B6Contrails
Longest Embraer 190/170 Flights
Fri Sep 25, 2009 12:16 am
Quick question, what are the longest E190/170 flights and who are they operated by
Could be either by time or distance. Thanks!
J
DesertFlyer
RE: Longest Embraer 190/170 Flights
Fri Sep 25, 2009 12:38 am
Per a recent discussion, B6 operates JFK-SLC with the E190 now which is 1723nm. I think the published range for a E190AR is 2400nm so there may be airlines pushing them further.
PPVRA
Fri Sep 25, 2009 12:40 am
YYZ-SEA and IIRC YYZ-PHX, off the top of my head.
"If goods do not cross borders, soldiers will" - Frederic Bastiat
PlymSpotter
Fri Sep 25, 2009 12:43 am
I believe that Royal Jordanian were supposed to be operating flights to Western Europe with their Embraers, BRU rings a bell, and that would be pushing five hours and completely maxing out its range. I'm sure I read it on here, so I expect somebody will be along to confirm or deny it, but I don't have the time to check myself right now.
Dan  Smile
rafflesking
Fri Sep 25, 2009 12:54 am
DL was running CMH-LAX a few years back with the E-jets which is almost 2000 miles.
Viscount724
Fri Sep 25, 2009 12:55 am
Quoting PPVRA (Reply 2):
AC:
YYZ-SEA 1791 nm
YYZ-PHX 1630 nm
YYZ-YYC 1628 nm
YYZ-YEG 1607 nm
LAXintl
Fri Sep 25, 2009 1:33 am
B6 did LGB-IAD earlier this year.
Quoting Rafflesking (Reply 4):
I dont recall this at all.
Actualy I dont believe so at all, as there was a small presentation when Frontier(Republic) brought its E170 to LA, as it was the 1st time the model was ever here.
chrisa330
Fri Sep 25, 2009 1:37 am
Also AC:
YYZ-YLW - 1660 nm
VC10er
Fri Sep 25, 2009 1:59 am
Will the "Lineage" the exec jet version of the E170/E190 have a further range?
The world is missing love, let's use our flights to spread it!
lhcvg
Fri Sep 25, 2009 2:03 am
That was with 738's, at least for a time. I do not recall E-jets ever being used on that route, but I do no at least for a time the CMH-LAX flight was a 738.
EMBQA
Fri Sep 25, 2009 2:08 am
Quoting VC10er (Reply 8):
Oh yea... it carries much more fuel...plus less passengers.
aeromexico757
Fri Sep 25, 2009 2:12 am
AeroMexico Connect operated a flight from DGO (Durango, Mexico) to ORD during the summer season. The flight was about 1600NM.
Aeromexico757
san747
Fri Sep 25, 2009 4:58 am
Though no longer operated, AC ran flights 779/780 (YYZ-SAN-YYZ) on E190s. According to Great Circle Mapper, that's 2157 miles.
Scotty doesn't know...
JQflightie
Fri Sep 25, 2009 5:00 am
BE have a EXT-DBV flight that is operated by a E195 and it is 3804 nm
Next Trip: PER-DPS-KUL-BKK-HKT-CNX-BKK-SIN-PER
RJLover
Fri Sep 25, 2009 5:04 am
Last year (or maybe the year before that) AC was flying YYJ-YYZ with the E190. We currently fly YYZ-DFW with the E175, at 1042 miles. I'm not sure how that stacks up to other E175/170 flights, or if that is our longest.
Last Flight(s): YHZ-YHM-YUL-YHZ Next Flight(s): YYZ-MAN // MAN-YYZ
indywa
Fri Sep 25, 2009 5:51 am
This one never happened. CMH-SLC, yes I believe so. I think our current long runs are ORD-YEG and YOW-DEN on S5.
Fri Sep 25, 2009 7:48 am
Quoting JQFlightie (Reply 13):
EXT-DBV is 1016 nm per Great Circle Mapper........
