skane340
Transfer From LHR-LGW
Sat Oct 24, 2009 9:28 am
Hi,
what are the alternatives for a transfer between LHR and LGW?
Train, buss, etc?
How long is the transfer time?
(The old post is from 2007)
RE: Transfer From LHR-LGW
Sat Oct 24, 2009 11:13 am
There are direct National Express busses, or various train routes. Easiest train, with just 1 change, would be the First Capital Connect to Kings Cross then take a Picadilly Line tube train from there. Quickest would be Gatwick Express to Victoria, take a Circle Line tube to Paddington, then Heathrow Express from there.
http://www.toandfromtheairport.com/heathrow.html
Scroll down to "Airport to Airport".
SA7700
Sat Oct 24, 2009 11:19 am
The following two links should be able to answer your questions:  Smile
Transfers Between Heathrow & Gatwick Airport
Connecting between Heathrow and Gatwick
SA7700
When you are doing stuff that nobody has done before, there is no manual – Kevin McCloud (Grand Designs)
LHRjc
Sun Oct 25, 2009 12:08 pm
As a local to LHR, and previously LGW, I'd say the main factors in your decision should really be the time at which you will be transferring, and how long you've got to make your connection.
I've got a National Express coach between LGW North Terminal and LHR Terminal 5 before that's taken only 40 minutes; during the morning or evening rush hour this time could more than double, during which times I'd take a train. Although the train is a bit more involved with multiple changes, it'll give you a much more reliable connection time during peak hours than sitting in a traffic jam.
Conversely, on weekends, our wonderful railway and underground systems are often subject to engineering works, delays and cancellations so the coach would be your best bet.
I wouldn't go near a taxi personally as it'll get stuck in the same traffic as the coach. Some of the coaches even have free WiFi if you're that desperate to get on the Internet.
"Our 319's are very reliable. They get fixed very quickly."
skane340
Thu Oct 29, 2009 7:36 am
Thank you for the response... we will be flying during the week, so that puts the train in the best position
lhr380
Thu Oct 29, 2009 10:02 am
I would always take the Bus. No connections to make, just on the bus, then off the bus at the other end. Max journey for me has been 1 hour 20, min just under 40 minutes
