AlnessW
JetBlue Airways Boarding Passes
Wed Jun 16, 2010 9:07 pm
Hello everyone,
I will be flying out of Portland International Airport (PDX) next week on JetBlue Airways (B6). I am wondering where I should check in PDX, either at a self-service kiosk, or at a full service counter. I will be checking bags.
The reason why I ask is because I want to know what kind of paper B6 prints their boarding passes on. I've noticed that most airlines don't print on the heavy cardstock ("ATB Coupons"?) anymore. I have also seen pictures of B6 boarding passes that are printed on supermarket-type receipts. When I flew on B6 in July of 2007, they printed on ATB Coupons, but do they still do that? I do not want to be stuck with cheapo "receipt" boarding passes; do they print on these at PDX? Also, what do the self-service kiosks in PDX give you?
Any JetBlue fliers or PDX regular fliers out there that can answer any or all of this?
(BTW, I asked this same question on Yahoo Answers and all people said were things along the lines of: "Does this really matter...?" Odds are if I asked the question, then I do think it matters. Maybe someone here will be more helpful.)
Thank you,
Wilson
[Edited 2010-06-16 14:29:34]
KingFriday013
RE: JetBlue Airways Boarding Passes
Wed Jun 16, 2010 9:32 pm
I've never flown B6 and received a boarding pass printed on paper other than "supermarket-type receipts." Sometimes they print it on that paper in the format of what a boarding pass on cardstock would look like, but its still the receipt-like paper.
One time I got a CO boarding pass on US Airways card stock, but that was because the US counter agent offered the CO agent her computer to check in our large group at COS.
-J.
Tho' I've belted you an' flayed you, By the livin' Gawd that made you, You're a better man than I am, Gunga Din!
AirframeAS
Wed Jun 16, 2010 9:38 pm
Quoting KingFriday013 (Reply 1):
Is this similar to what AS is using now? The paper they use is not the boarding pass stock type, it is like fax paper or something....
AlnessW
Wed Jun 16, 2010 9:48 pm
Quoting AirframeAS (Reply 2):
That's correct. AS prints on that fax paper-like material.
Do any airlines print on boarding pass cardstock anymore, with the magnetic stripe? I remember a long time ago, you would either give your boarding pass to the gate who would scan it, and then tear the stub off and give it back to you. Or, you got to to stick it into a machine which would read the magnetic stripe, cut the stub off, which then pops out the other end. I know that AC just scans it and gives the whole thing back to you...
[Edited 2010-06-16 14:51:03]
[Edited 2010-06-16 14:51:45]
AirframeAS
Wed Jun 16, 2010 10:42 pm
Quoting AlnessW (Reply 3):
F9 does, but it is not with the magnetic stripe. The boarding pass we use is not the hard paper, it is between a hard paper and fax paper, if that makes any sense.
Doesn't UA still use this method?
N801NW
Wed Jun 16, 2010 10:48 pm
You most likely will receive a boarding pass printed on thermal paper regardless of kiosk or agent. It is much cheaper than card stock.
flyguy89
Wed Jun 16, 2010 10:51 pm
Quoting AirframeAS (Reply 4):
I know what you're talking about. At AA you'll get the receipt paper if you check in at the self-service kiosks but anything that is done manually as well as stand-by passes, we use that 'in-between' paper, it looks like a standard ticket too and is either green or blue. We also still give out ticket jackets
AlnessW
Thu Jun 17, 2010 5:33 am
That does make sense, thanks.
I'm not sure. For a while they did, but I don't know if they do anymore. When I flew on UA in July of 2008, they didn't. They used the same type of boarding pass, but no magnetic stripe. It was scanned and given back to me, intact. Sounds like what AirframeAS is talking about for F9.
Quoting flyguy89 (Reply 6):
Awesome!
Transpac787
Thu Jun 17, 2010 11:29 am
Possibly at the smaller outstations but at the hubs we haven't used those for quite a long time now.
NASBWI
Thu Jun 17, 2010 5:52 pm
Quoting AlnessW (Thread starter):
In 2007, B6 did print out the "receipt-esque" boarding passes. However, since the change to Sabre, they now print boarding cards. If, of course, you print your boarding pass from a computer, you will receive a sheet of paper with the pass on it. But at the airport, both at the desk and at kiosks, it's a card now.
