AmricanShamrok
1-hour Connections At CDG
Sat Aug 08, 2009 12:24 am
I'm looking at flights between SNN and ORD and AF has a 1hr layover between WX5081 and AF50. Both flights operate into/from Terminal 2E. Would 1 hour be enough time to connect? Thanks.
HT
RE: 1-hour Connections At CDG
Sat Aug 08, 2009 5:50 am
Quoting AmricanShamrok (Thread starter):
Without the need to change terminals you should be okay.
Only a extra security check is likely.
-HT
WAC
Sun Aug 09, 2009 4:54 am
No problem as long as flight from SNN is not more than 45 mins late.
EI320
Sun Aug 09, 2009 10:16 am
You should be fine. There is a bus ride from the CityJet stands to 2E, which takes about 10mins, leaving you with roughly 45 mins when you reach the terminal. You won't have much time to spare.
goldorak
Sun Aug 09, 2009 4:28 pm
Yes, no problem as both flights will be in term 2E. In any case, if your flight from SNN was late, an AF agent will wait for you at the exit of the plane to bring you directly to your ORD flight. Enjoy !
AmricanShamrok
Sat Aug 15, 2009 5:00 pm
Ok, thanks for the replies all!
Users browsing this forum: longhauler, nicode, theobcman and 2 guests
