luckyone
Connecting In SJU
Fri Nov 06, 2009 9:23 pm
Hey folks,
I've got to connect between Delta and American in SJU. The SJU flight leaves at two. The earliest Delta flight arrives at 1230. Is that sufficient time to make a connection with no checked baggage? Thanks in advance for your help.
DeltaRules
RE: Connecting In SJU
Fri Nov 06, 2009 9:34 pm
Assuming you've already checked in for the AA flight, you should be good to go. It'll be a slight walk, but nothing too big.
The three concourses at SJU (AA hub (Gates 1-about 18), CO/B6/NK/IB (20s), DL/US/UA/NW/FL (Gates 31-41) are all joined by a connector walkway. When you get off the DL flight, instead of following the line through the revolving doors to baggage claim, go down the walkway with the view of the ramp. You'll enter the end of the concourse with the 20 gates & then the walkway continues off to the left on toward the AA terminal.
[Edited 2009-11-06 13:35:49]
desertjets
Fri Nov 06, 2009 9:35 pm
Yes.
You can walk the length of the airport airside in <20 minutes if you walk slowly.
