777ER
Crew
Air Canada's Comfort Plus Cabin
Thu May 06, 2010 8:12 am
While looking on ACs web-site, I see that AC have some B763s fitted with Comfort Plus seats instead of normal AC international J seats. I was wondering if AC is thinking of installing comfort plus on their domestic aircraft?
Head Forum Moderator
moderators@airliners.net
Flown: 1900D,S340,Q300,AT72-5/6,DC3,CR2/7,E145,E70/75/90,A319/20/21,A332/3,A380,F100,B717,B733/4/8/9,B742/4,B752/3,B763,B772/W,B789
With: NZ,SJ,QF,JQ,EK,VA,AA,UA,DL,FL,AC,FJ
connies4ever
RE: Air Canada's Comfort Plus Cabin
Thu May 06, 2010 9:54 am
I think there are 3 (?) odd-ball 763s that don't have the international J seats (pods0 installed, but have the older domestic J class seats. IIRC these a/c are deployed on lower-yield routes and the Comfort Class cabin is the domestic J seating sold at a premium over Y, but with Y cabin service.
Kaiarahi
Thu May 06, 2010 12:27 pm
Quoting connies4ever (Reply 1):
They're deployed on lower-yield seasonals - YUL/YYZ - BCN/ATH and YYZ - DUB this summer. Are these the last ex-CP 763s in the fleet?
Empty vessels make the most noise.
longhauler
Thu May 06, 2010 12:35 pm
Quoting Kaiarahi (Reply 2):
No, they are not exCP, they were an oddball lease when capacity was needed.
In the winter, they are used on low yield vacation type markets. The "Comfort Plus" cabin is to compete with Air Transat and its Club product.
Whiteguy
Thu May 06, 2010 4:50 pm
The majority of the AC B763 fleet is ex-CP except for these 3. AC only 6 B763s at the time of the CP takeover.
N43W79
Thu May 06, 2010 8:16 pm
Quoting whiteguy (Reply 4):
Actually Air Canada's 30 763s:
631-636 Air Canada (6)
656-657 Air Canada (2)
658-661 Air Canada (4)
687, 689, 690 Kenya (3) ---> Aircraft with Comfort Plus
637-642 Canadian (6)
645-648 Canadian (4) via other carriers.
681-685 Canadian (5)
pnwtraveler
Thu May 06, 2010 8:23 pm
The comfort plus are lease aircraft as stated above, and were deemed to be shorter term than warranting a full XM upgrade with the layflat J class Pods and full entertainment Y screens. I presume they will be among the first to go when the 787's arrive or shortly thereafter. The seats are the old J Class domestic seats so 6 across and comfortable enough but wouldn't cut it on YYZ to LHR or YVR to Asia.
777ER
Crew
Thu May 06, 2010 10:20 pm
Thanks for the answers so far. I'm looking at booking Vancouver - Toronto on AC later this year and was wondering ig AC had any plans to create a Y+ type product on its domestic/long haul fleet.
Whiteguy
Fri May 07, 2010 3:37 pm
Quoting N43W79 (Reply 5):
Fins 658-661 were actually ordered by CP originally prior to the takeover in 2000. That's why they have GEs instead of PW's and received the AC code. When AC took over CP they only had 631-636 in the fleet.
Quoting 777ER (Reply 7):
They just reconfigured their whole fleet in the XM project, I don't think they're going to do it all over again.
Kaiarahi
Fri May 07, 2010 4:49 pm
Quoting whiteguy (Reply 8):
If you decide to spring for J, make sure you book it on one of the flights from Oz/Asia - YVR - YYZ and you'll get the lie flat pods.
pnwtraveler
Fri May 07, 2010 4:55 pm
With the exception of the couple of 763's that haven't been XM'd the complete widebody fleet has lie flat J Class. So you can have one even on the YYZ to YUL 55 minute route if you choose a widebody.
777ER
Crew
Fri May 07, 2010 8:25 pm
Quoting Kaiarahi (Reply 9):
I would be arriving on NZ and most likly via LAX so I can try the E190
heavy747
Fri May 07, 2010 9:25 pm
Quoting pnwtraveler (Reply 10):
Yes, I have flown quite a few times between YYZ and YUL in a widebody with the international J product.
Aviation Enthusiast - AvgeekYVR - RTW Travel Solutions
beechnut
Fri May 07, 2010 11:57 pm
Actually their code is 767-36NER. Leased from GECAS. The GECAS customer code is 6N
Beech
StarAC17
Sat May 08, 2010 12:49 am
Quoting 777ER (Reply 11):
If you are going to go LAX-YYZ then not likely as that is usually operated with an A319 or A320 and sometimes the occasional 763, however you could get on one from SAN or SNA to YYZ.
If you are planning on flying LAX-YVR then I think that has at least a couple of E190's operating that route each day.
Engineers Rule The World!!!!!
777ER
Crew
Sat May 08, 2010 1:48 am
Quoting StarAC17 (Reply 14):
Yes LAX-YVR. All of NZs codeshares with AC from LAX-YVR are on the E190
Whiteguy
Sat May 08, 2010 7:22 pm
Quoting beechnut (Reply 13):
Where did you get this info? Everything I've read shows 658-661 and 631-636 listed as B767-333s. There are no B767s listed with the 6N code.
Viscount724
Tue May 11, 2010 2:22 am
Quoting whiteguy (Reply 16):
Not sure what aircraft you are referring to, but the 3 763s with the non-standard cabin and door layout and which did not undergo the XM conversion are the 3 767-3YOs, C-GHPD/PF/PH, shown below.
Photo © Thomas Posch - VAP
Photo © Patrick Lundgren
AC's 767-36Ns are C-GHLQ, C-GHLT, C-GHLU, C-GHLV.
Whiteguy
Tue May 11, 2010 4:01 pm
Quoting Viscount724 (Reply 17):
These aircraft are all B767-333s not 36Ns. They were originally delivered to AC in 2001. They may have since been sold to GEACS and leased back by AC but that does not change the original code!
Viscount724
Wed May 12, 2010 12:10 am
Quoting whiteguy (Reply 18):
The fleet list I referred to (Airfleets.net) must have the wrong code.
