flyf15
Any Two Airports That Are The Same?
Thu Oct 30, 2008 9:57 pm
Does anyone know of any two airports that have the exact same design? Obviously, aside from those that are small and are nothing but a runway... I mean those with the same runways, taxiways, etc. When I think about it, it seems amazing to me that essentially every airport in the world is unique.... I can't think of any two airports that look the same. Maybe two air force bases?
B6JFKH81
RE: Any Two Airports That Are The Same?
Thu Oct 30, 2008 10:26 pm
I wouldn't be surprised if there are "sister" airports. But when it comes to airport design, it is very difficult to find places where conditions are so close to one another where the airports would be designed the exact same way (i.e.: dominating weather trends, elevation, terrain, etc.). As far as terminals go, it is a possibility that there are some that were designed by the same person/company and are very much alike.
As for military or former military airports, you will see a large trend from the WWII era where many had a triangular design which optimised the possibility of having a reduced crosswind component for departing and landing aircraft because you had runways pointing in lots of directions.
I'm interested in seeing the responses!  bouncy
ANITIX87
Thu Oct 30, 2008 10:29 pm
The design around with ATH, SIN, ATL, and other airports are based is quite common. Two parallel runways with the terminals in the middle. However, no two of those will be identical in terminal layout, runway direction, etc.
All the major NYC airports (LGA, EWR, JFK) have at least one runway that faces 4/22. LGA and JFK also have runways oriented at 13/31, and EWR has 11/29.
EWR and LAS have similar layouts though I don't know the exact directions of the runways at LAS.
TIS
57AZ
Fri Oct 31, 2008 1:20 am
There were a bunch of military training airfields constructed in the middle and far west-many of which were abandoned after WWII. Some still survive as operating airfields. Google Abandoned Airfields and you'll be led to them.
"When a man runs on railroads over half of his lifetime he is fit for nothing else-and at times he don't know that."
LipeGIG
Fri Oct 31, 2008 2:03 pm
Quoting Flyf15 (Thread starter):
In Brazil , Infraero (which manages major airports) has a few years ago a closer "default" design for it's terminals. POA and FOR are very similar. SDU new terminal is an improved "copy" as well as REC.
New York + Rio de Janeiro = One of the best combinations !
Cubsrule
Fri Oct 31, 2008 3:22 pm
Chile immediately sprang to my mind... most of the airports have a single runway with the terminal off of the single parallel taxiway. Until a couple of years ago, even SCL had this design. CJC (whose runway is 10-28) is a notable exception.
Another pattern that you frequently see in the States is the pattern where the runways form a U and the terminal sits inside the U. CLT, CVG SDF, and MSP all have this pattern-- and CVG has added and CLT is adding a third parallel runway off to the west. IND will also have this pattern once the new terminal opens.
There's also the PIT and RDU design, where the terminal sits between parallel runways and a crosswind runway sits off in the distance somewhere.
jcchristie
Fri Oct 31, 2008 5:32 pm
SFO and LGA look very similar, although SFO has 2 more runways
dalb777
Fri Oct 31, 2008 7:21 pm
Airports in the Miami area are pretty similar:
MIA:
Photo © Ray Harvey
Photo © Stuart Middleton
FLL:
Photo © Ryan Kaskel
Photo © Ron Peel
OPF:
Photo © Andre Oferta
Geaux Tigers! Geaux Hornets! Geaux Saints! WHO DAT!!!
isitsafenow
Fri Oct 31, 2008 8:00 pm
Quoting Dalb777 (Reply 7):
Now, note the runway layout of West Palm Beach airport compared with what you have shown.
safe  scratchchin
If two people agree on EVERYTHING, then one isn't necessary.
