
Not an aircraft engine but still impressive -- world's most powerful piston engine, a 14-cylinder diesel powering the largest container ship, the Emma Maersk. The engine is 89ft long, 44ft high, weighs 2300 tons (equiv. to four A380s at MTOW), displaces over 1.5 million cu. in (25,480 liters) and generates 109,000 hp and 5.6 million lb. ft. of torque.
http://www.youtube.com/watch?v=Dz1f1C39_7g
The ship it powers:
http://www.youtube.com/watch?v=2oRlthTwEEM&feature=related
More on the engine:
http://www.emma-maersk.com/engine/Wartsila_Sulzer_RTA96-C.htm
jetmech
Sun Aug 31, 2008 2:55 am
Quoting Jcchristie (Thread starter):
I'm gonna have to go with the GE90-115B as the most powerful and physically largest engine fitted to an airplane.
Quoting RB211TriStar (Reply 27):
Apparently, each Space Shuttle solid rocket booster has 1.8 times the thrust of a single Rocketdyne F1.
http://en.wikipedia.org/wiki/Space_Shuttle_Solid_Rocket_Booster
Quoting Rwy04LGA (Reply 32):
Each SSME puts out 181,736 kg (400,000lb's) of thrust. The exhaust gas velocities are 4,000m/s and 3,650m/s in a vacuum and at sea level respectively. Taking the difference between exhaust gas velocity and vehicle velocity to be 3,650m/s at launch initiation, one would need an exhaust gas mass flow rate of about 488.45 Kg/s ( 1075 lb/s) to produce this amount of thrust
http://en.wikipedia.org/wiki/Space_shuttle_main_engine
The kinetic energy put into the exhaust gases per second is around 3,253,687,563 J, which is a power output of 3,254 Mw. As far as I can tell, the total amount of electricity generated for New York state in 2006 was 142,265,432 Mwh, or an average rate of 16,240,346,121 watts ( 16,240 Mw ). Thus, a single SSME should be able to supply about 20% of the total average electricity needs of New York state when running.
http://www.eia.doe.gov/emeu/states/h...u/use_eu_ny.html&mstate=NEW%20YORK
http://www.eia.doe.gov/cneaf/electricity/st_profiles/new_york.html
I'm reasonably sure these calculations are somewhere in the ballpark, however, according to this reference, I may actually have significantly under-calculated the power output of the SSME. This reference gives the ( peak? ) power produced by a single SSME at 9,400 Mw.
http://en.wikipedia.org/wiki/SSME_energy_and_power_relationships
My calculation considered the KE of the exhausts gases only. This reference includes the acceleration of the propellants into the combustion chamber, and the heat release of these chemicals when combusted.
Thus, according to this reference, a single SSME can provide 58% of New York states average electricity needs. Three SSME operating simultaneously could thus easily supply New York State's average electricity needs, if we assume a total peak output from the three engines of 28,200Mw.
The peak generation capacity for New York state appears to be around 39,551Mw. Thus, the three SSME operating simultaneously at their peak power outputs could supply 71% of the peak power consumption of NY state.
Regards, JetMech
autothrust
Sun Aug 31, 2008 3:31 am
Maybe also worth to be mentioned:
The RD-170 is the world's most powerful multi-nozzle multi-chamber liquid bipropellant rocket engine.
1,776,665 lbs or 257,000 hp (192 MW) the equivalent of three nuclear ice breakers.
“Faliure is not an option.”
rwy04lga
Mon Sep 01, 2008 3:19 am
Quoting JetMech (Reply 39):
Thanks JetMech!
EA772LR
Mon Sep 01, 2008 5:14 am
Quoting Viscount724 (Reply 38):
That is just incredible  Wow! On a similar note, the GE90-115B at full thrust has an equivalent 100,000 horsepower per engine!! Unbelievable amount of power and exhaust temperatures...
The Beast:
http://ge.ecomagination.com/site/cn/media/ge90/zoom-01.jpg
Quoting AutoThrust (Reply 40):
The Saturn V had over 7,000,000lbs of thrust (combine of all engines)...that was literally Earth shaking...
AirbusA6
Mon Sep 01, 2008 5:40 am
Just a thought, but unless Y3 turns out to be a sigmificantly larger twin than the 77W, will there in the future be anything more powerful than the GE90-115B? The A3510, being lighter offers nearly as much performance with considerably less power requirement, and any future Y3 will certainly use as much weight saving as possible?
it's the bus to stansted (now renamed National Express a6 to ruin my username)
jetmech
Mon Sep 01, 2008 3:08 pm
Quoting Rwy04LGA (Reply 41):
Thanks JetMech!
No worries. Apparently, when the first stage of the Saturn V is at full song, it could supply the entire eastern seaboard of the US with its electricity requirements. The combined thrust of the Saturn V first stage reaches a maximum of;
"9.18 million lbf (40.8 MN) at T 135 seconds"
after lift off. Apparently, the maximum thrust of an individual SSME, and the equivalent power is;
"2.089 MN (470,000 lbf)" where "each SSME is producing over 9.4 GW (12.6 million horsepower)"
thus, the combined maximum thrust and equivalent power of three SSME is 6.267 MN, and 28.2 Gw ( 37.8 million hp ) respectively. Using thrust as a very rough scaling factor, the Saturn V first stage thrust of 40.8 MN is equivalent to 183.59 Gw ( 246.09 million hp )
http://en.wikipedia.org/wiki/Saturn_V#S-IC_thrust_comparisons
Quoting EA772LR (Reply 42):
It may even be more than that. I have seen the figure of 145,000hp been mentioned.
http://www.geae.com/education/theatre/ge90/
Regards, JetMech
[Edited 2008-09-01 08:09:51]
richm
Sat Sep 06, 2008 7:16 pm
YULspotter
That's cool. I wish my car sounded like that, I'm sure the neighbors would love to hear that every morning!  Silly
Users browsing this forum: bohica, Pe@rson and 2 guests