TurkishWings
Fri Sep 25, 2009 8:51 am
I am flying an ERJ 190 between London and Tehran on Airline Manager. It's 2389 nm  Smile
Coffee - Tea or Me?
oly720man
Fri Sep 25, 2009 11:13 am
Quoting PlymSpotter (Reply 3):
AMM-BUD is the only one I can find, on acars as RJ129/130 and 1215nm.
Also used sometimes on the RJ147/148 to Tunis at 1313nm and 600/601to Muscat at 1280nm.
Carmelo
Fri Sep 25, 2009 2:00 pm
I guess Arkia's E195 operates LLBG-LFPG equals 1948nm (airway route, not point to point)
Carmelo
B6JFKH81
Fri Sep 25, 2009 2:02 pm
IIRC, after the Palin charter ended, B6 flew (ferry) and E190 from somewhere in Alaska to BUF non-stop and that was boasted as the longest E190 flight ever at that time...but that was nearly a year ago.
~H81
laca773
Fri Sep 25, 2009 2:06 pm
B6 uses a E90 on LGB-ORD and that's a pretty good length for a E90. Very comfortable ride too!
longhauler
Fri Sep 25, 2009 3:30 pm
Quoting EMBQA (Reply 10):
How much fuel does it carry?
That was always a gripe of mine of the E190. Not how much fuel the aircraft could lift, but how much it could carry. The E190s tanks max out at about 12,900 Kgs under standard conditions, but quite often with tanks full, on a long flight, you are still 3000-4000 Kgs under max take off weight.
If the engineering has been done to actually have larger tanks in the 190/195 wings, that alone would do a lot to increasing the aircraft range.
PlymSpotter
Fri Sep 25, 2009 4:17 pm
Quoting Oly720man (Reply 18):
Maybe it was that then. It's a comfortable aircraft, so I wouldn't mind long flights in it.
Dan  Smile
johnmke
Fri Sep 25, 2009 4:27 pm
Quoting Aeromexico757 (Reply 11):
That aircraft flew full every flight, and coulden't hold half the bags.
a340crew
Fri Sep 25, 2009 4:50 pm
Last year US was running a E190 PHL-DEN on one of the daily flights. Not sure if it still is running it.
nyc2tlv
Fri Sep 25, 2009 5:06 pm
Quoting Carmelo (Reply 19):
The longest route I found IZ using the Embraer 195 on is TLV-TBS. On the flights to CDG and BCN they use a Boeing 757-200.
nyc2tlv
Fri Sep 25, 2009 5:08 pm
Quoting NYC2TLV (Reply 26):
This could change though as IZ is going to restart service to GYD and if they use that aircraft then it will be longer than TBS.
Samurai 777
Fri Sep 25, 2009 6:11 pm
Quoting Viscount724 (Reply 5):
AC:
YYZ-SEA 1791 nm
YYZ-PHX 1630 nm
YYZ-YYC 1628 nm
YYZ-YEG 1607 nm
Where did get these figures from? YYZ-YEG and YYZ-YYC aren't even that long!
According to the Great Circle Mapper, YYZ-YYC and YYZ-YEG are both 1456 nm. The first two, YYZ-SEA and YYZ-PHX are correct, though.
But I think you meant YUL to Calgary and Edmonton, because the last two figures are correct if you meant YUL-YYC and YUL-YEG.
ODwyerPW
Fri Sep 25, 2009 8:24 pm
Question.
Can the E195 hold one suitcase and one small carry one and one personal item for every passenger?
learning never stops.
SNCNtry32
Fri Sep 25, 2009 11:14 pm
Northwest Airlink/Delta Connection/Compass does DTW MTY which is about 1500 miles I beleive. Also worth noting we have done MSP YVR, MSP SEA, and talk was that we were going to to MEM SAN but it went to an airbus.
Long Live Memphis!
live2fly83
Fri Sep 25, 2009 11:29 pm
after the demise of the Palin campaign B6 flew that chartered 190 from ANC-BUF I believe
"come fly with me"
WROORD
Fri Sep 25, 2009 11:35 pm
LO flies WAW/KRK-TLV and Royal Jordanian sometimes flies AMM-WAW.
