Vasu
Direct Flights Without Direct Returns!
Mon Jan 04, 2010 9:14 pm
Just a quick question... I hope it makes sense!
Are there any/many flights out there that don't have a direct return flight with the same airline? As in, where a flight goes directly from A to B, but not (directly) from B to A?
Luka
RE: Direct Flights Without Direct Returns!
Mon Jan 04, 2010 9:19 pm
From BEG Jat flies to Malta but there is no return flight. Instead it goes to Tripoli and then straight to Belgrade, so if you want to go from Malta to BEG you have to go via Tripoli or another city.
Viscount724
Mon Jan 04, 2010 9:22 pm
Air Mauritius operates once a week GVA-MRU nonstop. The return flight operates MRU-FRA-GVA. For FRA passengers, it's the opposite where the soutbhound flight stops at GVA and the northbound flight is nonstop. However, the flights are still "direct" meaning "same aircraft" but they are not nonstop in both directions. The "direct" definition includes flights that make intermediate stops.
richardw
Mon Jan 04, 2010 9:23 pm
Aircraft may do this, but the flight may not be available to passengers ie U2 SXF-LGW-VCE-SXF
I think there are more U2 examples including maintenance swap overs for the A320s.
TG may have done BKK-SYD-AKL-BKK in the past.
Also may occur at the summer/winter and winter/summer timetable change overs.
[Edited 2010-01-04 13:26:07 by richardw]
ANITIX87
These are called Triangle Routes, and there are several, though I can't name any with 100% certainty. I believe CDG-LAX-PPT-CDG is one, but it MAY go back to LAX before going to France. I know KLM's AMS-SXM-___-AMS is another, though I don't remember where the stop is.
TIS
David_itl
Mon Jan 04, 2010 9:27 pm
Quoting Vasu (Thread starter):
Like KEF-MAN-GLA-KEF by FI?
Viscount724
Mon Jan 04, 2010 9:35 pm
Quoting ANITIX87 (Reply 4):
Either CUR (Curacao) or BON (Boinaire) depending on the day of the week
02hilliert
Mon Jan 04, 2010 10:27 pm
Monarch are operating the following during the Winter using A330s;
LGW-UVF-BGI-LGW
LGW-TAB-GND-LGW
These are regualarly operated in the summer;
LGW-VOL-JSI-LGW A321-200
MAN-VOL-JSI-MAN B757-200
You will also find that a lot of European charter carriers operate triangular long haul routings. For example, I know that Condor operate the following;
FRA-MRU-SEZ-FRA B767-300
Thomson Airlines and Thomas Cook will also be operating triangular flights, most likely through Caribbean islands, especially Cuba and the Dominican Republic.
Virgin Atlantic are another airline that I belive operate triangles through the Caribbean.
I'm also booked on a tringular routing for February. To travel from Buenos Aires to Ushuaia, I am flying the following;
AEP-USH
and
USH-FTE-AEP
These flights are with Lan Argentina.
[Edited 2010-01-04 14:28:29]
Next Up: Back to the US - Charlotte & Kansas City
LTU932
Mon Jan 04, 2010 10:56 pm
They're called "triangular flights", because the flight path would resemble more a triangle.
PlymSpotter
Tue Jan 05, 2010 2:37 am
Syrian Air's old DAM-MAN-LHR-DAM service comes to mind, it may have routed in reverse order, and I'm not sure if it still flies TBH. They also have some similar routes involving BEY, LTK and ALP.
Air Southwest fly most of their routes in triangular formation, but all of them (IIRC) flip back now and again, meaning direct flights are available in both directions.
AeroSvit do something like KBP-SOF-BEG-KBP.
There are hundreds really.
Dan  Smile
MAH4546
Tue Jan 12, 2010 8:02 pm
AA has daily Miami-Salvador-Recife-Miami and daily (soon 2x daily) Miami-La Paz-Santa Cruz-Miami. In the case of the Bolivia route, La Paz' altitude does not allow an aircraft to take off and make it non-stop to Miami.
United has Chicago-Maui-Kona-Chicago. The runway at Maui combined with the equipment used does not allow the plane to make it non-stop to O'Hare.
JALWays has Tokyo-Kona-Honolulu-Tokyo.
EVA will soon have Taipei-Toronto-Anchorage-Taipei.
a.
SA7700
Wed Jan 13, 2010 3:04 am
On another note.... SA flies JNB-DKR-JFK-JNB on a daily basis.
SA7700
When you are doing stuff that nobody has done before, there is no manual – Kevin McCloud (Grand Designs)
QantasA333
Wed Jan 13, 2010 3:20 am
CX HKG-ADL is direct while their return goes ADL-MEL-HKG.
LHRBFSTrident
Wed Jan 13, 2010 7:05 am
PPT-CDG is an awfully long flight - I believe both TN and AF fly via LAX in both directions
directorguy
Wed Jan 13, 2010 4:24 pm
KLM has several triangular ME routings such as AMS-BAH-AUH-AMS or AMS-BAH-DOH-AMS etc. (they may have been changed/suspended though). They're not entirely uncommon.
Another one is BA's LCY-SNN-JFK-LCY service.
BNAOWB
Wed Jan 13, 2010 5:46 pm
Westbound PR flights LAX-MNL and SFO-MNL have technical stops in GUM. Eastbound PR flights MNL-LAX and MNL-SFO are nonstop.
Wed Jan 13, 2010 6:37 pm
TP fly LIS - MPM - JNB - LIS.
Users browsing this forum: desertjets and 1 guest
