LASoctoberB6
NW B757-351 Seat Map
Sun Jun 27, 2010 2:37 am
It is very difficult to decipher DL's seat maps on their website. I see that there are three different configurations and I don't know which this is. Maybe I do and I'm afraid of the result lol. After recently discovering that in seat 13A there is no window on DL's 738 (which I'm of course going to be changing hopefully), I'd like to know before-hand if seat 21A on the 757-3 is over-wing or near an engine (i.e. if I were to look out the window, would I see the cowling and fan and such..)
(Was this the right forum for this question?)
[NOT IN SERVICE] {WEStJet}
FX772LRF
RE: NW B757-351 Seat Map
Sun Jun 27, 2010 2:41 am
http://www.seatguru.com/
Go forth, and learn.
-Noah
Cleared to IAH via CLL 076 radial/BAZBL/RIICE3, up to 3k, 7k in 10, departure on 134.3, squawk 4676, Colgan 9581.
KingFriday013
Sun Jun 27, 2010 11:31 am
As FX772LRF said, seatguru.com is a wonderful resource to learn more about your aircraft's seat configuration. If you would give us the date you will be traveling and the flight number, we could help you a lot more. According to SeatGuru, 21A is just over the front of the wing in versions 1 and 2 of the 753; on version 3, you are just ahead of the wing, so you will have a view of the engine cowling if you are on that aircraft -- but probably not the fan; I don't think you're far enough ahead.
-J.
Tho' I've belted you an' flayed you, By the livin' Gawd that made you, You're a better man than I am, Gunga Din!
LASoctoberB6
Sun Jun 27, 2010 12:16 pm
Quoting kingfriday013 (Reply 2):
DL1603 04AUG2010
If I can see the whole cowling, if not the fan, then I'm cool. (*sigh* Yes, I know.. I'm high maintenance  ) I'm very much hoping to be on version 3, if I'm to be right beside the engine.
Transpac787
Sun Jun 27, 2010 3:24 pm
Seatguru is incorrect. Version 1 incorrectly lists the configuration as 24F/203Y and neither version 2 nor version 3 are actual 757-300 configurations at all, as they both have ~150 seats in Y, which is WAYYY too small for a 753. You'd be looking at 36in pitch or higher with a configuration that light in Y.
www.seatexpert.com is way better, not to mention correct, on showing the ONLY 757-300 configuration in the fleet:
http://seatexpert.com/seatmap/235/Delta_Air_Lines_Boeing_757-300/
KingFriday013
Mon Jun 28, 2010 1:17 am
According to the seatexpert link, 21A will still give you a view of most of, if not all of, the engine cowling. You should be ahead of the wing.
I checked online at delta.com, and the seatexpert map seems correct.
-J.
LASoctoberB6
Mon Jun 28, 2010 10:15 am
Quoting Transpac787 (Reply 4):
http://seatexpert.com/seatmap/235/De...-300/
Someone should tell them about that.. I think that's why I was confused.. There really weren't that many 757-3s in the first place to have that many configs. Well, that's what my thinking was. I never went and actually looked them all up on say, www.planespotters.net and counted. Oh, btw, I've known about SeatGuru for a few years now. I just needed some extra clarification, that's all.   Oh, and thank you, Transpac787.
Quoting kingfriday013 (Reply 5):
Perfect. At least I got one flight right...
isitsafenow
Mon Jun 28, 2010 2:09 pm
According to the DL website, there are 20F and 204Y seats on the -300.
I think NW had 24F and 200Y.
I should remember, I've been on a few.
DL has only one seat chart for the -300 on their site.
Try row 16,17 or 18.
You should be ok
safe
If two people agree on EVERYTHING, then one isn't necessary.
Transpac787
Mon Jun 28, 2010 2:57 pm
Quoting isitsafenow (Reply 7):
The website says 20F/200Y, which is also incorrect.
The configuration is actually 24F/200Y. Just have a look at the seat maps of any of the 753 flights, there are 6 rows in F. The configuration of the 753's have remained completely unchanged since NW - only DL blue leather seat covers have been added and that's it.
isitsafenow
Mon Jun 28, 2010 6:49 pm
Quoting Transpac787 (Reply 8):
Thanks for the info and update. If the DL 757-300 seat chart is wrong, how many more DL listed seat charts are wrong?
I think we all argree that the Delta website needs an enema.
safe
MSPNWA
Mon Jun 28, 2010 10:59 pm
Quoting isitsafenow (Reply 9):
I did a quick check and didn't see any more that are wrong. But I'm not an expert on all of the 757 versions on the DL side, so maybe there's another that has slipped through the cracks, I mean canyons, in that website.
LASoctoberB6
Tue Jun 29, 2010 1:20 am
They weren't avail. But I will certainly try when I check in (online, of course).
Viscount724
Tue Jun 29, 2010 4:19 pm
It also has a lot of outdated and incomplete information. It can be slow to be updated when carriers change configurations, and may not show all variations for carriers that operate multiple configurations for the same type.
Users browsing this forum: Majestic-12 [Bot] and 1 guest
