karan69
Heathrow Connection Advice
Tue Oct 27, 2009 7:21 am
Hi All,
I will be landing on VS 20 from SFO into LHR at 11am , and would ideally like to depart on EK 002 at 1345pm,
My question is,
Is a 2hrs 45 min connection enough to check out with bags and again check in on the EK flight or am i pushing my luck incase my flight from SFO is delayed
Or should i go with 9W which departs almost 9 hrs after arrival, making LHR T3 a very boring place to hang out ,
Also VS has said that they will not check my baggage all the way through as i have booked their ticket using miles and my EK or 9W ticket will be on a separate itinerary/PNR
Thanks in advance
Karan
BOCHORA
RE: Heathrow Connection Advice
Tue Oct 27, 2009 8:55 am
I think that you should be fine. Today for instance the flight is around 10 minutes late and this wouldn't be any problem.
You don't have to change terminal and the flight connections centre is fairly quick at T3, IIRC.
I know a big thing is made of changing at LHR but I used to do it from T1 - T4 in 1 hour, yes it would be a rush when flights delayed etc, but manageable all the same.
Also, there is an EK flight at 1635 - would this not be an option too?
All the best.
karan69
Tue Oct 27, 2009 12:28 pm
Hi Bochora,
Thanks for the reply,
Is it possible to do it considering i have to take my luggage out?
the later EK departure does not make sense as it entails a longish wait for me at DXB to catch my flight to BOM
So to conclude, In your opinion i should go for EK instead of spending 9 hrs at LHR for 9W
Karan
T8KE0FF
Tue Oct 27, 2009 2:25 pm
Just so you know, Most of the EK departures in the UK depart and arrive late anyway so theres an extra 40 mins for you  Smile
RJ85 E145 E195 A319 A320 A330 A340 A380 B737 B747 B757 B767 B777 B787 DH4
buck3y3nut
Tue Oct 27, 2009 4:03 pm
Karanji,
that time should be enough for you to connect within T3. Doesn't VS have interline agreements with EK?
golfradio
Tue Oct 27, 2009 7:22 pm
9W has moved to T4 since Oct 14. I traveled via LHR on Oct 15 arriving in T3 by AC and departing T4 by 9W. I actually timed my connection as on my return trip my connection between 9W and AC was only 90 minutes. It took me 40 minutes to transfer from T3 to T4 including the security check at T4.
Bring back the old site.
karan69
Wed Oct 28, 2009 10:40 am
Thank you all for your replies,
Quoting Buck3y3nut (Reply 4):
Yes but only if the entire trip is on one ticket or PNR
Quoting Golfradio (Reply 5):
I assume you could do it in that much time because you did not have your bags to lug around? but 40 mins is really encouraging
Thanks everyone once again i think i will go with EK
Karan