Fierce, Fabulous, and Flawless ;)
jetblast
Thu Jun 17, 2010 6:14 pm
At my BA station we do still issue boarding cards with the mag stripe on them along with ticket jackets.
Speedbird Concorde One
AlnessW
Thu Jun 17, 2010 10:02 pm
Quoting NASBWI (Reply 9):
Cool, thank you! So no more "receipt" boarding passes for B6?
Quoting jetblast (Reply 10):
How are they checked at the gate?
B6JFKH81
Fri Jun 18, 2010 12:27 am
Quoting AlnessW (Reply 11):
On all the flights I have been on lately for them, my bording passes that were printed from the kiosks or check-in counter have been in the style and layout of a card boarding pass...but the paper is still not your thicker/cardstock paper. It was the thinner thermal paper.
Hope that helps, and Happy Jetting!
~H81
Transpac787
Fri Jun 18, 2010 12:56 am
I flew B6 on JFK-DEN in July 2009 and it was a receipt-style boarding pass.
AlnessW
Fri Jun 18, 2010 1:40 am
Quoting Transpac787 (Reply 13):
Huh. Seems like I'm getting a number of different answers here. Does anybody know specifically what they use in PDX?
NASBWI
Fri Jun 18, 2010 3:21 am
The switch to Sabre didn't happen until 2010   So yes, in 2009 you would have still gotten receipt-style boarding passes.
B6JFKH81
Fri Jun 18, 2010 3:55 pm
Quoting AlnessW (Reply 14):
All airports served by us now have the same style boarding passes:
Quoting B6JFKH81 (Reply 12):
AlnessW
Fri Jun 18, 2010 8:49 pm
Quoting B6JFKH81 (Reply 16):
Thank you, but are they cardstock or the thinner thermal paper?
jetblast
Sat Jun 19, 2010 4:18 am
How do you mean? As in how do we board the flight?
We don't actually use the mag stripe on the passes at all - they have a barcode on the front we can scan.
AlnessW
Sat Jun 19, 2010 4:47 am
Quoting jetblast (Reply 18):
Correct.
Most airlines these days don't seem to use the magnetic stripe, even if it's already on the boarding pass. They just scan the barcode. Do you guys tear the stub off and return it to the passenger, or give the whole thing back intact? Most airlines also don't seem to tear them anymore, even if the boarding passes are designed with a passenger stub attached.
jetblast
Sun Jun 20, 2010 3:22 am
Quoting AlnessW (Reply 19):
We do not tear anything off the boarding pass - we give them the whole thing back. If we had a situation where our computers were down and we had to manually board the flight we would tear off the stub.
This system is especially nice for our first and business class passengers. When the crew on board take their jackets all they have to do is tear off the stub and attach it to the hanger in the closet with the jacket - much easier to determine whose coat is whose on descent.
AlnessW
Thu Jun 24, 2010 2:30 am
O.K folks, here's the result:
My B6 flights were yesterday morning, (I will have a trip report up soon) and I checked in at a self-service kiosk at PDX. The kiosk printed the boarding passes on the thinner thermal paper (not cardstock, as NASBWI said. The check-in desk however was printing on cardstock) with a stub attached. No magnetic stripe on any of these, just one barcode on the front. (Although I did see some passengers in the airport and at the gate that had boarding passes with magnetic stripes, what's that about?) When they boarded the flight, they scanned the barcode, tore the stub off and gave it back, keeping the larger portion as their record. Sometimes they tore the stub off first and scanned their portion later (to speed things up, I assume). They also tore a portion off of the boarding passes that were printed at home.
AirframeAS
Thu Jun 24, 2010 6:58 am
Quoting Transpac787 (Reply 8):
When did you guys stop using the magnetic stripe paper stock?
Transpac787
Thu Jun 24, 2010 11:07 pm
Quoting AirframeAS (Reply 22):
Well... we still use it just because we have incomprehensibly huge inventories of them but they went out of official production in favor of the plain white stock back in... early 2009 or so.
AlnessW
Fri Jun 25, 2010 8:30 pm
Quoting Transpac787 (Reply 23):
What do you use the magnetic stripe cardstock for now?
