meristem
Angled Lie-flat: Tips On How To Sleep?
Tue Mar 02, 2010 11:50 pm
I'll be on the return leg of a long-haul round trip in a few days. This trip is my first experience with angled lie-flat seats and sleeping at an angle proved a challenge...
If you have successfully slept -- or at least made yourself comfortable -- on angled lie-flat seats, please share your experience...I'd love to have a better flight
AM
Curiosity killed that cat. I still have some lives left.
deltairlines
RE: Angled Lie-flat: Tips On How To Sleep?
Tue Mar 02, 2010 11:53 pm
I tend to curl up into a little ball on the legacy Northwest WBC seats...I've been able to sleep that way before.
Aeroflot001
Wed Mar 03, 2010 3:02 am
On AAs next generation biz class seat which is angled I haven't had any sliding problems that some people report. Basically I but it in almost lie flat its just about in a very flat cradle position. In the fully flat position it seemed as though there was too much lumbar on the lower back so raising the seat slightly did the trick. Hope this helps!
Аэрофлот 001
Искренне Ваш
kiwiandrew
Wed Mar 03, 2010 3:12 am
I think peoples experiences on sloped beds depends on what sort of sleeper they are.
Friends of mine who are , for want of a better word "tranquil sleepers" seem to be fine whether it is sloped or true lie-flat , on the other hand , I am quite restless , and inevitably in the process of tossing and turning I move down the slope at least on the old style QF sloped Skybed ( I think my record was on JNB-SYD where I woke no fewer than 4 times to find myself in a little heap well downhill from where I had started - it wasn't too big a deal , each time I just pulled myself back up to the starting position and went back to sleep - but it definitely was a broken sleep compared to what I get on a lie-flat where I am dead to the world and usually have to be shaken awake for brekkie ) and LH sloped bed in contrast to the true flat of EK and NZ where I have no problem .
skyone
Wed Mar 03, 2010 4:46 am
No problem sleeping in AA business class. Always go to sleep while watching a movie or program. Never had a problem sliding out of the J bed. After years of flying Y on those birds, now I kind of like them a lot, as it is completely different to being in the back of the plane.
MAH4546
Wed Mar 03, 2010 4:53 am
On the AA beds, I sleep on my side and sleep perfectly. No problems "sliding."
Rather than putting it full-flat, I prefer the setting where it has a little notch in the center. You can use this setting by pushing the lie-flat button a second time.
a.
mauiman31
Wed Mar 03, 2010 3:31 pm
Sleep like a baby on AA's 763 seats. I am average height and weight though. Just 5'9" 158 lbs. And sleep on my side. Both those factors probably help. . .
Now wonder if pre-flight Champange, Vodka Tonics, Wine with dinner, with a Cognac finish helps also?
meristem
Sat Mar 06, 2010 1:11 am
Awesome. This helps a lot... I will let you know if I sleep or heap tonight!
Ps: I do think the relaxation of wine, etc may help... And at 5"2' and change, I bet the ergonomics were not considering me as the middle of the curve
vhtje
Mon Mar 08, 2010 8:23 pm
Quoting mauiman31 (Reply 6):
All of the above, I should think...
I only turn left when boarding aircraft. Well, mostly. All right, sometimes. OH OKAY - rarely.
warren747sp
Wed Mar 10, 2010 2:12 am
U can't do it. U are better off flying an airline which offer as close to a true flat bed as possible.
747SP
MAH4546
Wed Mar 10, 2010 6:18 am
Quoting warren747sp (Reply 9):
U do realize that "angled lie-flat" is exactly "as close to a true flat bed as possible," right?
a.
FlyDeltaJets87
Wed Mar 10, 2010 3:52 pm
I recently had the fully Lie-Flat seat on LAX-ATL on the Delta 777-200LR, and I actually found THAT awkward for sleeping because most of the flight, the aircraft was at a slight nose-up angle, and in the fully flat position, my feet were above my head. I slept with the seat almost fully reclined but not in true flat mode. (Granted this was not long haul or even a redeye).
Depends. I've seen some airlines have "176 degree recline". If the airplane is nose-up 2 or 3 degrees, than 176 degrees moves closer to 180 degrees and is essentially "flat", where as with true 180 degree recline, your feet are now above your head at a 2 to 3 degree angle.
"Let's Roll"- Todd Beamer, United Airlines Flight 93, Sept. 11, 2001
readytotaxi
Wed Mar 10, 2010 5:45 pm
Guess there are two camps here, lie flat and at an angle.
Having done both it has to be Flat for me, by far the better and longer sleep.
Best bed BA Club.
Worst bed KLM Business
WildcatYXU
Wed Mar 10, 2010 8:53 pm
Well, I'm an inch taller, 60 pounds heavier and I sleep on my side too. I slept in Lufthansa's business seat like a baby.
However,
All of that (except Vodka tonics, substitute with Scotch on rocks) definitely helped too.
310, 319, 320, 321, 333, 343, 345, 346, 732, 735, 73G, 738, 744, 752, 762, 763, 77L, 77W, 788, AT4, AT7, BEH, CR2, CRA, CR9, DH1, DH3, DH4, E45, E75, E90, E95, F28, F50, F100, MD82, Saab 340, YAK40