EMB170
Fri Sep 25, 2009 11:39 pm
I know MS was beginning to operate their less popular EU routes with E70s. CAI-BUD rings a bell.
IND ORD ATL MCO PIT EWR BUF CVG DEN RNO JFK DTW BOS BDL BWI IAD RDU CLT MYR CHS TPA CID MSP STL MSY DFW IAH AUS SLC LAS
steex
Fri Sep 25, 2009 11:52 pm
AC:
YYZ-SEA 1791 nm
YYZ-PHX 1630 nm
YYZ-YYC 1628 nm
YYZ-YEG 1607 nm
Regarding AC, they also fly YYC-EWR on the E90 at 1737 nm.
icebird757
Sat Sep 26, 2009 12:02 am
Quoting LACA773 (Reply 21):
Actually LGB-ORD is operated by a A320. The E190 stopped on that route quite a while ago.
LGB....where you can watch the grass grow because the traffic is so slow.
phllax
Sat Sep 26, 2009 3:11 am
Quoting LHCVG (Reply 9):
Until YX/RP started MKE-LAX, there was no regularly scheduled E170/190 service to LAX.
indywa
Sat Sep 26, 2009 4:57 am
Quoting Phllax (Reply 36):
I believe RW flew out of LAX for F9 on the 170 if I recall correctly.
pilotpip
Sat Sep 26, 2009 5:22 am
Some of the longer flights I've done in the 170
PIT-DEN (1120mn)
ORD-GEG (1300nm)
ORD-YHZ
ORD-YEG
DEN-ATL
ATL-MTY (we have to stay within 50nm of shore, can't cut across the gulf)
DMI
JU068
Sat Sep 26, 2009 8:22 am
LO also flies the WAW-LCA as well as TLV, but they are not that long, 3h25
Since we are talking about E-jets now, which airline is the biggest operator?
aces727
Sat Sep 26, 2009 11:35 am
Not the longest, but considerably long, CM E190, (PTY-MAO), 1365 nm.
LXA340
Sat Sep 26, 2009 12:12 pm
Quoting JU068 (Reply 39):
AC or United? When considering EM 135/140/145's then probably American Eagle?
[Edited 2009-09-26 05:13:18]
pilotpip
Sat Sep 26, 2009 12:59 pm
I believe Republic is the largest operator. Shutttle and Republic have about 60 170/175s and as of right now I think the 190 count will be 9 but likely climbing.
DMI
mercure1
Sat Sep 26, 2009 1:06 pm
Quoting Live2fly83 (Reply 31):
this past winter Jetblue was operating a E190 LGB-IAD on some wkend redeyes (only eastbound ops). 1973nm
spetouss
Sat Sep 26, 2009 1:22 pm
Baboo flies the E190 from Geneva to Larnaca which is more than 1430 nm.
JU068
Sat Sep 26, 2009 1:54 pm
What about Finnair? What is their longest flight?
RJLover
Sat Sep 26, 2009 4:28 pm
Quoting LXA340 (Reply 41):
AC has a total of 60 E-Jets (45 E190s 15 E175s).
david21487
Sun Sep 27, 2009 6:38 am
CMH-LAX was always on the 737-800 until it was discontinued.
It was CMH-SLC that used to be on the E170. It was crazy weight restricted. It eventually got upgraded to mainline MD90 service, and then downgraded again to a CR7 before it was, like LAX, completely discontinued.
-- Step! Jump! Slide! --
andaman
Sun Sep 27, 2009 2:48 pm
Quoting JU068 (Reply 45):
Must be HEL-IST 1170nm, flying time 3h 20min on E190, both A32X and E190 used on the route.
Chinese cookie in SFO: "You're doomed to a life of forever travelling abroad and to be able to afford it!"
Viscount724
Mon Sep 28, 2009 2:38 am
Quoting Samurai 777 (Reply 28):
AC:
YYZ-SEA 1791 nm
YYZ-PHX 1630 nm
YYZ-YYC 1628 nm
YYZ-YEG 1607 nm
Yes, sorry, the last two should have read YUL-YYC and YUL-YEG.
