Severnaya
AMS-VIE-LED Short Transit Time
Fri Dec 11, 2009 2:20 pm
Hello,
I'm planning to book my usual trip AMS-LED somewhere in april/may.
After flying KL, LH, SK, FV, SU i think it's time for me to use another carrier on the route. Therefor i'll try out OS with the route AMS-VIE-LED-VIE-AMS.
However the transit time in VIE is only 35 mins. Should this be enough, taking into account that i also have to go through passport control and possible walk some distance to the gate. Or should i not have to worry too much. For your info, i've not been in VIE so far, so i don't have the familiarity with the airport.
What are my 'rights' in case the AMS-VIE leg is delayed so i would miss my connecting flight VIE-LED. It's gonna be all booked on one PNR so OS has to bring me in any case to LED i suppose, but how are they gonna do that? By booking me on a flight via MUC or FRA, or will they bring me only the next day?
Всяк глядит, да не всяк видит.
RE: AMS-VIE-LED Short Transit Time
Fri Dec 11, 2009 4:57 pm
If they let you make the booking, they will basically take resonsibility that you can make connection at VIE. Why do you have to go through passport control again? You can stay 'airside' I suppose and just go to the next gate? You should be able to get your onward boarding pass at AMS, and baggage is labelled through to the final destination.
In case you miss the connecting flight, and there is not a later OS service, expect rebooking via another Star Alliance partner (expect LX or LH) via either one of their hubs.
btw, good choice to take OS; I have so far only very good experience on them!
Severnaya
Fri Dec 11, 2009 5:46 pm
Quoting Airbuseric (Reply 1):
Because AMS and VIE are Schengen, while LED isn't.
Thanks for the info!  Smile After your TR i might consider LX for the next one as well.
Sounds good! I'm looking forward to it as well.
HT
Fri Dec 11, 2009 7:07 pm
Quoting Severnaya (Thread starter):
While it might be legal to make that connection, I personally would not go for it.
While VIE is none of those mega-airports, walking from one end to the other end can be lengthy - and depending on time I also have seen some moderate queues at outbound immigration counters.
Quoting Severnaya (Reply 2):
At ZRH keep in mind that you will have to connect from A-gates to E-gates (aka. Dock Midfield) involving a train ride with passport check before the train ride and new security control after the train ride (unless this security check becomes void when ZRH introduces the new central security check).
In places it resembles one of a Shopping Mall.
The fact that the terminal building has been amended with structure again and again can not be overlooked.
-HT
Fri Dec 11, 2009 7:41 pm
I have the feeling that there should some special passport control point inside the 'airside' area. This will be some shortcut and reduces time significally usually.
If you decide to fly Business Class, you might be able to use a Priority lane.
I'v done several transfers, sometimes also 30 minutes (actually I made a 45 minute transfer at VIE, from a longhaul OS arrival to a European OS flight), and without problems.
Also for ZRH, AMS flight might arrive on the midfield near gates E, disembarking by bus and a drive to terminal A. The walk to terminal E for your onward LED bound flight takes about 10 minutes if you continue walking all the time. But, the airport signs state that it would take longer, it was definitely not the case during my visits.
Remember that, when OS is selling this ticket combination, such a transfer is possible and basically guaranteed by the airline. The only thing needed is some 'rush' by yourself to make sure that the connection is to be made, but from the basics it is possible.
sandrozrh
Sat Dec 12, 2009 12:28 am
Quoting Airbuseric (Reply 4):
All Schengen flights arrive at terminal A  Wink
HT
Sat Dec 12, 2009 8:37 am
Quoting SandroZRH (Reply 5):
I was confused by the original statement too, but as Airbuseric continued "disembarking by bus and a drive to terminal A." I figured that he was referring to the parking positions south of runway 28 where the AVROs usually are parked (if they do not use the apron next to (former) pier B) ...
Slight amendment:
Makes no sense to *walk* while being stuck in the SkyMetro .... D:
There is no option to walk all the way to E-gates. SkyMetro (and currently buses replacing it from E to A) is the only option.
-HT
Severnaya
Sat Dec 12, 2009 3:48 pm
Quoting HT (Reply 3):
Thanks for the heads up!  Smile
I suppose it does like as in FRA.
Yeah that's exactly what i thought off as well, and well, if they mess it up i'll receive an extra leg. Wink
Thanks in any case everybody for sharing the experience, i very much appreciate it.
HT
Sat Dec 12, 2009 8:56 pm
Quoting Severnaya (Reply 7):
OTOH, when getting re-routed at short notice, chances are that there might be a problem with checked luggage ...
-HT
Severnaya
Sat Dec 12, 2009 9:57 pm
Quoting HT (Reply 8):
Well i usually travel light and we have two houses (one close to AMS and one in LED), so clothes and stuff is not really the point as i don't check luggage most of the time.  Smile but thanks anyway, very much appreciated.
planeguy727
Sun Dec 13, 2009 11:47 pm
When I did a short time transfer at VIE (FRA-VIE to VIE-CAI) I was worried - esp. with delayed leaving FRA. I was able to make the connection as they were doing the passport control at the entry to the departure gate area and there was quite the queue. Despite my concerns the OS staff had a list of transfers and were very sure to check on passengers (something I did not expect).
I want to live in an old and converted 727...
Mon Dec 14, 2009 10:39 am
Quoting HT (Reply 6):
Indeed. That was what I meant.
Slight amendment:
I meant 'walking to B-gates', not E *sorry*
I guess the LED flights also leave from the B-gates at ZRH?
HT
Mon Dec 14, 2009 3:52 pm
Quoting Airbuseric (Reply 11):
I just checked: Yes, LX-flights to LED use (original) B-gates (it was B29 today).
-HT
